aslsa.rng(at)gmail.com Guest
Posted: Thu Jan 22, 2009 2:24 pm Post subject: HKS readings for the day |
OAT 65RPM 5050 to 5400 (cruise)
CHT L 270/275 R 286/290
EGT L 1240/1254 R 1220/1230
Oil temp 150
fuel used 3 gallons
flt time 1.5 hours
Rick
Posted: Thu Jan 22, 2009 3:24 pm Post subject: HKS readings for the day |
What kind of aircraft?
Load?
Prop?
Cruise speed?
Looking at your info leads me to believe you were just loafing along. The engine is red lined at 6200 rpm. Normal cruise is 5800 rpm.
Oil temp is not hot enough to cook off condensation.
I can get 2.5 gph at 4000 rpm which gives me 65 mph with a fat mkIII loaded down with camping gear and 150 lbs of fuel. However, that is too slow to get the oil to the 190F to burn off condensation. I'd rather fly 5000 rpm, 85 mph, and burn 5 gph. My oil temp stays up around 210 to 230F.
Been wanting to fly but still trying to get over a "bug" for three weeks now, and it has been down right too cold and windy here for fun flying. I am saving lots of gas money though. Gonna need it come next Spring.
See ya'll at MV2009!
[quote]OAT 65 RPM 5050 to 5400 (cruise)
Oil temp 150
fuel used 3 gallons
flt time 1.5 hours
Rick
_________________ John Hauck
Titus, Alabama |
Posted: Thu Jan 22, 2009 4:14 pm Post subject: HKS readings for the day |
Northwing trikejust me
Powerfin 4 blade "F" 68" set for 6100 RPM climb
55 mph GPS average
Oil temp is measured after the cooler and tank, never gets above 185 in the summer. HFT laser thermometer measured hot side at 210 last summer so figure the reading is 25 degrees lower on the cold side.
Put a pan of water on the stove, raise temp to 180, it still evaporates away, just slower. I change oil at 50 hours, use full synthetic and cut open my filters for inspection, never seen any sludge on oil tank cap, in oil after a drain, or in the little viewing line that runs up the side of the tank.
Anything above 5400 RPM in cruise means I have to fight to keep from climbing. All I get for the effort is sore arms and a bigger fuel burn. I don't like giving Big Oil my money any more than I have to.
Report is mainly for Larry C. as he's fighting high CHT's. I know others who have the same problem, so I posted to group.
Rick
On Thu, Jan 22, 2009 at 5:23 PM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
| Quote: | What kind of aircraft?
Load?
Prop?
Cruise speed?
| Quote: | OAT 65 RPM 5050 to 5400 (cruise)
Oil temp 150
fuel used 3 gallons
flt time 1.5 hours
Rick
| ==== get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution [/b] |
Posted: Thu Jan 22, 2009 4:28 pm Post subject: HKS readings for the day |
That won't help Larry a whole lot because, if I understand correctly, he is operating his HKS at 5800 rpm cruise. It is working a lot harder at 5800 and generating a lot more heat.
912's measure engine oil temp in the oil pump after the cooler. Rotax wants 912's to get at least 190F. If I don't, I'll have a milky looking goop on the under side of the oil tank cap.
[quote] Anything above 5400 RPM in cruise means I have to fight to keep from climbing. All I get for the effort is sore arms and a bigger fuel burn. I don't like giving Big Oil my money any more than I have to.
Rick
Titus, Alabama |
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Thu Jan 22, 2009 6:59 pm Post subject: Re: HKS readings for the day |
| John Hauck wrote: | That won't help Larry a whole lot because, if I understand correctly, he is operating his HKS at 5800 rpm cruise. It is working a lot harder at 5800 and generating a lot more heat.
I freaked a bit the first time I saw the milky stuff syndrome on my oil cap too as a new 912 driver. I was looking all over for coolant getting into the oil, etc., until a friend of mine told me it was a symptom from the oil not getting hot enough for a long enough time.
I have the oil thermostat on mine and when it's really cold out I still have to run the motor hard to get the temps to at least 180.
There have been days cold enough that the temps couldn't hit 180, so I landed and called it quits. Too cold on the oil is hard on the engines according to rotax.....
LS
_________________ LS
Titan II SS |
Posted: Thu Jan 22, 2009 7:39 pm Post subject: HKS readings for the day |
| Quote: | I have the oil thermostat on mine and when it's really cold out I still
LS
Lucien:
I looked at thermostats, but never could come around to install all that
extra plumbing. John W had a thermostat on his 912S for a while, but
removed it because it was not that efficient. He went back to manually
blocking off the radiator to bring up CHT and eng oil temp. I do the same
thing. My eng oil cooler is piggy backed on the radiator. By taping the
area of the radiator that extends beyond each side of the oil cooler, I can
bring CHT and eng oil temps up where they belong. The 912UL and 912ULS both
run much better when CHT is kept up and above 180F.
I don't think eng oil temps below 190 are hard on the engine. I use 4W40
Shell Rotella full syn. It flows well hot and cold. The crankcase and oil
tank will become contanminated with condensation if run too long below 190.
The minimum of 120F before going full power is to keep eng oil pressure
below the max which I can not remember now. Had to look it up: 101.5 psi.
When I was flying with the 912UL, I bypassed the oil cooler in the winter,
then hooked it back up in the summer. Can't do that with the 912ULS, it
runs much warmer than the 80 horse.
Titus, Alabama |
zeprep251(at)aol.com Guest
Posted: Fri Jan 23, 2009 5:35 am Post subject: HKS readings for the day |
The oil temp with cooler equipped engines need adjustable air supplies.Fooling with taping off the front of the cooler is hit and miss.Does anyone have a simple, reliable system yet?(this is submitted for a friend with a 912S in a Savannah)
Posted: Fri Jan 23, 2009 5:49 am Post subject: HKS readings for the day |
Instead of blocking off the front of the radiator, has anyone tried making a set of shutters- like they used to use on old diesel trucks? Simple to make, and could be either cable controlled or by a thermostat. Same problem, same solution.
Bill Sullivan
Windsor Locks, Ct.
Posted: Fri Jan 23, 2009 6:07 am Post subject: HKS readings for the day |
Date: Fri, 23 Jan 2009 08:34:36 -0500
zeprep251,
I have had a radiator shutter on the FireFly for several years and it works
very well. I see no reason why the same scheme cannot be applied to an oil
cooler It can be seen at:
http://www.thirdshift.com/jack/firefly/firefly123.html
http://www.thirdshift.com/jack/firefly/firefly67f.html
http://www.thirdshift.com/jack/firefly/firefly76.html
Jack B. Hart FF004
Winchester, IN
Posted: Fri Jan 23, 2009 6:47 am Post subject: HKS readings for the day |
Jack,
As usual, very innovative, and a real nice job. I do have a question for you, though. You made a reference to weights, and they seem confusing to me. You mention the unit weighs .9 oz. Or, a part weighs .2 oz.
These sure seem light!! Did you mean 9 oz, and 2 oz., etc?
Also, does your coolant system have a built-in thermostat?
Mike Welch
MkIII
Windows Live™: E-mail. Chat. Share. Get more ways to connect.
http://windowslive.com/howitworks?ocid=TXT_TAGLM_WL_t2_allup_howitworks_012009
Posted: Fri Jan 23, 2009 7:10 am Post subject: HKS readings for the day |
Well, I have to disagree on that one.
John Williamson and I have more than 4,000 hours flying the 912UL and 912ULS in my mkIII and his Kolbra. Our system works great. Usually, a couple wraps of tape when the cold temps of winter arrive is all it takes. It is not a daily chore.
My philosophy of flying is "keep it simple". The less "stuff" I have to contend with on my aircraft and the less "stuff" I have to do, the better off I am aviating.
Like I shared with you all yesterday, reducing the size of the coolant radiator takes care of increasing CHT, which makes the 912 run better, and also brings up engine oil temp. The 912 is primarily an oil cooled engine. The heads are oil and water cooled. The cylinders are air cooled. No need to block the oil cooler.
mkIII - Might get to exercise the mkIII this afternoon. Weather if looking good.
Titus, Alabama |
ulflyer(at)verizon.net Guest
Posted: Fri Jan 23, 2009 7:34 am Post subject: HKS readings for the day |
Way back a long, long, time ago when I was flying Piper Cherokee's I
recall that when winter came on they would install a winterization
plate which reduced the airflow to the oil cooler. You might have to
do the same thing with your 912's and HKS engines to keep the oil
temps high enough during cold weather months.
jerb
At 08:59 PM 1/22/2009, you wrote:
> john h
> mkIII
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p 26279#226279
lucien
Posted: Fri Jan 23, 2009 9:24 am Post subject: Re: HKS readings for the day |
| ulflyer(at)verizon.net wrote: | Way back a long, long, time ago when I was flying Piper Cherokee's I
jerb
Well the oil thermostat works fine for the oil temp. Below 180f, there's no oil flowing through the oil cooler anyway. Its probably the super cooled CHT's that are preventing the oil temp from getting up to the green in those cases where it still stays below that.
I've used the tape method in the past and like John says it works pretty well, but I havn't found the correct amount of tape to use. On mine, the oil cooler is mounted directly in front of the radiator which does help when oil is flowing through the cooler.
There are several different shutter designs I've been considering and all of them so far are too hard to retrofit and fail in a closed position, etc.
I havn't tried taping off the radiator itself on each side of the oil cooler as John suggested - that may very well be the ticket.
We're having a mild winter this year, tho, so I havn't had too much problem yet. I've been able to run 180 to 190f so I havn't messed with this yet.
I may have a go with the tape the way John suggested tho if it turns cold again....
LS
Titan II SS |
Posted: Fri Jan 23, 2009 12:06 pm Post subject: HKS readings for the day |
At 06:47 AM 1/23/09 -0800, you wrote:
Jack,
| Quote: | These sure seem light!! Did you mean 9 oz, and 2 oz., etc?
Mike,
The weights listed are correct. When you have a defined empty weight limit,
you must keep component weight down.
No, the system does not include a thermostat. The one supplied by Simonini
weighed too much.
Jack B. Hart FF004
Winchester, IN
lcottrell
Posted: Sun Jan 25, 2009 9:37 pm Post subject: HKS readings for the day |
Posted: Mon Jan 26, 2009 7:10 am Post subject: HKS readings for the day |
Larry:
Are you reading both heads?
Any chance the CHT senders are not the correct sender, or unserviceable?
Seems like if the heads are primarily oil cooled the oil temps would run higher.
I'm just guessing.
[quote] I do not see any correlation between the oil temps and the actual CHT's, so I have to think that is just tight.
Titus, Alabama |
lcottrell
Posted: Mon Jan 26, 2009 7:44 am Post subject: HKS readings for the day |
by0ung(at)brigham.net Guest
Posted: Tue Jan 27, 2009 12:11 pm Post subject: HKS readings for the day |
Yes, it reads both and shows the highest reading. They are the sensors supplied by EIS for their unit, and are brand new. I find it very puzzling as well.
Larry C,
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>
You say the cht temps are high,,,,, and the oil is low…. How high are the cht?
I am with john… the returning oil from the heads should cool the heads and raise the oil temp.
Boyd
Posted: Tue Jan 27, 2009 1:38 pm Post subject: HKS readings for the day |
If you suspect the CHT senders are the cause of incorrect readings, take them out of the heads and stick the tip in a pan of boiling water. If the EIS doesn't read 212 (or 100 if your EIS is set for metric reading) you've at least isolated the problem to the sensing system. Have you checked the jet needle position. Mine came with the clip set on the second groove from the top, I raised the needles by moving the clip to the 3rd position and the heads cooled right down.
Do you use the stock vacuum pulse driven fuel pump? If so, how is your fuel pump connected? Did you (or your supplier) tee the balance line between the intake manifolds for the pulse line to the fuel pump. Check for vacuum leaks there, check the pump diaphragm for leaks, too.
Have you mechanically and pneumatically synched your carbs? That can cause CHT problems as the two cylinders fight each other. The Rotax owners site has a great e-learning module that explains the process and why it is important. The method in the HKS manual has not been updated to reflect the addition of a balance tube between the intake manifolds. Contact Dana at Hpower LTD. They have a service bulletin on this. Frankly, the Rotax method works better and you can download the 912 Line Maintenance manual. The method is described in Section 12-00-00 pages 21 through 25.
Have you checked the carb boots? If they have a crack in a carb boot, the mixture will go lean and the CHT's go up. Mine were rotted out after just 50 hours. HKS has a service bulletin about this, too, although the problem with the supplier is supposed to have been fixed some time ago.
Rick
On Tue, Jan 27, 2009 at 2:05 PM, boyd <by0ung(at)brigham.net (by0ung(at)brigham.net)> wrote:
Larry C,
Boyd
lcottrell
Posted: Tue Jan 27, 2009 6:09 pm Post subject: HKS readings for the day |
Hi,
Boyd,The last time I flew I was doing 5750 rpm's oil temps were 157 and CHT was 329 degrees.
Richard, I have not changed anything from the way it came from the factory. I only have about 4.5 hours on it now. I may indeed check the clip positions, it has just been too cold to do anything right now. Good point though.
I did sync the carbs using tubing and Marvel Mystery oil as a marker. I squeezed the balance tubes shut using wood blocks and vice grips. They were quite a bit out of synch. It is smoother, but not cooler.
I do have the pulse pump and a facet fuel pump and the balance lines are teed. Other than that every thing else appears to be ok. I just think that it is tight. If it does not improve with more time, then it will be time to get worried.
Larry C
