Posted: Mon Jan 12, 2009 1:39 pm Post subject: D-Sub connectors |
At 01:32 PM 1/12/2009, you wrote:
See,
That's why we post here Bob, you knew that the the color bands
index to the mil-spec part, whereas when I order from Arrow or
Jameco, or Newark, I only paid attention to the Amp catalog numbers
and the tooling / App sheets. I never noticed that the MilSpec
nomenclature was even in the docs I have!
Pleased to be of service my friend.
toaster73(at)embarqmail.c Guest
Posted: Mon Jan 12, 2009 6:48 pm Post subject: D-Sub connectors |
I'll second the compliment, I have learned so much about D-subs, when I saw
the sheet metal type in mouser I kinda wondered and I can't say I have ever
seen them in an actual application. SO machined it is!
Chris
RV-10
Posted: Tue Jan 13, 2009 7:10 am Post subject: D-Sub connectors |
At 08:43 PM 1/12/2009, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Chris" <toaster73(at)embarqmail.com>
I'll second the compliment, I have learned so much about D-subs, when I saw the sheet metal type in mouser I kinda wondered and I can't say I have ever seen them in an actual application. SO machined it is! |
Probably every d-sub connector in your computer
system is populated with the sheet metal pins.
These are most often supplied in very long strips
and coiled onto reels for application by automatic
machines. ASSUMING you have the manufacturing
environment to install these pins, they'll perform
as advertised.
We should also be mindful that just because a
pin is not machined from solid materials doesn't
place it lower in the connector food chain.
AMP MulitMate series of pins are an excellent
example of high-performance products manufactured
from sheet stock and well suited for high volume
production.
[img]cid:.0[/img]
( -Thomas Paine 1776- )
107.69 KB |
507 Time(s) |
kesleyelectric(at)chooseb Guest
Posted: Tue Jan 13, 2009 9:15 am Post subject: D-Sub connectors |
I have noticed that a few of your replies concerning D-sub connectors have a
reference to Emacs!. I'm not familiar with that. What is it?
Tom Barter
Kesley,Iowa
Avid Magnum - wiring
Posted: Tue Jan 13, 2009 12:40 pm Post subject: D-Sub connectors |
At 11:11 AM 1/13/2009, you wrote:
<kesleyelectric(at)chooseblue.coop>
Probably an artifact of typos and/or cut-n-paste
activity. Ignore it.
rampil
Posted: Tue Jan 13, 2009 2:55 pm Post subject: Re: D-Sub connectors |
Hi All,
Through a circuitous route (that's a double E pun) I found this web
page which not only illustrates the connector pin color code
that Bob explained, but also adds includes a table of which positioner
to use for the crimp:
http://www.pinsandsockets.nl/bin.htm
I'm not an Engineer, I just played one in Grad School
