		Kelly McMullen
				 Posted: Thu Jan 08, 2009 8:44 pm    Post subject: Erroneous Plans sequence on elevators |
				While it doesn't cause a major problem, I was a bit annoyed to find
 out that the plans called for edge rolling the skins to full plans
 pages after telling you to dimple them, where the dimples prevent a
 nice neat edge roll. Page 9-7 calls for the dimpling in step 9. Page
 9-9 step 7 calls for the edge roll. IMHO both 9-9 steps 7 and 8 should
 be done before dimpling. Also a bit annoying that the foam rib
 templates have no dimensions with them, so you don't know if the plans
 page is exactly to scale or not. Given that the foam blocks are bigger
 than the dimensions given in the plans for them, I'm not so confident
 about the templates.
 Kelly
 40866, obviously on elevators
A&P/IA, EAA Tech Counselor
KCHD |
		Phil.Perry(at)netapp.com Guest
				 Posted: Thu Jan 08, 2009 9:15 pm    Post subject: Erroneous Plans sequence on elevators |
				I can see where you're coming from and I usually try to roll my edges
 before dimpling too.
 However I wouldn't say the plans are wrong.  It really depends on the
 tools you are using because some of edge rollers are thicker than
 others; thus requiring more depth (from the edge) to roll correctly.
 I'll bet your edge roller runs relatively deep and that's the reason you
 were running up on your dimples.
 Good luck!  The tailcone is blast!
 Phil
		Kellym
				 Posted: Thu Jan 08, 2009 9:38 pm    Post subject: Erroneous Plans sequence on elevators |
				I understand the difference in tools.  I'm using one of these:
 http://www.averytools.com/pc-45-70-edge-rolling-tool.aspx
 It puts the bend right at the edge of the dimples, but because of the
 bump, you can't continue smoothly.
 The plans were very clear on the rudder to edge roll before dimpling, so
 I'd expect at least a bit of consistency.
  Phil
KCHD |
		tsts4
				 Posted: Fri Jan 09, 2009 10:52 am    Post subject: Re: Erroneous Plans sequence on elevators |
				Kelly,
 I'm confused here.  The plans steps you listed don't jive with mine. Why are you dimpling the leading edge rivet holes?  The rivets called out are AD-41s which don't need a dimple.
 Also the templates in the plans are full sized.  That's why the steps say cut out and glue to the foam blocks-- you'll get 2 ribs from each block.  Personally I made copies so my plans would always have the originals in case I needed to make new ones in the future.
  _________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
				 Posted: Fri Jan 09, 2009 11:17 am    Post subject: Erroneous Plans sequence on elevators |
				I think he's talking about slightly rolling the trailing edges of the
 control surface to close any gaps that might exist around the
 wedge-shaped insert.
 I don't think he's talking about the big broom-stick roll on the
 trailing edge.
		tsts4
				 Posted: Fri Jan 09, 2009 11:42 am    Post subject: Re: Erroneous Plans sequence on elevators |
				Ahhhh. My mistake--apologies.  Not the leading edge but the trailing edge. I forgot that you put a bend on that edge as well.  I seem to recall that I just went slow and it turned out fine (I have the vise grip style edge roller).
		Kelly McMullen
				 Posted: Fri Jan 09, 2009 4:45 pm    Post subject: Erroneous Plans sequence on elevators |
				Correct.
 Re the foam ribs, Copying the plans introduces a dimension change,
 because unless you change the enlargement, most copiers add 2%
 enlargement, and how does one know the originals from Van aren't a
 copy of a copy?
 On Fri, Jan 9, 2009 at 12:15 PM, Perry, Phil <Phil.Perry(at)netapp.com> wrote:
  trailing edge.
KCHD |
		tsts4
				 Posted: Fri Jan 09, 2009 6:05 pm    Post subject: Re: Erroneous Plans sequence on elevators |
				My HP all-in-one made copies exactly the same size as the plans (I checked)-- I guess I got lucky.  As to whether the plans are copies of copies, I don't know.   There's an easy way to check.  The forward end of the ribs fit in between the rear spar flanges.  Just measure the distance between the flanges and compare to the width of the rib template.  I bet it's pretty darn close.  All I can say is I followed the plans and mine fit fine, and in 5 years since the -10 was released I don't recall anyone ever posting an issue with the templates here or over at VAF.  Granted, there can always be a first time, but I wouldn't worry too much about it--build on!
