		AirMike
				 Posted: Mon Jan 05, 2009 4:29 am    Post subject: Spread the load CSK washers on wheel pants |
				Has anyone use the "hat" style CSK washers on the wheel pants or on other fiberglass parts to prevent the fiberglass from cracking. I remember that I had a bunch of them on my Piper to prevent the cheap ABS from cracking on the pants?
 If you have used them would you consider them to be effective at spreading the load and preventing cracking?
 Spruce sell them pretty cheap
  _________________ See you OSH '18
Q/B - sold. |
				 Posted: Mon Jan 05, 2009 5:50 am    Post subject: Spread the load CSK washers on wheel pants |
				Piper liked them for a good reason ..... they cover up a multitude of
 sins ..... mostly wide tolerances in the ABS parts ..... and they look
 good.  We (the collective experimental plane builder 'we') take a lot of
 time to make our removable fasteners fit really nice so I'm not sure
 that I'd wallow out the holes to install the finish washers.  I would,
 however use them for the same reason that Piper does ..... after hard
 use has already wallowed out the holes.
 Linn
 AirMike wrote:
  OSH '08 or Bust (busted) be there in "09
  Q/B Kit - wiring and FWF
  http://forums.matronics.com/viewtopic.php?p 22941#222941
		Dave(at)AirCraftersLLC.co Guest
				 Posted: Mon Jan 05, 2009 11:56 am    Post subject: Spread the load CSK washers on wheel pants |
				We use them on everything we can.  I didn't put the on my -10 wingtips since
 there are so many screws there already, but just about everywhere else.
 Especially the wheel pants and the four screws at the front of the cowl.
 FWIW, I like to use #10 screws up there too.  They seem to hold up better.
 Dave Saylor
 AirCrafters LLC
 140 Aviation Way
 Watsonville, CA
 831-722-9141
 831-750-0284 CL
 www.AirCraftersLLC.com
		ron.mcgann(at)baesystems. Guest
				 Posted: Mon Jan 05, 2009 1:39 pm    Post subject: Spread the load CSK washers on wheel pants |
				Mike,
 I was just reinstalling the front wheel pant the other day and noticed
 that the pant sidewall at the bracket attach screws was particularly
 thin.  With the pant countersunk to take the -8 screw head, there is
 very little material to support the head.  Given the amount of vibration
 the pant will be subject to on our not so smooth strips, I will be using
 Tinnerman washers to reinforce the attach points on the pants.
 Cheers,
 -187, fiddly bits and paperwork.
