		jeff(at)rmmm.net Guest
				 Posted: Wed Jan 21, 2009 3:07 pm    Post subject: Induction Air |
				Hi All,
 While I have Gold Rush in for the winter annual I'm considering some
 cowl changes. Including closing off the upper NACA use for induction
 air on the 912-S and using the lower starboard NACA normally used for
 the 914 induction. I seem to remember someone else using that for carb
 intake and under cowl carb heat. I'm going to use the same air plenum
 with the same filter as now but I will fabricate a side intake to
 attach to the top of the plenum and a 2 inch scat tube coming up from
 the below NACA. My question is this. I already have the inlet plumed
 for this 2 inch tube and not a lot of room to increase it to 3 inch. My
 concerns is if the 2 inch would be enough for both carbs. Has anyone
 else done this with the 912-S and if so what size of tube did you use?
 Best Regards,
 Jeff R.
 A258 - N128LJ / Gold Rush 175 hours and climbing slowly cause this
 winter if frickin could & wet for Tennessee ;o(. Must be al's global
 warming!
		topglock(at)cox.net Guest
				 Posted: Wed Jan 21, 2009 3:22 pm    Post subject: Induction Air |
				Jeff,
 It's square inches, my friend.  Get out the old pi r squared and figure
 the square inches in the duct cross section.  Then compare that to the
 square inches of the inlet opening.
 Jeff
 JEFF ROBERTS wrote:
  	  | Quote: | 	 		   Hi All,
  cowl changes. Including closing off the upper NACA use for induction air
  on the 912-S and using the lower starboard NACA normally used for the
  with the same filter as now but I will fabricate a side intake to attach
  to the top of the plenum and a 2 inch scat tube coming up from the below
  NACA. My question is this. I already have the inlet plumed for this 2
  inch tube and not a lot of room to increase it to 3 inch. My concerns is
  if the 2 inch would be enough for both carbs. Has anyone else done this
  Best Regards,
  Jeff R.
  warming!
  size  color="#000000" face="courier new,courier">
  href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
  Checked by AVG - http://www.avg.com
		cptimm(at)telus.net Guest
				 Posted: Wed Jan 21, 2009 3:53 pm    Post subject: Induction Air |
				Hi Jeff,
  I modified my Classic cowling early on, with a  starboard NACA inlet on the lower cowling, and started out with a 2" scat  tube
  to the plenum chamber. This turned out to be too  small for the 912S, and it became necessary to enlarge the inlet to  3".
  It enabled me ,however, with a home-made 3" to 2" Y  , to also supply air to 2 ball vents in the cockpit, as well as making the  engine happy.
  Peter Timm
  # ll0, Classic mono, 912S, 380 hrs
  [quote]   ---
		air.guerner(at)orange.fr Guest
				 Posted: Thu Jan 22, 2009 4:26 am    Post subject: Induction Air |
				Hi Jeff,
  I am using the optional Rotax airbox on my 912ULS.  The inlets of the airbox are designed for 60 millimeters diameter SCAT, one for  cold air and one for preheated air. I suppose Rotax have determined  that this diameter was necessary. On my installation, cold air is suplied by a  NACA on the left side of the cowl. You can see a picture of the cowl in my album  http://www.europaowners.org/modules.php?set_albumName=album196&op=modload&name=gallery&file=index&include=view_album.php
  I am very satisfied with this installation which  allows straightforward controllable carb heat. However there is one  inconvenience worth to mention: I consistently see induction air temperature  (measured inside the airbox) which is 6 degrees Celsius higher than OAT. This is  due to the length of SCAT ducting between the NACA intake, the filter box and  the aluminum airbox, all that stuff  being heated by the hot air inside the  cowl. Those 6 degrees may reduce power by up to 2%. The Europa XS airbox is  better on this point of view, as it takes the air directly from above and  induction temperature probably equals OAT.
  Remi Guerner
  F-PGKL
  Induction Air
 Hi All,
 Best Regards,
 Jeff R.
