Doug.Gee(at)firestone-tex Guest
Posted: Sat Jan 31, 2009 9:06 pm Post subject: Deburring |
I have just started building the VS and I have a question about deburring technique. I have used the scotchbrite wheel t do most of the outside edges and this works well. I have used the deburring tool with the swivelling blade to do the lightening holes but how do I do the notches around the ribs? I used a needle file but very tedious - is there a better way or d these notches not need to be done? Thanks
rv10free2fly(at)yahoo.com Guest
Posted: Sun Feb 01, 2009 3:11 am Post subject: Deburring |
Doug, I find the cloth type sanding paper the best as it doesn't tear and can easily be folded to get into the notches. I normally use around 240 grit and tear off a 1" wide x 3" piece and slide it through the notches a couple of time to debur.
Patrick Pulis
Adelaide, South Australia
From: Doug Gee <Doug.Gee(at)firestone-textiles.com>
Sent: Sunday, 1 February, 2009 3:09:16 PM
Subject: RV10-List: Deburring
--> RV10-List message posted by: "Doug Gee" <Doug.Gee(at)firestone-textiles.com (Doug.Gee(at)firestone-textiles.com)>
I have just started building the VS and I have a question about deburring technique. I have used the scotchbrite wheel t do most of the outside edges and this works well. I have used the deburring tool with the swivelling blade to do the lightening holes but how do I do the notches around the ribs? I used a needle file but very tedious - is there a better way or d these notches not need to gator?RV10-List" target=_blank>http://www.matronics.com/Navigator?RV10-Lit; http://forums.msp; bsp; -Matt Dm/contribution" target=_blank>http://www.matronics.com/contribution
Make Yahoo!7 your homepage and win a trip to the Quiksilver Pro. [url=http://au.rd.yahoo.com/homepage/mailtagline/*http://au.docs.yahoo.com/homepageset/?p1=other&p2=au&p3=tagline]Find out more[/url]. [quote][b]
Posted: Sun Feb 01, 2009 5:58 am Post subject: Deburring |
Usually you can get those with the swiveling blade tool from the right
angle. That tool also can have different shaped blades for different
types of deburring.
Beyond that the needle file can be used to finish up.
Do not archive.
Jesse Saint
Saint Aviation
jesse(at)saintaviation.com
352-427-0285
On Jan 31, 2009, at 11:39 PM, "Doug Gee" <Doug.Gee(at)firestone-textiles.com
> wrote:
done? Thanks
Posted: Mon Feb 02, 2009 6:19 am Post subject: Deburring |
Regarding the swiveling blade tool - I have used such a tool labeled
"Vargus" for a couple of years to deburr an entire QB kit. It has a
thin pencil shaped body with a swiveling but fixed in place blade. It
was part of an RV tool kit I bought from "Ishmail Tools".
Anyway, I figured that the tool must be getting dull so a couple of
months ago I bought one of the deburring tools from Cleveland or Avery.
The type with multiple blades stored in the fat handle. I quickly
discovered the newer tool was inferior to the original. The blades
chattered and caught on the work and quickly dulled. Apparently
something less than hard tool steel or whatever is required for a good
deburring too. I'm back to the Vargus and consider myself lucky it
didn't happen the other way around.
I have no idea where to buy a Vargus but if someone does, I'd still like
to refresh it.
FWIW
Bill "I'm gonna put it up on the wheels" Watson.
Jesse Saint wrote:
types of deburring.
Kelly McMullen
Posted: Mon Feb 02, 2009 6:43 am Post subject: Deburring |
Perhaps you mean Isham? Is this the tool you refer to?
http://www.store-planetools.com/index.asp?PageAction=VIEWPROD&ProdID=53
On Mon, Feb 2, 2009 at 7:15 AM, Bill Mauledriver Watson
<MauleDriver(at)nc.rr.com> wrote:
"Vargus" for a couple of years to deburr an entire QB kit. It has a thin
pencil shaped body with a swiveling but fixed in place blade. It was part
| Quote: | I have no idea where to buy a Vargus but if someone does, I'd still like to
refresh it.
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Mon Feb 02, 2009 8:22 am Post subject: Deburring |
Yes on both counts.
I bought a tool kit from Isham Inc a couple of years ago and it turns
out it was a very good kit for me. Of course I can't easily compare
with others but it's worked out better than expected.
Thanks for info. I never really made the connection with PlaneTools but
I will adding it to my vendor list.
Bill
Kelly McMullen wrote:
> refresh it.
poneill(at)irealms.com Guest
Posted: Mon Feb 02, 2009 12:12 pm Post subject: Deburring |
I have a set of the swiveling tools mentioned. I picked up a set of 4
different ones (from Cleveland or Avery I think) at the beginning of the
project which has worked very well. I also use the mini scotchbrite wheels
for some of those hard to get places and so far it has all worked quite
well:
http://www.averytools.com/pc-351-43-scotch-brite-cutting---polishing--wheel-
-kit.aspx
Best Regards,
Patrick #40715
