wild.blue(at)verizon.net Guest
Posted: Wed Jan 07, 2009 11:33 am Post subject: Spins |
Gents--
Not to beat the dog, but it may be wise to remember that spinning any
airplane involves some risk, even your favorite fully tested and thoroughly
flogged certified aerobatic airplane. Correct me here, but I'm unaware of
any documented flight test data for Yak-50's, -52's or Nanchangs regarding
fully developed and flat spins. I hope they were required to demonstrate
some sort of spin recovery capability and documented demonstrated recovery
techniques, something at least equivalent to what FAA requires for aerobatic
airplane certification (which ain't much), but I've never seen any evidence.
Anecdotes ain't documentation.
Just because you did a couple of one or even two or three-rotation spins in
a 150 or 172 during CFI training or you read all about spins in Gene Beggs'
or Rich Stowell's books doesn't mean you know anything about spinning Yaks
or Nanchangs. Yes, Craig, Nanchangs (forward CG) are hard to hold in a spin
but put a little weight in the tail and its a different matter. We all
know too many folks have been killed in -52 spin accidents. Too many highly
skilled, highly experienced pilots have been killed in lots of different
airplanes that were supposed to be safe to spin. Art Scholl--who was famous
for his airshow 27-turn inverted flat spins--comes to mind (Pitts S-2A).
If you've ever seen any of the film of NASA spin testing Grumman Yankees you
have to wonder what ever made anyone involved in the project think the
airplane had potential for aerobatic certification (which they had intended)
Engineers get it wrong, too.
The classic wings level, gradual speed reduction, stick all the way back,
stand on the rudder spin entry and the equally classic crossed controls base
to final skid entry are not what kill folks. It's not stalling at low
altitude, either. It's distraction, surprise and especially--though I hate
to say it--piss poor piloting technique. It's not the entry, it's not the
recovery, its awareness and avoidance that must be learned and exercised.
That means keeping the nose down, the speed up, the ball in the cage, the
bank shallow and your head on tight at low speed and low altitude.
Spin training, yes--very carefully, in the right airplane with a truly
qualified instructor. Test piloting--are you really sure you want to do
that?
Let's be careful out there. Good piloting skills require proper instruction
and lots of practice. To paraphrase Alexander the Great: De Le vigilance,
encore de Le vigilance, toujour de Le vigilance!
Jerry Painter
Wild Blue Aviation
425-876-0865
www.FlyWBA.com
JP(at)FlyWBA.com
Posted: Wed Jan 07, 2009 2:42 pm Post subject: Spins |
So basically what you are saying here Jerry is that you do not advise
getting spin training in the type of aircraft that you own, be it a
YAK-52, YAK-50 or CJ? And that instead of spin training, you recommend
spin avoidance instead. Again, if I am getting the wrong meaning out of
what you have written, please correct me.
If I have indeed interpreted you correctly, I just want to say that I
completely disagree with you. I have received spin training in a number
of different aircraft. Each one has it's own little way of doing
things, and personally I do not think anyone should even begin to think
about doing aerobatics in a YAK-50 or 52 or CJ until they have received
spin training in the make and model of aircraft that they plan on doing
said aerobatics in.
I do agree totally that there is always some risk involved.... That risk
starts as soon as you put the key into the ignition of a car, turn on
the mags of an airplane, you name it. The risk factor increases doing
spins, landing at night at a short field you have never landed at
before, etc., etc. Life's a risk for heavens sake.
FYI, both the 50 and 52 have a Flight Manual that has been translated
from the original Russian. In that Flight Manual, it describes the
procedures for certain aerobatic maneuvers including spins.
When I learned to fly, some of the Instructors had never been in a spin
in their entire life. We were taught to avoid them at all costs, and to
be ... Pretty much... Scared to death of the darn things. I flew for
YEARS with that stigma. I now fervently believe that it is the wrong
way to go when it comes to flying airplanes.
Let me repeat... I am not saying you are wrong. I am saying I do not
agree with you... Each of us has the right to not agree... So no mud
slinging intended.
Mark Bitterlich
drc(at)wscare.com Guest
Posted: Wed Jan 07, 2009 3:21 pm Post subject: Spins |
I agree with Mark.
I know what Jerry's point is - and I would not jump on him though.
I think he is correct that a guy who does not have adequate training,
reliable data from the manufacture, or a modified plane is becoming a
test pilot.
I do not have good data and info on the Yak 52TW. I have talked to
the Romanians at OSH and they cannot supply flight testing info that
would be of any use. Also when we moved the oil cooler and modified
the leading edge of the airplane, I went up high and became a test
pilot. We had 3 different openings and a variety of fences for the
opening to the oil cooler and I went out and stalled/spun the plane
from numerous attitudes and configurations to collect the info for the
mod. We tufted the right wing to look at airflow around the opening.
So yes my experience with a newly manufactured and modified plane
confirms Jerry's conclusion that we become test pilots.
On the other hand the Yak 55 -
Good information from Russia, translated into English. An airframe
designed to compete in aerobatics with stall spin a required figure
(not to be avoided). I would say that is more what Mark is
describing. Yet it is a single place - you can talk about stall spin
on the ground all you want and read about it in the manual, but at
some point you just have to go do it. You have to take flying
experience from other planes, and people's advice and go out by
yourself and learn what the plane does. But with good information.
Herb
On Jan 7, 2009, at 4:40 PM, Bitterlich, Mark G CIV Det Cherry Point,
MALS-14 64E wrote:
Point, MALS-14 64E" <mark.bitterlich(at)navy.mil>
recommend
out of
number
think
received
doing
said aerobatics in.
risk
spin
and to
slinging intended.
Mark Bitterlich
bu131(at)swbell.net Guest
Posted: Wed Jan 07, 2009 4:47 pm Post subject: Spins |
we can beat this subject to death
but a few words to the wise
I lost a few friends in the T-6 world with similar situations
after 25 years and many scars in my back I developed a few safe rules
I happen to be number 2 behind a good friend of mine whom I had to extract from the ground and hate to see this recurring.
overhead approaches
at 90 degrees of bank if you load the stick (because you are pushed away due to quarterly winds) or mismanaged the turn (turning too late)
in a T-6 there is not enough power to recover similar in a yak and other airplanes you need 300 + miles/hr to stay flying
therefore break always high over the field, do not extend the turn, always keep the ball in the center, its a COORDINATED TURN
cross control will kill you.
You can have 1000 hrs of spin training and there is not a soul in the world that will save you from braking your neck. You have to AVOID entering a
landing stall, not enough room to recover.
If you dont believe it, get an instructor, go to 10,000 feet, drop gear and flaps, slow it to 90 kts (landing configuration) do an overhead approach
not losing more than 400 feet in the turn and then just load the stick (you will not believe how fast you will get in a full established spin)...
spin recovery (thanks to Nikolai for the instruction) is absolutely needed. Any hammerhead maneuver at the top with cross control not only will get you
into a spin but possible into an inverted spin which in the yaks and sukhois with their gyroscopic effects are not natural to recover. There is the jesus
maneuver to learn etc to be able to manage such attitudes. But unless you do aerobatic and simple formation flight please be original and try a different
way to go.
fly safe
my thoughts to the flush and GIB family
ak
yakplt(at)yahoo.com Guest
Posted: Wed Jan 07, 2009 5:57 pm Post subject: Spins |
My 2 cents yet again.
In order to fully recognize when a spin is getting ready to happen... you have to be in the airplane a few times when it actually does happen. Period. Of course you want to avoid a spin in the pattern, but to avoid crossed controls and to "always keep the ball in the middle?" What happened to the "slip to landing" practice we all had as private pilots?
While doing Hammerheads it is quite common to use crossed controls. For example, .. full right rudder with just a tad of left aileron ... because the left wing is swinging faster with a hammer to the right, it develops a tad more lift, thus a little left aileron is required to keep the maneuver clean without rotation of the fuselage. The trick is to keep it on the exact vertical line while doing this. When your vertical line is off, and you end up say... pushing forward on the stick, with outboard aileron and full right rudder... you can go right into an inverted spin. The answer is not to avoid cross controls but to develop a good vertical line.
The bottom line is that there are many MANY ways to fly an airplane without crashing the darn thing. More important than anything else is attitude. Anyone that gets at least somewhat serious about aerobatics knows that the first thing to achieve is not to be afraid of the airplane. In order to accomplish this one needs to be convinced that he or she can recover from anything unexpected. This takes training and practice and not avoidance.
The question is should anyone be doing 90 degree high G Sectional breaks into the pattern multi-ship with none of the above teaching or practice at all? Others may disagree.. but I say "no". Of course I could be wrong.
Mark Bitterlich
N50YK
To: yak-list(at)matronics.com
Sent: Wednesday, January 7, 2009 7:46:41 PM
Subject: Re: Spins
overhead approaches
way to go.
fly safe
richard.goode(at)russiana Guest
Posted: Wed Jan 07, 2009 7:54 pm Post subject: Spins |
Following a fatal spinning accident in a 52-flown by a highly experienced
pilot [one of the top handful of aerobatic pilots at a World Championship
level]BUT NO EXPERIENCE in the 52,I did a lot of research into this issue.
I found SEVEN different flight manuals for the 52 and ONLY ONE went into any
detail of the potential problems of recovery from developed spins!
This is because the Russians and others were being taught in a military
system where spin training was done in the aircraft with a really competent
pilot.[Also,in passing,where no pilot was allowed to fly aerobatics weighing
more than 100 kgs-220 lbs,total with clothes,parachute etc.!!]
Richard G.
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
I'm currently in Sri Lanka but this Mail is working,and my local phone is
+94 779 132 160.
Posted: Thu Jan 08, 2009 2:44 pm Post subject: Spins |
Do you spin the 52 Richard?
Mark Bitterlich
I concur with everything Herb has said here, and Jerry as well
(regarding "becoming a test pilot" in certain circumstances). What Herb
said about the 55 applies just as well to the 50. The 50 was designed
to be an aerobatic competitor from day one. Regarding the 52, I'll let
owners of the aircraft thrash that question around. I do not own one,
nor have I flown one, but I have watched Sergei Boriak teach guys here
in New Bern to TUMBLE that aircraft time after time, and I kind of think
that if the aircraft can tumble, that it is probably safe for spins
given the correct instruction and the proper precautions, (as mentioned
by Richard Goode more than once).
One addition: When I first spun my 50... I did it by myself, starting
way way up high. The thing acted a little strange. The details of which
are not worth mentioning... .but it was kind of like the airplane was
talking to me and saying: "Something here is just not quite right". A
feeling more than a known issue... The plane just departed much faster
and with a suddenness that I had never felt before in another airplane.
Later I spun it under the supervision of Sergei Boriak watching from the
ground. That guy is so good it is like having him in the backseat of an
airplane that only has one seat. He could see every little nuance of
what was going on and was coaching me with stick inputs going in and
coming out of the spin. Just an amazing guy.
ANYWAY....
Here is the primary reason I am writing this posting. I never did a
weight and balance on my aircraft myself. I used the previous data from
the previous owner. I guess I would have to admit that this was a
mistake... A bad one. During my second or third year of ownership on my
50, I modified the tailwheel locking adjustments so that you had to push
the stick ALL THE WAY FORWARD to unlock the tailwheel. This keeps the
tailwheel from unlocking during normal flight and then going into a bad
shimmy when landing. If your 50 does this, send me a private email.
ANYWAY... When I took everything apart in the tail, I found a 20 pound
lead weight neatly installed back there. WTFO !!!! No wonder my 50
would do a snap roll so much better than any other 50 I had ever flown.
It also explained the weird spin feelings I had with this aircraft. The
logs did not show any such modification. I have no idea who put it in.
Obviously it is gone now.
Mark Bitterlich
N50YK
cjpilot710(at)aol.com Guest
Posted: Thu Jan 08, 2009 6:23 pm Post subject: Spins |
I don't think there is a question here whether or not spin training is the good safety insurance or not. I believe that along with "normal spin" training some or more time should be spent on the unusual attitudes from whence spins can occur. Not just from just poorly started loops, rolls, or hammerheads, (more a issue in Yaks) but in the mundane turns.
Year ago when I was teaching in Cubs and Champs, spins were required on our school flight curriculum. In particularly what we called "over the top" and "out of the bottom" spin entries. Crossed control spin entries.
The "over the top" spin was done from a climbing turn. After established, a slip was induced by rudder, either by reducing required rudder or adding top rudder, and the bank angle held with the ailerons. At stall, the airplane would usually brake toward the high wing. If controls were held, she would virtually, snap away from the turn and start to enter a spin opposite the original turn. The same again was performed but this time by inducing a skid. This time of course the airplane would brake into the turn.
The "out of the bottom" spins were done the same way except from a glide. Of course this was to imply and simulate what could happen in the traffic pattern. Of course the WW2 PT-22 had the worst reputation for stall/spin. I am willing to bet where most of the accidents happened?
If I remember correctly we spent more time on these stalls and spin entries than we did on anything straight ahead.
Like a number have already remarked on this list, I believe one should be very aware and training should cover ALL those realms of flight where stall/spins can occur. In particularly in those that could happen at altitudes and speeds that one would encounter down wind to base, to final part of the pattern. While I do not want to minimum-ize the need for training of spins at altitude, pre-stall and eminent spin recognition is what may save more guys, simply because they will fly though that area on every flight.
One other point. A lot of forced landings are blotched and turned deadly because of the same problem. "Trying to hard - with nothing left". Trying to turn back to the runway, after a takeoff engine failure? Once again - stall with incipient spin will do them in.
The CJ does not want to spin BUT she will brake to a very nose down attitude with wing snap, with any cross controls. If this happen below pattern altitude, you may position the controls to recover from the stall and even stop the spin, BUT there is no altitude left. From a 8 hundred feet, traffic pattern there just not enough room for a recovery. She is just a very pretty green anvil.
Today I took my CJ-6 up to 4,000' and practiced a total stall series. At one point I tried to simulate what might have happen. I hate to admit it but the point here is in 1,500 hours of CJ-6 time, I've never done cross control stalls with the gear and flaps down before in the CJ-6. So I was really interested in what might happen. The airplane behaved as you would expect, perhaps with slightly faster rolls rates than with gear and flaps up. (I would have thought because of gear and flaps being down, they would dampen roll and pitch rates). It seem to me it took considerably more control deflection to produce the brake but the brake was sharper and roll rate higher. IAS at the stall was about 75Kts and bank angle was around >45'. When the elevator was held back, there was a very short stall burble which ended at the brake. The nose pitched from about 10 deg nose down to about 85 deg nose down within 2 second and rolled about 90 deg at the same time. At that point I initiated recovery. I found that the airplane had lost between 300 & 400 feet from the brake altitude and required another 200' to 300' to recover to straight and level flight. A average total of 600' from the brake altitude.
This was not an unusual "hairy" maneuver at 4,000' but down below pattern altitude, I am sure it would instill panic, where someone might lock back on the stick.
Not everyone in the aviation community has had the advantage of "government" schools nor professional aviation back grounds. Compared to the 3K of F-whatever time or 24,000 hr of heavy time, many of our members are low timers. Many of our members start out at our local FBO and pay their way though the tickets. There some schools out there better than others. And I personally think that more training should be spend on basic stick and rudder. But in this day of GPS, TSA, ADIZ, Class B,C,D, etc. the average private pilot has more stuff to worry about and required to learn, than we did over 50 years ago. Most likely most of our guys have gotten just the minima spin training during their 10 hours insurance check outs. That is if their instructor isn't afraid of CJ or Yak spins.
Passing the "word" at RPA clinics, airport coffee shop, coke machine by the hangar, bar, or over this list, helps. Good training, - hopefully, will keep the body count down.
Jim "Pappy" Goolsby
A Good Cr75x1215047751x1200957972/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=DecemailfooterNO62"> See yours in just 2 easy steps!
nigel(at)yakdisplay.com Guest
Posted: Thu Jan 08, 2009 11:51 pm Post subject: Spins |
I do....
Nigel
http://yakdisplay.com
Posted: Mon Jan 12, 2009 7:36 pm Post subject: Spins |
Years ago I taught college AF, Navy and Marine ROTC cadets how to fly. One
guy in particular was pretty sharp and wound up instructing on T-38's. He
was killed in short order by a student who stalled and snapped the aircraft
in the pattern. I gave another guy a BFR about a year ago who had also
instructed on T-38's. Had some pretty good stories.
I'm thoroughly convinced that lots of practice flying slow in different
configurations/attitudes is the best way to learn how an airplane will
behave in those situations you'd rather avoid. Sensitizes the hind quarters
and earballs, encourages proper movement of hands and feet. It won't
prevent the diversion induced unexpected tho it makes folks more aware of
the possibilities and consequences so more likely to practice avoidance.
Doing spins is fun and instructive, too, in the right airplane, but in and
of themselves don't really expose folks (usually) to the kinds of situations
that lead to the unexpected. -52's are very docile aircraft, usually, but I
m not going to spin one. I'll take the word of folks like Richard Goode and
the unfortunate experiences of those who've been killed in them (including a
friend of mine) to heart. Learning at least basic aerobatics is good, too.
Opens the envelope. We are so fortunate that these airplanes became
available when they did and at reasonable prices so standard issue
folks/aging boomers could join up to do the kind of flying the airplanes
were built to do. Not readily available elsewhere on the civilian market.
T-34's, T-6's, T-28's etc are a bit pricey for most of us. Glad to see that
others, RV's etc have joined in the fun.
BTW, there is a video on U-Tube of a de Havilland Mosquito doing a fly by
that winds up in a half-assed pitch up to a half roll, inverted stall/spin,
flat spin, spin reversal and crash. No apparent power reduction. Almost
looks intentional and almost recovered. Not pretty. I presume the pilot
was an otherwise experienced and sharp sort.
The -52 spin article is worth making more widely available--why don't you to
post to the list? In fact I think I'll post this whole discussion.
JP
Posted: Tue Jan 13, 2009 1:56 pm Post subject: Spins |
Sorry, the more you emphasize how you feel about it Jerry, the more I am
going to reply and keep saying that I disagree and honestly think my
point of view is just as meaningful and valid as yours is. I have no
question in my mind that anyone who reads what we both have written is
aware of the two widely divergent points of view. So what do we have to
gain by continuing to write about it? I have no problem with spin
avoidance training. You seem to be bound and determined to influence as
many people as you can from getting spin training. I just don't get it.
While you say that spin and aerobatic training "opens the envelope",
everywhere else in your posting you advocate against it, at least IMHO.
Anyone that has been exposed to flying long enough accumulates stories.
Telling them over a cold beer is a very important and fun part of what
flying is all about. I am not going to debate specifics concerning
every accident story on the planet, so I will not address the ones you
mention.
So... You say: "I'm thoroughly convinced that lots of practice flying
slow in different configurations/attitudes is the best way to learn how
an airplane will behave in those situations you'd rather avoid."
How in the world are you going to learn how an aircraft will behave in a
situation you would rather avoid, by never experiencing what it is you
trying to avoid? To me, that is like saying: In order to avoid
skidding around in circles driving in your car when it snows, simply
either don't drive in the snow, or if you do, drive slow enough so that
you will never skid. When I was a kid, my Dad took me to a BIG parking
lot after a good snow. We went skidding and sliding all over the place.
Had a ball doing it too. In the end I learned how to steer into a skid,
learned how to not just JAM ON THE BRAKES AND HOLD THEM to avoid sliding
into another car, etc., etc. This skill set saved my butt many times
when driving in the snow. This is an EXACT analogy to the present
topic. A person can either learn to drive a car right up to the point
where a skid is probably going to occur, and stop right there and hope
it never goes beyond that point... Or he or she can learn by doing.
That said, you can learn how to fly an airplane the way you say, and
hope to JESUS that nothing ever comes up that distracts you, or the
airplane is rigged wrong, or you accidentally get into wake turbulence,
WHATEVER... Point being, you never EVER get into a situation where the
airplane is in a position and/or situation that you never have been in
before and have no freaking idea how to get out of, ..... Or, you can
realize that an airplane has the capability to do a whole lot more than
what you learned as a private pilot, and it might be a good idea to
prepare yourself for that kind of situation should it ever occur. The
first method builds a fear of the unknown, that is simple human nature.
The second method builds confidence in ones self and in the airplane.
You said: " Doing spins is fun and instructive, too, in the right
airplane "
The list of aircraft that are approved for spins is much higher than the
number that are not. A Cessna 172 is approved for spins. If the
airplane that you fly is approved for spins, you should be taught spins
in that aircraft. Later on you can branch out and spin something like a
PITTS and do the whole spin regimen. I.E. Upright, inverted, flat, etc.
airplane, but in and of themselves don't really expose folks (usually)
to the kinds of situations that lead to the unexpected. "
I have no problem with that statement. This is not an EITHER // OR
situation. Of course I advocate spin avoidance! Who would not,
especially in the pattern! However.... While doing spin training does
not expose a pilot to the kinds of situations that lead to the
unexpected (as you say), not doing spin training leaves a pilot totally
unprepared for what happens AFTER the unexpected manages to somehow
happen. Why do you think CFI's have to be taught spins as a matter of
FAA requirements?
You said: " -52's are very docile aircraft, usually, but I m not going
to spin one "
Then I would strongly advise that when you do fly a 52, that you keep it
perfectly within the confines of what is defined as "non-aerobatic
flight". No bank angles beyond 60 degrees for example. No rolls, no
loops. Etc., etc. However, the YAK-52 was built as an aerobatic
trainer. Most owners of them are going to want to do something other
than fly straight and level. When someone of your skill and experience
says: "I am not going to spin a YAK-52" that kind of gives the
lay-person the sense that there must be something inherently dangerous
about doing a spin in a YAK-52, and as such ... They should be avoided
at all costs. This is simply not the case.
You then go further by saying: " I'll take the word of folks like
Richard Goode and the unfortunate experiences of those who've been
killed in them (including a friend of mine) to heart."
You are quoting Richard Goode TOTALLY OUT OF CONTEXT and that is wrong.
Richard Goode never once said not to spin a YAK-52. What he DID say is
that if you do spin one, you should be well aware of some of the special
characteristics of this airplane, and you should get that spin training
with a totally qualified instructor in this particular make and model.
This is good advice for ANY kind of training in ANY kind of aircraft!
Lastly, as you and anyone else with any real history in aviation knows,
people have been killed in just about every make and model of aircraft
made. Some die in spins because they are improperly trained, or are
with poor instructors, and some fly a perfectly good airplane right into
a mountain, or run them out of gas, etc. etc. The list is endless. Do
not try to imply some kind of inherent additional danger regarding spins
as compared to any other aspect of flying that is not done correctly.
We all know that a careless and/or reckless approach to flying is
inherently dangerous whether it be spins, or simply taxing across the
flight line.
Quote: " Learning at least basic aerobatics is good, too. Opens the
envelope."
Completely agree.
Quote: " Glad to see that others, RV's etc have joined in the fun "
The IAC is even thinking about including them in a special aerobatic
category for the same exact reason. Of course, that means you have to
learn how to spin one.
You comment: "BTW, there is a video on U-Tube of a de Havilland Mosquito
doing a fly by that winds up in a half-assed pitch up to a half roll,
inverted stall/spin, flat spin, spin reversal and crash. No apparent
power reduction. Almost looks intentional and almost recovered. Not
pretty. I presume the pilot was an otherwise experienced and sharp
sort."
And your point is? Scott Crossfield flew right into a thunderstorm and
died. Bob Hoover crashed after some idiot filled his airplane with
JET-A after an airshow. The lead pilot of the Thunderbirds flew his
whole team into the deck and killed every one of them during practice
some years ago. Recently during a section flight in this area, lead got
too slow during a formation approach and a young low time pilot stalled
and spun in while flying on his wing. Some of the very best pilots on
this planet have crashed and/or died from a momentary lapse of judgment.
What exact point is made by that? Flying can be dangerous?
Lastly you said: " The -52 spin article is worth making more widely
available--why don't you to post to the list? In fact I think I'll post
this whole discussion. "
First,..... part of that discussion you decided to make public
specifically mentioned the recent crash in Texas, and we have been asked
not to discuss that in public, so I am removing that from my message
string here. Second, .....in most circles it is considered to be not in
the best of taste to participate in a private email discussion (where
the rules about what we should or should not discuss in public do not
apply) and then take that conversation and post it for the whole world
to see. Especially without asking all the other participants first.
Sorry if that sounds like a lecture, but I know that when someone does
that to me, it really makes me angry. Others don't care at all.... But
I believe it is better to be safe than sorry when taking a private
conversation public.
Back to the main topic. I think we might BOTH agree that spin
prevention is a good idea. Can we not also agree that Spin Training is
equally as important to create the best blend in total pilot training?
Mark Bitterlich
wise(at)txc.net.au Guest
Posted: Tue Jan 13, 2009 4:12 pm Post subject: Spins |
