Starter Motor Earth Cable
ianwilson2
PostPosted: Wed Jan 21, 2009 2:15 am    Post subject: Starter Motor Earth Cable Reply with quote
Has anyone seem/implemented Jabiru's JSL 005-1 about adding an earth cable from the back of the starter body? I don't really want to add another heavyish cable to the front end if it's not going to make much difference, so I'd welocme the groups experience as to whether this is a change that makes any difference!
Many thanks.
Ian Wilson
Lynn Matteson
PostPosted: Wed Jan 21, 2009 3:52 am    Post subject: Starter Motor Earth Cable Reply with quote
I did it...I didn't NEED to do it, but I did it anyway, just to be
safe. I used 2 braided and tinned copper straps about 1/2" wide,
attached terminals on both ends, and installed. I'd never had a
starting problem before but just wanted to be sure...and I was
running out of things to fiddle with. : )
Lynn Matteson
Jabiru 2200, #2062, 600.2 hrs
Sensenich 62x46
New skis done and flying
On Jan 21, 2009, at 5:15 AM, ianwilson2 wrote:
<ianwilson2(at)hotmail.com>
Many thanks.
Ian Wilson
http://forums.matronics.com/viewtopic.php?p 25965#225965
Lynn
Kitfox IV-Jabiru 2200
N369LM
jcrowder(at)lpbroadband.n
PostPosted: Wed Jan 21, 2009 11:26 am    Post subject: Starter Motor Earth Cable Reply with quote
I am currently Installing a 3300 on my Kitfox 5. I just installed the
engine ground cable at that point on the starter instead of on the engine
block. My thinking is that that is where the greatest current demand
occurs. I guess I will see how that works out.
Jim Crowder
[quote] --
Peter H
PostPosted: Wed Jan 21, 2009 4:11 pm    Post subject: Starter Motor Earth Cable Reply with quote
Ian,
I reported 18 months ago that the two assembly bolts which clamp and retain
the starter were getting hot. The earth return is by means of these two
bolts but they are set in Loctite and there is a voltage drop because of
high resistance.
I fitted a separate earth strap and got better performancxe from the
starter.
Peter
ianwilson2
PostPosted: Thu Jan 22, 2009 1:34 am    Post subject: Re: Starter Motor Earth Cable Reply with quote
Thanks Lynn, Jim and Peter for the information. Lynn, I can't see that you will ever run out of things to fiddle with Smile
OK, so given that I need to add a strap to the starter, how do I get the bolts off without shearing them? I'm in contact with another builder of the same plane as me and he's just done this on his 2200. He tried heating the bolts to loosen the Loctite, but the bolts still sheared. Now, not only does he have to find some new bolts, he also has to take the casting to a specialist shop for them to remove the broken bolts.
Any ideas?
Again, many thanks for your responses.
Ian
dhonabach
PostPosted: Thu Jan 22, 2009 8:16 am    Post subject: Starter Motor Earth Cable Reply with quote
Maybe I just got lucky, but in moving the ground wire for the starter, I
didn't have any problems with the bolt and shearing, etc.
I'd also recommend moving the ground wire or adding the strap for the
starter. I was actually having issues with mine and moving the ground
wire resolved the issue.
Don
