Joe(at)hambrothers.com Guest
Posted: Mon Feb 02, 2009 6:53 am Post subject: CLEANING AND FILLING DENTS |
my xl kit was purchased in 02 wings assembled have ben sitting around
moved many times. have picked up some dents can i use a filler ?
what kinde. also what to use for cleaning in general.
thanks.
joe ham
xl / lycoming 0235
Rickey B.
Posted: Mon Feb 02, 2009 7:35 am Post subject: CLEANING AND FILLING DENTS |
Hi, Joe,
I had a couple of dents (minor) from the delivery of parts. I went to O'Reilly's and got a tube of filler glaze for the very small dings. I used a good body putty to fill around parts that I wanted to blend to a contour or just smooth around an add on such as the tail light. Lightly sand with 600 then 1000 before priming. Block sand if it is on a curve to hold the radius and not have a flat spot. It will be impossible to spot after painting.
Rick Beckman
Trainnut01(at)aol.com Guest
Posted: Mon Feb 02, 2009 8:03 am Post subject: CLEANING AND FILLING DENTS |
I had the same problem. Recommend Poly-Fiber Superfil. Got mine at Aircraft Spruce. Strong, light and easy to work with.
Carroll
Stay up to date on the latest news - from sports scores to stocks and so much more.
naumuk(at)windstream.net Guest
Posted: Mon Feb 02, 2009 3:11 pm Post subject: CLEANING AND FILLING DENTS |
Rick-
The question is, does the filler stay put? I've seen too many projects where the filler cracks and comes loose over time.
Bill
Rickey B.
Posted: Tue Feb 03, 2009 4:26 am Post subject: CLEANING AND FILLING DENTS |
Well, hopefully the dents are not so big as to have a small bucket full of putty. I was referring to small dents. If you wish, let's call them dings. I think if you have big dents, it might call for some new aluminum. I used scotch brite to scuff the area (no, I am not going to tell you what color) and cleaned with lacquer thinner, then the glaze or putty. Some of these are years old and you still cannot find them. Hopefully, you never will!
Rick
Rick-
Bill
Posted: Tue Feb 03, 2009 10:17 am Post subject: CLEANING AND FILLING DENTS |
thanks Rick
my dings are very small can you tell mr what filler to use.
also i want to reinforce the cowling what should i use
thanks again Joe Ham
rjscep(at)yahoo.com Guest
Posted: Tue Feb 03, 2009 3:19 pm Post subject: CLEANING AND FILLING DENTS |
--- On Tue, 2/3/09, Joe <Joe(at)hambrothers.com> wrote:
[quote] From: Joe <Joe(at)hambrothers.com>
Subject: Re: CLEANING AND FILLING DENTS
Date: Tuesday, February 3, 2009, 6:14 PM
thanks Rick
Posted: Tue Feb 03, 2009 3:42 pm Post subject: CLEANING AND FILLING DENTS |
Rick-
I'm not talking about filling potholes.
I built my outboards 3 years ago and was so disappointed with my tips I was ready to commit hari-kari. The gap between the aluminum leading edge and the fiberglass tip is what I'm talking about. The wing's in a cradle- took the picture laying on my side. The tips haven't been riveted yet, so the gap might decrease.
No matter the severity- what filler's going to have the best chance of staying put?
Bill
Description: |
Filesize: |
86.75 KB |
Viewed: |
368 Time(s) |
Rickey B.
Posted: Wed Feb 04, 2009 4:33 am Post subject: CLEANING AND FILLING DENTS |
Rick-
Bill
That does not look that foreboding. There is, also, a filler that has fiberglass strands in the mix. It is used just like Bondo or any of the other fillers, except it is a little tougher. If you use this, you should apply it by spreading it in one direction only, so as to "line up" the fibers for more strength. At least that is what I was told/ Seems to work pretty good. That area in your picture is not even close to being a moving or flexing part, so any of the fillers would probably do just fine. Just be sure to get it as smooth as you want the finished look. Any scratches will show in the final finish.
Rick
Posted: Wed Feb 04, 2009 4:09 pm Post subject: CLEANING AND FILLING DENTS |
Rick-
I think I have some of the stuff you're talking about, and if you don't get it right the first time it's stuck, and you're stuck because you can't sand it.
Bill
Rickey B.
Posted: Thu Feb 05, 2009 4:55 am Post subject: CLEANING AND FILLING DENTS |
Well…..I can sand mine, so probably something a little different. If you cannot sand it, I would not use it! Frome way.
Rick
Do not archive.
Bill
Posted: Thu Feb 05, 2009 5:51 pm Post subject: CLEANING AND FILLING DENTS |
Rick-
You bet, which is why I haven't done anything yet. I'm leaning towards the ACS stuff.
Bill
