		EMAproducts(at)aol.com Guest
				 Posted: Sat Jan 24, 2009 9:03 am    Post subject: Short Wing Pipers |
				Short wing Pipers death traps??
  I think all should fly a few hundred in aircraft before they bad mouth  them.  I flew the Colt (2 place Tri-Pacer no flaps) for 600 hours when I  started instructing, along with T-Crafts Tri-Pacers and all of the other typical  aircraft of the day  1962.  The majority of the Piper PA-20's (Pacer)  are converted to PA-22 (Tri Pacer)  I have a parts manual and it is a PA  20-22 parts manual, the ONLY difference is the gear location.  I still say  the Tri-Pacer is one of the most under estimated aircraft around and one of the  better buys, they might not look sexy but they will do what is asked of  them.  Good plane!  $ for $ it will haul more faster with less  maintenance than nearly any airplane made.
  Elbie 25,000 hours still instructing  EAA 38308
  EM Aviation, LLC www.riteangle.com
  A Good Credit Score is 700 or Above.  See yours in just 2 easy steps!
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Sun Jan 25, 2009 8:52 am    Post subject: short wing pipers |
				Whoops my fingers didn't do what my brain said  PA-22's are  converted to PA-20's
  Elbie  Mendenhall, EM Aviation, LLC
  From Wall Street to Main Street and everywhere in between, stay up-to-date with the [url=http://aol.com?ncid=emlcntaolcom00000023 ]latest news[/url].
		Paul A. Franz, P.E.
				 Posted: Sun Jan 25, 2009 9:17 am    Post subject: short wing pipers |
				On Sun, January 25, 2009 8:50 am, EMAproducts(at)aol.com wrote:
  PA-20's
 What I learned here is that there are STC's for conversion of PA-20's to PA-22's. I
 was unaware of the early PA-20 version. So apparently conversions have been done and
 there are STC's for both tricycle <==> conventional swaps.
 Paul A. Franz
 Registration/Aircraft - N14UW/Merlin GT
 Engine/Prop - Rotax 914/NSI CAP
 Bellevue WA
 425.241.1618 Cell
  _________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
		larry huntley
				 Posted: Sun Jan 25, 2009 10:13 am    Post subject: short wing pipers |
				You're all right Elbie. I noticed earlier that I had said they brought out  the PA-22 Pacer instead of PA20 pacer.
    You show up everywhere!   Larry Huntley  B75L
  [quote]   ---
  _________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
		crazyivan
				 Posted: Sun Jan 25, 2009 12:52 pm    Post subject: Re: Short Wing Pipers |
				You're right.  It isn't a death trap.  Look up the NTSB database.  The "deathtrap" reputation came from the fact that some Pacers had their wings break off.  They identified this as a problem a long time ago and found that the wing struts were rusting and failing.  Since then an AD was issued and they came out with sealed struts and stronger attachment forks.  The only Pacers that lost their wings over the past 20 years were those that didn't comply with the AD.  There was one where the spar cracked off but that was due to shoddy extensive maintenance by the owner (non A&P).
  _________________ Dave
Piper PA-22/20 |
		ruebd(at)skymail.csus.edu Guest
				 Posted: Tue Jan 27, 2009 8:07 am    Post subject: Short Wing Pipers |
				My first solo was in a Piper Colt off of a grass strip.  I later purchased a Tri-Pacer which I owned for 15 years.  I share your opinion of those craft, and have a lot of respect for them.  The Tri-Pacer that I had was a 1957 with 150 hp, and would cruise (at) 135 mph carrying more than a 172 at a higher speed.
 These airplanes are tough and good, and are generally under rated for sure.  In fact the Tri-Pacer out performed Piper’s immediate replacement model, the Cherokee 140.  Mine had the 8 gallon aux tank, and I once flew it nonstop from Phoenix Field, near Sacramento  California to Redmond Oregon.  I now can hardly believe that I did this without noise cancelling headset, in fact without headset at all!
 Duane Rueb, N24ZM
 From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of EMAproducts(at)aol.com
  Sent: Saturday, January 24, 2009 8:58 AM
  Subject: re:Short Wing Pipers
 A Good Credit Score is 700 or Above. See yours in just 2 easy steps!   	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Kitfox-List  | 	  0123456789
