		jaybannist(at)cs.com Guest
				 Posted: Sun Jan 04, 2009 11:09 am    Post subject: Elevator bias spring |
				Any suggestions on finding the details about the elevator bias spring -  CZAW drawing 6-BO-4CZ ?
  Jay in Dallas
    Email message sent from CompuServe - visit us today at http://www.cs.com
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		david_a_g_johnson(at)btin Guest
				 Posted: Sun Jan 04, 2009 12:36 pm    Post subject: Elevator bias spring |
				Jay,
  I (after much e-mailing) got the attached drawing  from CZAW and I hope you find it more use than I did!
  In the end I found out, from the UK agents, that  all you need is a spring that will apply about 6 - 10 lbs of back pressure on  the stick when the flap is lowered.
  Dave Johnson
  601XL Jab3300, almost ready for test flying AND  GROUNDED!!!!!!
  [quote]   ---
		|  Description: |
		  Download |
		|  Filename: |
		 6-BO-5CZ.pdf |
		|  Filesize: |
		 49.83 KB |
		|  Downloaded: |
		 753 Time(s) |
				 Posted: Sun Jan 04, 2009 1:39 pm    Post subject: Elevator bias spring |
				Thanks for sending it, but, you are right.  It is pretty much useless.
  I was curious, because I had never heard of an "elevator bias spring".  Now that I know what it is, I know I don't need one.
  Jay in Dallas
		Martin Pohl
  Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
				 Posted: Mon Jan 05, 2009 2:15 am    Post subject: Re: Elevator bias spring |
				Jay & Dave
 Have a look at the attached drawing 6-BO-4CZ: This is the installation of the "elevator bias spring" required by LAA UK on CZAW CH601XL.
 Cheers Martin
		|  Description: |
		  Download |
		|  Filename: |
		 6-BO-4CZ.pdf |
		|  Filesize: |
		 171.88 KB |
		|  Downloaded: |
		 747 Time(s) |
 _________________ Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html |
		Terry Phillips
  Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
				 Posted: Mon Jan 05, 2009 8:05 am    Post subject: Elevator bias spring |
				Martin
 Does the LAA require the bias spring on aircraft that have the full width
 elevator trim tabs (i.e., as changed in updates 2005b)? Or is it only
 required on aircraft with the original, narrower elevator trim tabs?
 Thanks.
 Terry
 At 02:15 AM 1/5/2009 -0800, you wrote:
  	  | Quote: | 	 		  Jay & Dave
 Cheers Martin
 Terry Phillips  ZBAGer
 ttp44~at~rkymtn.net
 Corvallis MT
 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
 are done; working on the wings
 http://www.mykitlog.com/N47TP/
 _________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
		Martin Pohl
		Terry Phillips
				 Posted: Mon Jan 05, 2009 9:46 am    Post subject: Elevator bias spring |
				Thanks, Martin!
 ttp44~at~rkymtn.net
 Corvallis MT
Corvallis, MT
ttp44<at>rkymtn.net
		chris Sinfield
  Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
				 Posted: Mon Jan 05, 2009 1:10 pm    Post subject: Re: Elevator bias spring |
				OK I cannot read the words about the size or strength of the spring required for full flap, anyone expand on this? and
 how is it different from other XL's as I thought the Idea of the full size trim was so you can still do a circuit with full flaps and fly hands off with full elevator trim.?
 Chris
		psm(at)att.net Guest
				 Posted: Mon Jan 05, 2009 1:36 pm    Post subject: Elevator bias spring |
				One thing which varies a great deal among XLs is the engine
 weight.  I think this could have a large impact on the trim required
 under some conditions like full flaps.
 Paul
 XL getting close
 At 01:10 PM 1/5/2009, you wrote:
  	  | Quote: | 	 		  how is it different from other XL's as I thought the Idea of the
 Chris
