Jab 3300 Regulator
lwhitlow
PostPosted: Sat Jan 31, 2009 4:59 pm    Post subject: Jab 3300 Regulator Reply with quote
All
Is there a mating plug for the regulator?? The terminals look like the standard fast-on connector would just slide right on the tabs, but a mating connector pigtailed out would make a cleaner installation and make regulator replacement easier if it ever fails
Larry Whitlow
601XL Jab 3300
challgren(at)mac.com
PostPosted: Sat Jan 31, 2009 9:54 pm    Post subject: Jab 3300 Regulator Reply with quote
Larry:
Yes. there is. I got one from Pete but I noticed in the 3300
Installation Video that they cut the plug off from the regulator and
installed the wires separately.
Stan
701/3300
On Jan 31, 2009, at 17:59 , lwhitlow wrote:
All
Larry Whitlow
601XL Jab 3300
lwhitlow
PostPosted: Sun Feb 01, 2009 5:22 am    Post subject: Re: Jab 3300 Regulator Reply with quote
Simplicity at is best, I like that idea.
Larry
challgren(at)mac.com wrote:
Larry:
Stan
701/3300
All
Larry Whitlow
601XL Jab 3300
dredmoody(at)cox.net
PostPosted: Sun Feb 01, 2009 8:36 am    Post subject: Jab 3300 Regulator Reply with quote
We've been warned not to use plug fixtures and told to hard wire the connections and insulate them heavily... very heavily. The plug interface causes increased resistance which causes increased heat, which further increases resistance and so on. The end result is that the current attempts to arc to any nearby frame element... even through the plug housing. Make the best connections that you can to reduce the resistance at that point and insulate the crap out the junction.
Ed
