Posted: Fri Feb 06, 2009 6:12 pm Post subject: Up on its' gear |
Can someone give me a measurement of how high the fuse bottom is off the ground while the plane is on it's gear.
I need to barrow a pallet jack to raise my fuse holder off the ground and I want to barrow it and return it in the same day.
Thanks C
JOhn G.
millstees(at)ameritech.ne Guest
Posted: Fri Feb 06, 2009 6:23 pm Post subject: Up on its' gear |
Mine is 27", measured at the landing gear.
Steve Mills
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez
Sent: Friday, February 06, 2009 8:11 PM
To: RV 10 group
Subject: Up on its' gear
JOhn G.
AirMike
Posted: Sat Feb 07, 2009 10:00 am Post subject: Up on its' gear |
Yes to all of the above, but you need to raise it up higher than that in order to capture the gear in the receiver. I would est that you need to jack it 33-36" up to get the gear legs in the hole. Remember also to grease the gear legs before hand. Good luck.
_________________ See you OSH '18
Q/B - sold. |
Posted: Sat Feb 07, 2009 12:42 pm Post subject: Up on its' gear |
Thanks C
I meant to say
(I'll) use a lot of vasoline
JOhn
DO NOt Archive
[quote] Subject: Re: Up on its' gear
Date: Sat C 7 Feb 2009 10:00:52 -0800
I use a lot of vasoline
JOhn
DO NOt Archive
[quote] Subject: RV10-List: Re: Up on its' gear
Posted: Sun Feb 08, 2009 9:36 am Post subject: Up on its' gear |
I put mine on top of a 34" workbench yesterday and that is clearly be
high enough to install the gear legs and the wheels. I used my HF
engine hoist to lift the fuse on the table. Worked very well.
Bill
John Gonzalez wrote:
| Quote: | Can someone give me a measurement of how high the fuse bottom is off
JOhn G.
