Handheld GPS
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
currydon(at)bellsouth.net
PostPosted: Mon Dec 29, 2008 10:42 am    Post subject: Handheld GPS Reply with quote
I’m currently running Anywheremap on an iPAQ Hx4700 and I’m very pleased with it. However, because the Hx4700’s uses Windows Mobile 2003, I can’t download the latest map program from Anywheremap; it requires WM5 or higher. In the past, people who upgraded their Hx4700s to WM5 had all kinds of problems, but those problems were all supposed to have been taken care of with Microsoft’s latest release, WM6.1. So the questions are: have any Anywheremap/Hx4700 users downloaded WM6.1; how did you do it; and how do you like it?
Don
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
glastar(at)gmx.net
PostPosted: Mon Jan 05, 2009 4:02 am    Post subject: Handheld GPS Reply with quote
Hello Don,
sorry was not very active over Xmas and as I'm not seen any answer here
my experience. I'm running PocketFMS (as Anywhere Map is not so useful
outside the US) on my Hx4700 and did change autum 2007 from WM2003 to
WM6.0 and it was a difference which was noticeable, mostly by freeing
some memory. 6.0 for the 4700 is a non official version, but running
fine, very stable, faster and does not loose all your settings when the
battery goes flat.
You can see some perf tests here:
<http://www.pocketfms.com/phpBB3/viewtopic.php?f=4&t=3954>
The description how to upgrade is seen here
<http://forum.brighthand.com/showthread.php?s=151039929fbc914bba3cdba863cd00e4&t 46529>
(read carefully and reread before you start) I had some difficulties to
find the image, let me know if you can not find it I might still have it
somewhere.
Good luck and have fun!
Werner
Don
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
