Adam(at)ValidationPartner Guest
Posted: Sat Jan 07, 2006 2:34 pm Post subject: Z14 Failure Modes and the Cross-Tie |
I'm laying out the electrical system for my all-glass, all-electric,
FADEC-powered Lancair Legacy. The Z-14 system seems like the natural way to
go, using two full-size alternators. It would be very attractive to have the
ability to power both the A and B buses and recharge both batteries from a
single alternator when needed. However, I'm having trouble imagining a
failure mode where the cross-tie could be used in flight.
If the Bus A alternator's field breaker trips in flight (for example), would
it be safe to engage the cross-tie? You don't know what caused the failure,
and tying the A and B buses together could knock out the B bus.
If you get a low voltage warning on bus A, do you pull the corresponding
field breaker and engage the cross-tie? Again, if something is shorting out
the bus (such as shorted windings on the alternator), you are in danger of
overloading bus B.
Any thoughts?
Adam Molny
Legacy #151
klehman(at)albedo.net Guest
Posted: Sat Jan 07, 2006 5:58 pm Post subject: Z14 Failure Modes and the Cross-Tie |
Hi Adam
I figure the most likely reason to close the crossfeed is when one
alternator simply stops producing power or has been shutdown by the OV
protection. Bus voltage will be nominal battery voltage in such a case.
With a contactor on the output of an IR regulator even the stator and
diodes are out of the circuit when I shut down an alternator or the OVP
activates but I'd expect the alternator fuse/breaker/ANL to already be
open anyway in that case. I agree that it might be unwise to close the
crossfeed if immediately after the low voltage warning you observe that
the voltage is below normal battery voltage but then again you have the
option if you need the equipment and think maybe you've got a open
circuited or disconnected battery (or open master contactor) that has
allowed a subsequent OV excursion and alternator shutdown. Plan A would
be to leave it alone til on the ground if I don't need it. Any smoke or
sparks would definately keep my finger away from the crossfeed. There
really isn't much of a "bus" on a small airplane with fuse blocks which
makes it very difficult to imagine a shorted bus. Z-14 also gives the
option of conducting a single alternator recovery flight home or to a
maintanance facility.
Ken
overloading bus B.
Any thoughts?
Adam Molny
Legacy #151
Posted: Sat Jan 07, 2006 7:43 pm Post subject: Z14 Failure Modes and the Cross-Tie |
Hi Adam
Ken
overloading bus B.
Any thoughts?
Adam Molny
Legacy #151
Posted: Sun Jan 08, 2006 1:25 pm Post subject: Z14 Failure Modes and the Cross-Tie |
Hi Adam
Ken
overloading bus B.
Any thoughts?
Adam Molny
Legacy #151
AdmID:83E83C29680237C6A7B9D0D346BF94A9
AdmID:699E6044ECE49308DB21D9330AB77D81
Posted: Sun Jan 08, 2006 2:05 pm Post subject: Z14 Failure Modes and the Cross-Tie |
Hi Adam
Ken
overloading bus B.
Any thoughts?
Adam Molny
Legacy #151
AdmID:F24EE12554874507101161E0190BA573
nuckollsr(at)cox.net Guest
Posted: Sun Jan 08, 2006 5:23 pm Post subject: Z14 Failure Modes and the Cross-Tie |
99+ percent of alternator failures is to simply stop
producing for whatever reason . . . including ov trip.
A major fraction of what's left will be cause for manual
shutown . . . voltage unstable? Whatever. It is very unlikely
that any alternator failure will take out the b-lead protection.
It's axiomatic that many problems get worse when the pilot
starts messing with things in some attempt to "get all the
goodies back up and running."
The advantage of a fully dual system is that you spread
your backup systems around. One on main bus, one on aux
bus. The best thing to do when something goes T.U. on one
bus is to simply shut that one down. Go into an endurance
mode until comfortable arrival is assured. Battery on the
cold bus is held in reserve. Battery on working bus is
being supported by normal alternator operations.
When and if anything on the 'cold' bus becomes useful
or necessary in the final phase of flight. Close battery
contactor first and watch for normal battery-only
bus levels. Close crossfeed contactor second while observing both
bus voltages now show normal operational levels. Then
finish the flight.
If any voltages appear out of whack after operation of
a switch, re-open the switch immediately and finish the
flight on one bus . . . but don't do this experiment until
you have the airport in sight.
I think it's useful to think of the various system options
as tools for comfortable termination of flight by insuring
availability of minimum equipment . . . the exercises that
pilots go through to perform in-flight diagnostics and/or
get some suite of equipment up running doesn't
necessarily improve outcome is certainly a distraction
and perhaps hazardous.
Only the more complex aircraft can justify Z-14. While
complexity brings capability and convenience, it also
brings workload. If you're vfr in the clear, then perhaps
a total failure is no big deal. When you are depending on at
least the most useful of things to be working then you're
probably IFR and busy with pilot-things to do. The last
thing you want to do is troubleshoot especially when there
is risk of making a situation worse.
| Quote: | Hi Adam
Ken
Adam Molny wrote:
<Adam(at)ValidationPartners.com>
>overloading bus B.
>Any thoughts?
>Adam Molny
>Legacy #151
-- incoming mail is certified Virus Free.
< Throughout history, poverty is the normal condition >
< of man. Advances which permit this norm to be >
< exceeded -- here and there, now and then -- are the >
< work of an extremely small minority, frequently >
< despised, often condemned, and almost always opposed >
< by all right-thinking people. Whenever this tiny >
< minority is kept from creating, or (as sometimes >
< happens) is driven out of a society, the people >
< then slip back into abject poverty. >
< This is known as "bad luck". >
< -Lazarus Long- >
http://www.aeroelectric.com
Posted: Mon Jan 09, 2006 8:19 am Post subject: Z14 Failure Modes and the Cross-Tie |
finish the flight.
| Quote: | Hi Adam
Ken
>overloading bus B.
>Any thoughts?
>Adam Molny
>Legacy #151
< -Lazarus Long- >
AdmID:506495D6A0BE8036E3BA3D8C6EA71624
Hi Adam
Ken
overloading bus B.
Any thoughts?
Adam Molny
Legacy #151
AdmID:834804A500D89DCA3DDB10F5EDBDD50D
Posted: Mon Jan 09, 2006 9:30 am Post subject: Z14 Failure Modes and the Cross-Tie |
Hi Adam
Ken
overloading bus B.
Any thoughts?
Adam Molny
Legacy #151
AdmID:679109EACB011FD5036DE2BED2C725F9
Posted: Mon Jan 09, 2006 9:31 am Post subject: Z14 Failure Modes and the Cross-Tie |
finish the flight.
| Quote: | Hi Adam
Ken
>overloading bus B.
>Any thoughts?
>Adam Molny
>Legacy #151
< -Lazarus Long- >
AdmID:A867B9F7A178F5059EAB26AD23FFEF89
Posted: Mon Jan 09, 2006 10:18 am Post subject: Z14 Failure Modes and the Cross-Tie |
Hi Adam
Ken
overloading bus B.
Any thoughts?
Adam Molny
Legacy #151
AdmID:71891E74249F9C1BBF57E74AFBB586C3
finish the flight.
| Quote: | Hi Adam
Ken
>overloading bus B.
>Any thoughts?
>Adam Molny
>Legacy #151
< -Lazarus Long- >
AdmID:ED8CE98DD769EE3B4812009F5B18A878
Posted: Mon Jan 09, 2006 12:00 pm Post subject: Z14 Failure Modes and the Cross-Tie |
Hi Adam
Ken
overloading bus B.
Any thoughts?
Adam Molny
Legacy #151
AdmID:09CAA75BA955462A672903018FC996DC
finish the flight.
| Quote: | Hi Adam
Ken
>overloading bus B.
>Any thoughts?
>Adam Molny
>Legacy #151
< -Lazarus Long- >
AdmID:E0D14FFB7A61D0F5EBC9D02D7B0A282F
