		Tom463(at)aol.com Guest
				 Posted: Thu Jan 15, 2009 5:30 am    Post subject: RotaxEngines-List Digest: 16 Msgs - 01/14/09 |
				Perhaps I didn't explain the issue correctly; I'm not talking about  temperature or moisture having an effect on the paper fuel filters. I would like  to know if anyone has had an issue with Ethanol enhanced fuel causing the paper  filters to become partially or totally clogged.
  Tom
  N569AT
 A Good Credit Score is 1201028747/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=DecemailfooterNO62"> See yours in just 2 easy steps!
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		tooch(at)hughes.net Guest
				 Posted: Thu Jan 15, 2009 6:00 am    Post subject: RotaxEngines-List Digest: 16 Msgs - 01/14/09 |
				A few years back at a Rotax seminar conducted by Phil Lockwood we were told never to use a paper filter. The reason was that if you have bad fuel, the paper filter will clog up and stop the fuel flow completely whereas the screen filter will still let enough through to keep your engine running. You can buy these filters at Napa part # 740-1155. They are clear and have one screen in them.
 From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Tom463(at)aol.com
  Sent: Thursday, January 15, 2009 8:28 AM
  To: rotaxengines-list(at)matronics.com
  Subject: Re: RotaxEngines-List Digest: 16 Msgs - 01/14/09
 Tom
 N569AT
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RotaxEngines-List  | 	  0123456789
		rampil
				 Posted: Thu Jan 15, 2009 7:15 am    Post subject: Re: RotaxEngines-List Digest: 16 Msgs - 01/14/09 |
				I concur.
 I also have heard Phil and Dean say to stay away from paper element
 filters. This was based on field experience with failures.
 Switch to plastic mesh filters.
 Consider it an AD.
		Float Flyr
				 Posted: Thu Jan 15, 2009 7:39 am    Post subject: RotaxEngines-List Digest: 16 Msgs - 01/14/09 |
				I doubt the paper filters will have any issues with paper filters except if you are premixing your fuel and you have a phase separation at which time the engine will stop filter or not!  With oil in the gas when a phase separation occurs it forms a heavy mass of off white to tan coloured sludge which I doubt you could pass through a fine screen let alone a paper filter.
 Water will pass through paper filters no problem... At least it does on cars and trucks not to mention my coffee maker.  Water has a very hard time passing through felt or chamois while gas passes right through it...  Use a good felt cloth or Chamois to filter all your fuel.  BTW it is suggested to pre-wet a chamois with gasoline before using it to filter water out of the gas.
 Noel
  Sent: Thursday, January 15, 2009 9:58 AM
 Tom
 N569AT
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		b.carl@sympatico.ca
				 Posted: Sat Jan 17, 2009 3:17 pm    Post subject: RotaxEngines-List Digest: 16 Msgs - 01/14/09 |
				Tom.
  Been using car type metal\paper filters since 1995, ethanol blend for at  least 5 years. I change them yearly and cut them open for inspection. The old  filters are like new except for a slight discolouring of the paper element.  Never found any foreign matter or deterioration. Since using ethanol I never get  even a drop of water from my drains. I believe the ethanol absorbs any small  amount of condensation inside the system.
  Yearly inspection of the carbs is also pristine.
  As someone has mentioned on the list, water will go through a paper filter.  I had the experience in my pickup when the filler tube rusted and it took a  while to locate the hole under a protective rubber sleeve. I removed a fair bit  of water  from the carb before I found the problem and yes the  filter did start to breakdown after a couple of weeks of contact with  water. Lesson if you find water in your system, change the filters and clean out  the carbs,  lines and tanks
  Carl
