egohr1
Joined: 17 Jan 2006 Posts: 38 Location: Oklahoma City
Posted: Fri Jan 16, 2009 4:15 am Post subject: Vans Manifold pressure fitting replacement |
FYI.
McMaster carr part number 5058K243 ALUMINUM SINGLE-BARBED TUBE FITTINGS, ADAPTER FOR 1/4" TUBE ID X 10-32 UNF MALE, BLUE
This will replace the nylon fitting sent with vans FWF kit for connection to a AFS or other system.
_________________ eric gohr
EGOHR86@alumni.carnegiemellon.edu |
Posted: Mon Jan 19, 2009 10:52 am Post subject: Vans Manifold pressure fitting replacement |
What is wrong with the nylon one van's sends?? Doesn't work with AFS or is it just the material it is made of.
John G
Posted: Mon Jan 19, 2009 11:11 am Post subject: Vans Manifold pressure fitting replacement |
Hose barb on the. Afs sensor is 1/4 inch vans is 1/8
Sent via BlackBerry by AT&T
Date: Mon, 19 Jan 2009 10:51:37 -0800
To: RV 10 group<rv10-list(at)matronics.com>
Subject: RE: RV10-List: Vans Manifold pressure fitting replacement
What is wrong with the nylon one van's sends?? Doesn't work with AFS or is = it just the material it is made of.
 =3B
John G
>=3B Subject: RV10-List: Vans Manifold pressure fitting rep= lacement
>=3B From: EGOHR86(at)alumni.carnegiemellon.edu
>=3B Date: = Fri=2C 16 Jan 2009 04:15:22 -0800
>=3B To: rv10-list(at)matronics.com
= >=3B
>=3B -->=3B RV10-List message posted by: "egohr1" <=3BEGOH= R86(at)alumni.carnegiemellon.edu>=3B
>=3B
>=3B FYI.
>=3B Mc= Master carr part number 5058K243 ALUMINUM SINGLE-BARBED TUBE FITTINGS=2C AD= APTER FOR 1/4" TUBE ID X 10-32 UNF MALE=2C BLUE
>=3B
>=3B This w= ill replace the nylon fitting sent with vans FWF kit for connection to a AF= S or other system.
>=3B
>=3B --------
>=3B eric gohr
>= =3B EGOHR86(at)alumni.carnegiemellon.edu
>=3B
>=3B
>=3B
&= gt=3B
>=3B Read this topic online here:
>=3B
>=3B http://f= orums.matronics.com/viewtopic.php?p=3D225053#225053
>=3B
>=3B >= =3D=3D
>=3B
>=3B
>=3B
= | Quote: | | _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - The RV10-List Email Forum - _-=3D Use the Matronics List Features Navigator to browse _-=3D the many List utilities such as List Un/Subscription, _-=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, _-=3D Photoshare, and much much more: _-=3D _-=3D --> http://www.matronics.com/Navigator?RV10-List _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - MATRONICS WEB FORUMS - _-=3D Same great content also available via the Web Forums! _-=3D _-=3D --> http://forums.matronics.com _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - List Contribution Web Site - _-=3D Thank you for your generous support! _-=3D -Matt Dralle, List Admin. _-=3D --> http://www.matronics.com/contribution _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D |
indigoonlatigo(at)MSN.COM Guest
Posted: Mon Jan 19, 2009 11:35 am Post subject: Vans Manifold pressure fitting replacement |
Thanks C I'll order this now and I should need it in a few days. Really appreciate it!!!
John
Subject: Re: Vans Manifold pressure fitting replacement
Date: Mon C 19 Jan 2009 19:09:27 +0000
.ExternalClass .EC_hmmessage P {;} .ExternalClass body.EC_hmmessage {font-size:10pt=3B font-family:Verdana;} Hose barb on the. Afs sensor is 1/4 inch vans is 1/8
Date: Mon C 19 Jan 2009 10:51:37 -0800
Subject: RE: Vans Manifold pressure fitting replacement
=3B
John G
| Quote: | =3B -->=3B RV10-List message posted by: "egohr1" <=3BEGOH= R86(at)alumni.carnegiemellon.edu>=3B
=3B
=3B FYI.
=3B
=3B
=3B --------
=3B eric gohr
=3B
=3B
=3B
&= gt=3B
| Quote: | =3B Read this topic online here:
=3B
=3B
=3B
= =3D=3D
=3B
=3B
=3B
= ¦·›~‰í² CÞÙÊ%¢½4ÓM4}§r‹«‰êç{(º¸ž8^E]t.+-f¢”Z+ºe CzØ^1«k¢xœ°¸¬´Wš¶êÞ°Ö¯Š¢»hnº0±ëazf§È¸¬¶ëb–+bzË.r¬.+-RÒ¹»®*mЉÀÈb½äžj·!Œ'–†�ì6²º0±à¡jÑ(at)(at)øh¶‹!j·š�Ù®r®r¨æ¡çá¶Úÿ 0™«k¢xœ±Ê&ü֝Т´U×Bâ²Øm¶Ÿÿà &jÚèž' Cr‰¿5«â�«huи¬·öŒ4N4€’X(at)E9 I&¦z Þj×(ž×§µ©l¡«ÚŠV›•ëâjØ^YæÅ¢»¦±¨kyøm¶Ÿÿ~ŠîšÉš¶º'‰Ë¢hm¶Ÿÿ~ŠîšÉš¶º'‰Ë¢oÚ.+- ‰í®&î¶*'YæÒŠ×“…©äÊ‹Ÿ¢¼¨º¸�êèºË.¦š+´Æ´:Ú–W‹ŠË(at)vh§jÞ~m§ÿðà š¶º'‰Ë¢oÜ¢{k‰»Š‰á¶Úÿ 0™«k¢xœ±Ê&ýÊ'¶¸›ºØ¨Ÿö¿o÷èžßéïÛ¡Ü¿†Ù¥ [quote][b]
