AirMike
Posted: Tue Jan 13, 2009 6:08 pm Post subject: Lower Cowling attachment |
Another builder and myself are approaching the point of installing the engine. We want to install the cowl flanges and hinges first. We are aware of the issue with the eyelets on the hinges breaking on the bottom of the cowl, so we have both decided to use a flange/screw and nut-plate arrangement.
The question is this.... In a recent post someone mentioned that they used .063 aluminum plate to support the bottom of the cowling. That is awfully heavy metal, but maybe that is what is called for in this location.
I also see that Deems has used some kind of aluminum flange with 3 nut-plates on each side. I also think that Tim Olsen did not use the hinge on the bottom of the cowl. But I cannot see the pic on his site.
If anyone (or hopefully several) of you can give some insight here it would be graciously appreciated
_________________ See you OSH '18
Q/B - sold. |
Tim Olson
Posted: Tue Jan 13, 2009 6:25 pm Post subject: Lower Cowling attachment |
Hi Mike,
I have hinge stuff on these pages:
http://www.myrv10.com/N104CD/fuselage/20050821/index.html
http://www.myrv10.com/N104CD/finishing/20050905/index.html
http://www.myrv10.com/N104CD/finishing/20050911/index.html
I don't think that .063 is needed for greater support. Basically,
depending on how you attach everything, and what your actual cowl
thicknesses are, you're just trying to find a thickness of metal
that allows you to get the cowl to fit flush to the bottom of the
fuselage. In my case I can't remember what I used, but it added
up to some thicker material. I didn't use any shims, if I
remember right...just that material, and I attached some metal
to the cowl and metal to the plane. It really all just depends
on how you want to make it. Just make it come out so the cowl
is flush, and you have a few screws holding it all instead of
hinges with eyelets and you'll be fine.
AirMike wrote:
this location.
site.
-------- OSH '08 or Bust (busted) be there in "09 Q/B Kit -
wiring and FWF
http://forums.matronics.com/viewtopic.php?p 24639#224639
Jim Berry
Posted: Tue Jan 13, 2009 6:32 pm Post subject: Re: Lower Cowling attachment |
The original hinge material was 0.063". Using a flange of the same thickness makes it easier to maintain cowl to fuselage alignment.
Jim Berry
40482
Dave(at)AirCraftersLLC.co Guest
Posted: Tue Jan 13, 2009 8:48 pm Post subject: Lower Cowling attachment |
Mike,
I replaced my broken hinges with .063 sheet of the same dimensions as the
two hinge halves pinned together, about 2" x 6". The sheet is riveted to
the horizontal return at the bottom of the firewall, exactly like the hinge
was. I have three nutplates in the sheet to support the aft end of the
cowl. The hinge half on the cowl was removed, and now the cowl screws
directly to the sheet.
The hinges cracked out at about 50 hours. We've got 306 hours as of today
and the new attach is working fine.
Soon after the hinges went away, the vertical center support also cracked.
That got duplicated in .063 (I think it was originally .032). So far so
good with that one too.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
planesmith(at)hotmail.com Guest
Posted: Tue Jan 13, 2009 9:14 pm Post subject: Lower Cowling attachment |
Hi Mike C
I did the same as been echoed by others. There are some pictures and info at the bottom of my blog: http://www.aviationstop.com/
Vern Smith (#324 finishing)
[quote] Subject: Lower Cowling attachment
Date: Tue C 13 Jan 2009 18:08:46 -0800
--> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net>
Another builder and myself are approaching the point of installing the engine. We want to install the cowl flanges and hinges first. We are aware of the issue with the eyelets on the hinges breaking on the bottom of the cowl C so we have both decided to use a flange/screw and nut-plate arrangement.
The question is this.... In a recent post someone mentioned that they used .063 aluminum plate to support the bottom of the cowling. That is awfully heavy metal C but maybe that is what is called for in this location.
Q/B Kit - wiring and FWF
http://forums.matronics.com/viewtopic.php?p=224639#224639
========================Windows Live™: Keep your life in sync. See how it works.
AirMike
