		n85ae
				 Posted: Fri Jan 09, 2009 2:36 pm    Post subject: Re: Trailering a Kitfox |
				All of which, in addition to the obvious are darned good reason to
 not tow with the wings spread.
 I was only talking about the comment about the Skystar trailer towing
 G-Meter readings. Engineering calculations are boring, by the way, that
 sounds too much like my job.
 Realistically, the average bumpy landing is more harmfull to your plane
 than towing. Not to mention landing and taxiing in a bumpy field. My
 honest opinion is that the most likely damage you'll sustain from towing,
 is if the wings get banging around. I have taxied mine across bumpy
 grassy fields, and those worry me a lot more. if you are on main roads
 you'll likely not have any sort of bumpy enough ride to damage your plane on a trailer. UNLESS it is loose, or the wings aren't supported
 or somebody runs into you. Or it gets hit by a rock.
 Half the toys I've had I've towed, from dirt bikes, to cars, and planes,
 boats and my camper, and the only damage has been from stuff getting hit by road debris.
 I worried a lot about the effects of towing mine, until I actually did it.
 The experience of hauling it behind my truck, changed everything I
 really worry about. I only worry about two things now - Some jerk hitting
 it, or my tiedowns coming loose.
 Jeff
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		msm_9949(at)yahoo.com Guest
				 Posted: Fri Jan 09, 2009 2:48 pm    Post subject: Trailering a Kitfox |
				Man, and I thought we lawyers liked to argue! I had no idea engineers were so much like lawyers . . . but with math!! How's this:
  Lots of trailering = 1 reportedly damaged airplane. Can we move on now?
  Marco Menezes N99KX
  Model 2 582-90 C-Box 3:1 w/clutch
 --- On Fri, 1/9/09, Bob Brennan <matronics(at)bob.brennan.name> wrote:
  [quote]From: Bob Brennan <matronics(at)bob.brennan.name>
 Subject: RE: Re: Trailering a Kitfox
 Date: Friday, January 9, 2009, 3:52 PM
 [quote]--> Kitfox-List message posted by: "Bob Brennan" <matronics(at)bob.brennan.name>  The Kitfox airframe, which is fabric covered metal tube, does not have a posted MTBF that I know of, probably because the airframe is designed not to flex under load. Sorry, I should have been more clear in stating that aircraft whose frames are made of metal (rather than "metal airframes" have an MTBF of parts according to the stress they are subjected to. To be even more clear - I meant airframes of almost all airline aircraft and most standard type GA aircraft such as Piper and Cessna, which rely on stressed metal monocoque skins to form the "airframe". And all such MTBF numbers are based on the metal flexing under "momentary spikes", not constant loads.  My reply is to this subject: "This is completely flawed, because these momentary spikes mean nothing."  And this although I think "Rexinator" already replied better than me: "They completely lacked the engineering brainpower to realize that load is related to force over time."  The 3 wing attach points on the Kitfox seem to be designed well for the published maximum plus and minus loads in flight, but the designers seem to have failed to design for the stresses of the unsupported wings in the trailering position, or failed to publish limits or recommendations on how to rig the wings for trailering. I'd be happy to be proved wrong on that last point and get some real numbers, but in the meantime it seems it is left to us to hash it out here and hopefully provide some rigging recommendations that work.  I know I personally have learned a lot from these discussions, but don't want to discuss "hogwash" really. I'll leave that to farmers.  Bob Brennan - N717GB ELSA Repairman, inspection rated 1991 UK Model 2 ELSA Kitfox Rotax 582 with 3 blade prop Wrightsville Pa   --
		matronics(at)bob.brennan. Guest
		n85ae
				 Posted: Fri Jan 09, 2009 2:52 pm    Post subject: Re: Trailering a Kitfox |
				 	  | Quote: | 	 		  I don't have a trailer so for me this is all really theoritical, but Denney
 built trailers that towed tail first with the tailwheel elevated, Skystar
 did the same.  |
 A good reason for this is axle location and tongue weight, when you
 design a trailer, you need to locate the axle, and this affects the tongue
 weight. To keep the tongue weight reasonable you end up with the
 axle location of the trailer pretty close to the planes cg. Considering
 you need to be able to turn as  well when towing you pretty much end
 up sketching and calculating to the point where you have a backwards
 towing rig. Which is exactly what I did. Somewhere I have an excel
 spreadsheet with all the calculations I did for the trailer in the
 previous picture.
 Jeff
				 Posted: Fri Jan 09, 2009 2:59 pm    Post subject: Trailering a Kitfox |
				All good points Jeff, except for one. You *knew* I'd find at least one
 didn't you?<g>
 With the wings out all the forces along the wings are perpendicular to the
 fuselage and concentrated on 3 connect points, which is well documented and
 presumably designed for and tested to the stated maximum loads.
 But it seems that with the wings folded and only supported by 2 of the
 attach points, now with the force-moments *parallel* to the center line of
 the fuselage - stuff can break. And worse yet it can be damaged via metal
 fatigue rather than wings snapping off during transit. These are things I
 try to do my best to understand, and avoid.
 bob
				 Posted: Fri Jan 09, 2009 3:02 pm    Post subject: Trailering a Kitfox |
				2 reported damaged airplanes Marco, so far. 1+1=2 with  math<g>
  I don't want to be number 3
  tedious bob
    From: owner-kitfox-list-server(at)matronics.com  [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Marco  Menezes
 Sent: 09 January 2009 5:47 pm
 To:  kitfox-list(at)matronics.com
        Marco Menezes N99KX
		n85ae
				 Posted: Fri Jan 09, 2009 3:07 pm    Post subject: Re: Trailering a Kitfox |
				ok, ok, ok. I Have the solution.
 A really BIG box, and styrofoam peanuts!
 Those packaging engineers aren't dummies, they invented that stuff
 for a good reason.
 Have a nice weekend.
 Jeff
		gary-n-dorothy(at)tctwest Guest
				 Posted: Fri Jan 09, 2009 4:09 pm    Post subject: Trailering a Kitfox |
				So --it seems that we need a structural engineer to design a  3 rd attachment  point/ brace to be used for transport , locating it  to the outboard end of the wing, and attaching somewhere near the rear of  the airframe, the wing forming a triangle / or a truss,  better spreading  the load to the airframe and eliminating  the "lever action" the wing  imparts to its two attach points when folded.
       I can understand  the concerns   brought up here. But believe that Sky star  designed an airplane ---not a  trailer, and I do believe that the loads imparted to the airframe over a  period of time will damage the basic airframe attach points. Chuck holes,  speed bumps,  gravel roads and freeways, trailer spring rates, all will  bring different levels of abuse,  So  I guess each of us in our own  way will have to solve their transport  problem.
        Personally,  I tow on a trailer  , tail propped up, wings close to level with the aircraft facing forward, and  the wing butts covered with a wind chock, removing it when unfolding the wings.
        The box full of Styrofoam  peanuts sounds fun  !!!  you may need a lot of help tho, cleaning  runways when unpacking. :~}
  have a good weekend
  GG
   N4276M
  [quote]   ---
		Fox5flyer Guest
				 Posted: Fri Jan 09, 2009 4:50 pm    Post subject: Trailering a Kitfox |
				Nice trailer, Jeff.  Very nice.  Ever thought about making plans for it?
 Deke Morisse
 Mikado Michigan
 S5/Subaru/CAP 402+ TT
 "The aim of an argument or discussion should not be victory, but progress."
 - Joseph Joubert
		dwight purdy
				 Posted: Sat Jan 10, 2009 5:42 am    Post subject: Trailering a Kitfox |
				I have never commented on this subject and am also tired of deleting them.
 That being said I must comment on this idea of fastening down tight. Who
 ever built my trailer made the tongue carry through too weak and it flexes a
 bunch. If you tie it down tight your plane becomes an integral part of the
 trailer. You do not want your longerons doing that! I need to beef up my
 trailer.
   Dwight Purdy
   Model II
  _________________ dwight
model II |
		pwmac(at)sisna.com Guest
				 Posted: Sat Jan 10, 2009 6:55 am    Post subject: Trailering a Kitfox |
				Replacement of the spar steel doubler would be one option. Pretty low
 tech and it puts the plane back to what it was when built.
 Examine  the  front/rear braces for any tell tale issues that would
 give a hint of plane attachment issues?
 Verify the fuge lower structure is still straight as designed.
 Consider some kind of ndt for the tail spring?
 Paul
 At 05:30 AM 1/10/2009,  Dick Maddux wrote:
  	  | Quote: | 	 		  I know we have beat this subject to death but I really would like to
 solicit an opinion on the best way to check the rear spar pivot
 point for damage. Unfortunately I had to trailer my Kitfox from just
 south of Boston to Pensacola ,Fl due to the lousy weather enroute
 when I bought it. It was towed on a tandem wheel trailer and it was
 a rough ride on the interstate due to the light weight of the
 Kitfox. The tanks were empty and the front brace bar was installed.
 I examined the rear spar pivot point visually upon arrival as I
 thought this might be a  possible weak point. It appeared to be ok
 but now with all this discussion I think I will reexamine it. Any
 good ideas on how to check it other than visual (i.e.: dye
 penetrant,etc) Any other areas to check?
                      Dick Maddux
                      Fox 4-1200
                      Pensacola Fl
		shinco(at)bright.net Guest
				 Posted: Sat Jan 10, 2009 8:35 am    Post subject: Trailering a Kitfox |
				n85ae wrote:
  for a good reason.
  Jeff
  http://forums.matronics.com/viewtopic.php?p 23774#223774
  Checked by AVG - http://www.avg.com
 NOW That is a good idea.....may be all so we could have UPS ship it for
 us.from home to airport..that way you all so would not need a tow truck
 to pull it..Steve Shinabery N554KF  KF2  St.Marys Ohio
				 Posted: Sat Jan 10, 2009 8:44 am    Post subject: Trailering a Kitfox |
  them. That being said I must comment on this idea of fastening down
  tight. Who ever built my trailer made the tongue carry through too
  weak and it flexes a bunch. If you tie it down tight your plane
  becomes an integral part of the trailer. You do not want your
  longerons doing that! I need to beef up my trailer.
   Dwight Purdy
   Model II
