W&B 601XL
craig(at)craigandjean.com
PostPosted: Tue Jan 06, 2009 3:06 pm    Post subject: W&B 601XL Reply with quote
It has already been tested and (as I recall) the pilot and passenger walked
away. Picture attached. Was it Poland or the Czech Republic?
-- Craig
 Filesize:  28.95 KB
 Viewed:  829 Time(s)
Terry Phillips
PostPosted: Tue Jan 06, 2009 4:22 pm    Post subject: W&B 601XL Reply with quote
I believe it was Minnesota. See:
http://brsparachutes.com/files/Documents/Press%20Releases/PR%20Saves%20212-213.pdf
Terry
-- Craig
Terry Phillips ZBAGer
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
Gig Giacona
PostPosted: Tue Jan 06, 2009 7:18 pm    Post subject: Re: W&B 601XL Reply with quote
Well they talk funny there too.
That is amazing. I can't put a screw in the canopy without causing a crack yet this one can have a rocket go off inches away and not damage it.
Look at the gear on that thing. It pulled MANY G's on impact and yet the wings stayed on.
W.R. "Gig" Giacona
601XL Under Construction
Martin Pohl
PostPosted: Wed Jan 07, 2009 4:41 am    Post subject: Re: W&B 601XL Reply with quote
If anybody is interested in where the CZAW and european ULM versions have their BRS installed, have a look at the ULM-drawings (6-UL-5).
I am not sure if the 600kg BRS-version would fit right behind the firewall? The ULM version only needs the lighter 450kg parachute.
Martin
Zenair ULM supplement 22 pages.pdf
 Filename:  Zenair ULM supplement 22 pages.pdf
 Filesize:  1.96 MB
 Downloaded:  598 Time(s)
Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html
PatrickW
PostPosted: Wed Jan 07, 2009 7:30 pm    Post subject: Re: W&B 601XL Reply with quote
I'm considering mounting a BRS-1350 between the firewall and the instrument panel of my 601XL with 650 canopy.
Here's pictures: http://picasaweb.google.com/Patrick.Hoyt/BRS#
When using the 650 canopy on the XL, I believe that the usual baggage compartment location is no longer possible due to the 650 canopy covering what previously would have been the frangible cover installed in a cutout of top skin. It may be possible to mount the BRS behind the baggage compartment bulkhead, but that would move the CG much further aft.
The challenge with putting the BRS up front is that it will displace depth behind the panel, which will limit what can be put in the panel on the passenger's side. To partially mitigate this, I fabricated a pan that allows the BRS to sit lower. I plan to "fine tune" my CG with appropriate placement of the battery.
I'm interested in what other people are doing, particularly those who are installing BRS's on 650's or XL's with 650 canopies.
- Pat
ggower_99(at)yahoo.com
PostPosted: Wed Jan 07, 2009 9:11 pm    Post subject: W&B 601XL Reply with quote
Great for flying NORDO with only a compas OVER the instrument panel
Saludos
Gary Gower
PLEASE Do not Archive.
--- On Wed, 1/7/09, PatrickW <pwhoyt(at)yahoo.com> wrote:
Subject: Re: W&B 601XL
Date: Wednesday, January 7, 2009, 10:30 PM
--> Zenith601-List message posted by: "PatrickW"
firewall?
bulkhead, but that would move the CG further much aft.
- Pat
Patrick
601XL/Corvair
N63PZ (reserved)
http://forums.matronics.com/viewtopic.php?p 23481#223481
alex_001
PostPosted: Thu Jan 08, 2009 10:00 am    Post subject: Re: W&B 601XL Reply with quote
have a look at drawing and pics to see forward installation (std CZAW)
 Filesize:  91.77 KB
 Viewed:  737 Time(s)
 Filesize:  369.96 KB
 Viewed:  753 Time(s)
 Filesize:  170.16 KB
 Viewed:  778 Time(s)
 Filesize:  946.75 KB
 Viewed:  724 Time(s)
PatrickW
PostPosted: Thu Jan 08, 2009 11:49 am    Post subject: Re: W&B 601XL Reply with quote
alex_001 wrote:
have a look
Thanks for sharing those, Alex.
- Pat
