		GENE MAYO
				 Posted: Wed Feb 04, 2009 5:56 pm    Post subject: clock 2-bladed prop. to jabiru 3300 |
				DO ANY ONE KNOW IF THERE IS A SPECIFIC WAY THAT A 2 BLADED PROP. SHOULD BE CLOCKED TO A JABIRU 3300 ENGINE.
 THANKS IN ADVANCE.
 GENE
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ gene fl |
		DaveG601XL
  Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
				 Posted: Thu Feb 05, 2009 5:55 am    Post subject: Re: clock 2-bladed prop. to jabiru 3300 |
				Gene, I took two considerations in mind when I installed my prop, 1. tracking and 2. a horizontal prop when I turn the engine off.
 1. If you cannot get the tracking in spec with one location, remove and rotate, for example, 180 degrees and see if it helps.
 2. For a horizontal prop, I was given this link to the  UK Jab site:
 (http://www.jabiru. flyer.co. uk/)
 "Stand in front of the prop looking back towards the flywheel.
 Position the flywheel so that the magnets are vertical. Position the
 prop so that it is located in the prop guides that give it an 11.00
 o'clock position. It should now stop in the horizontal".
 I did this and about 70% of the time I get a horizontal prop on engine shutdown.
 Good luck,
  _________________ David Gallagher
Cincinnati, OH area |
