rampil
Posted: Sun Jan 25, 2009 7:32 am Post subject: Rotax Preheat update pleae |
Hi Guys,
Its been two years since preheaters have been discussed here.
Paul, Are you still happy with the Reiff?
Anybody else happy or unhappy?
Any new data on the JC Whitney variant?? Has someone found
an auto parts equivalent to the oil tank band heater and its thermostat??
It's 16F here today (brrrrrrrr, shiverrrrrrr) but bright VFR
paul.the.aviator(at)gmail Guest
Posted: Sun Jan 25, 2009 1:40 pm Post subject: Rotax Preheat update pleae |
Hi Ira,
The Reiff is working fine for me. He sells two variations for the
Rotax. One heats the engine block, oil tank and the coolant. The
other model, which I purchased is minus the coolant heater.
When the unit arrived I realized it was something that probably could
be fabricated easily by purchasing a couple of the small heating pads
from an auto parts store and putting one on the engine and one on the
oil tank. The Reiff heater does have thermostat for the oil tank, so
you would have to fabricate this as well.
BTW, Reiff did confirm that the cement for the pads is JB Weld
Paul
Posted: Sun Jan 25, 2009 1:42 pm Post subject: Rotax Preheat update pleae |
BTW, it has just struggled up to 12F here. I have been at the hanger
working on removing my engine, and although its heated, it was just
too darn cold to work.
Ira N224XS
craigb(at)onthenet.com.au Guest
Posted: Sun Jan 25, 2009 2:55 pm Post subject: Rotax Preheat update pleae |
16f hu, one thing, good performance at that temp, if you can get it warmed
up
air.guerner(at)orange.fr Guest
Posted: Mon Jan 26, 2009 2:48 am Post subject: Rotax Preheat update pleae |
For those having the optional Rotax air guide around the cylinders and the third round air intake in the cowling as specified by Europa for the 912S, one solution is to preheat with an hair dryer plugged into the air intake. I have been doing that for two years and it works really great. With a 2000 Watt hair dryer, CHT and oil temp probes both show a 1 degree Celsius (about 2 F) per minute increase. The whole engine block is being heated by the hot air forced around the cylinders. However the oil tank itself is only slightly heated by the warm air inside the cowling. Using this preheat process the engine starts like in summer all the time.
Remi Guerner
F-PGKL
Hi Guys,
Ira N224XS
rampil
Posted: Mon Jan 26, 2009 6:01 am Post subject: Re: Rotax Preheat update pleae |
Hi Guys,
Thank you all for the feedback!!!
I have been doing some searching around and found that the
Reiff block heating element is apparently the "Kat's Universal Silicone
Hot pad". These are widely available in the US for about $20 (Amazon,
Napa Auto, Autozone, but not Pep Boys).
I am still looking for a band type element for the oil tank, although
another possibility is to us a 25-50 watt Kat's hot pad on the oil tank
since the pads are flexible down to 1" radius. (no compound curves)
I am also looking for thermostatic elements that can be mounted inline
on the 120VAC and attached to the block and tank.
I take it from the absence of comments that the block pad's location
just above the muffler's aluminum heat shield is not an issue.
rampil
Posted: Mon Jan 26, 2009 6:27 am Post subject: Universal Silicone Hot Pads Update |
Greetings All,
I just found an (the?) OEM for the heating pads
www.minco.com
They have an excellent engineering guide at:
http://www.minco.com/uploadedFiles/Products/HDG01_KL6_final.pdf
BTW: The silicone pads have an upper temperature rating of 455F
and can be affixed with many different adhesives including RTV#6
and Epoxy (JB Weld)
Minco also carries small thermostat elements as well
