		dougsire
				 Posted: Mon Feb 02, 2009 1:37 pm    Post subject: Tensile Strength of AN470 solid rivets |
				I am working up a rivet strength comparison chart and am trying to find the tensile strength of AN470 1/8" and 5/32" solid aluminum rivets.   I found the shear strength in the ZAC Construction Standards but haven't been able to track down tensile.   Anyone have that handy?
 Doug Sire
 601XL
 Billings, MT
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Doug Sire 601XL
Do Not Archive |
		bryanmmartin
				 Posted: Mon Feb 02, 2009 2:13 pm    Post subject: Tensile Strength of AN470 solid rivets |
				I did a Google search on "tensile strength of an470 rivet" and found
 this site at the top of the list:
 http://tinyurl.com/aj37tw
 On Feb 2, 2009, at 4:37 PM, dougsire wrote:
  that handy?
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus redrive.
 do not archive.
  _________________ --
Bryan Martin
do not archive. |
		dougsire
				 Posted: Mon Feb 02, 2009 2:36 pm    Post subject: Re: Tensile Strength of AN470 solid rivets |
				I forgot to mention that in my searches all I have found is a very high number (at least relative to others that I'm comparing against), such as 38,000 lbs.   This must be an ultimate number whereas everything else I've found is in the few hundred lb range.   Maybe these are "yield" strength?   For example, the factory spec sheet for an Avex A5 rivet shows a tensile strength of 300 lbs.
 Doug Sire
Do Not Archive |
		bryanmmartin
				 Posted: Mon Feb 02, 2009 3:40 pm    Post subject: Tensile Strength of AN470 solid rivets |
				That 38,000 you found is given in pounds per square inch. If you
 multiply that by the cross sectional area of the rivet, you'll get the
 actual strength of that rivet. About 466 pounds for an 1/8" rivet.
 On Feb 2, 2009, at 5:36 PM, dougsire wrote:
 Bryan Martin
 N61BM, CH 601 XL,
 do not archive.
Bryan Martin
do not archive. |
		bcchurch
				 Posted: Mon Feb 02, 2009 3:46 pm    Post subject: Re: Tensile Strength of AN470 solid rivets |
				Doug,
 Some confusion can creep in here.  Strength can refer to the rivet material itself or the joint which the rivet forms.
 Shear strength numbers I have seen appear to me to refer to strength of a joint (like a lap-shear joint).  Tensile strength numbers (like the 38 ksi you mentioned) appear more like tensile strength of the rivet material.
 Once you get your data, would you please post it here along with links to where the data was obtained?  It would probably save some others a lot of time duplicating your efforts.
 Ben Church
  _________________ Ben Church
CH801
Racine, WI |
		JohnDRead(at)aol.com Guest
				 Posted: Mon Feb 02, 2009 8:17 pm    Post subject: Tensile Strength of AN470 solid rivets |
				Doug;
              The  300 lb number is probably the clamping strength of the rivet whereas the 38,000  lb number is the yield strength of the aluminum.
  John  Read
 CH701 - Elbert CO - Jabiru 3300
 Phone: 303-648-3261
 Fax:  303-648-3262
 Cell: 719-494-4567
   In a message dated 2/2/2009 3:37:15 P.M. Mountain Standard Time,  dsire(at)imt.net writes:
   	  | Quote: | 	 		  -->    Zenith601-List message posted by: "dougsire" <dsire(at)imt.net>
 Doug Sire
 Doug    Sire 601XL
 Read this topic online    here:
 http://forums.matronics.com/viewtopic.php?p=228220#228220
  Stay up to date on the latest news - from sports scores to stocks and so much more.
		leinad
  Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
				 Posted: Tue Feb 03, 2009 9:33 am    Post subject: Re: Tensile Strength of AN470 solid rivets |
				Doug,
 I've relied on the info from Aircraft Spruce.  Here's an example:
 ""A" rivets are "soft". They are fabricated from 1100-grade aluminum and have a tensile strength of 16,000 PSI. "AD" rivets are fabricated from 2117 aluminum and heat treated to the T4 condition. They have a shear strength of 26,000 PSI and a tensile strength of 38,000 PSI.
 I think you'll find the ZAC drawing indicate the stronger "AD" rivets.
 Dan
  	  | dougsire wrote: | 	 		  I am working up a rivet strength comparison chart and am trying to find the tensile strength of AN470 1/8" and 5/32" solid aluminum rivets.   I found the shear strength in the ZAC Construction Standards but haven't been able to track down tensile.   Anyone have that handy?
 Doug Sire
 601XL
 Billings, MT |
  _________________ Scratch building XL with Corvair Engine |
