Change in Economy... Change in Plans... Interior
Goto page 1, 2  Next
jeff(at)westcottpress.com
PostPosted: Sat Feb 07, 2009 1:43 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
With the downturn in the economy (my business, a commercial printing
company, is down 40%) I'm having to rethink my RV-10 plans and would
love to hear some thoughts about cost cutting options in the home
stretch. I imagine I'm not the only one struggling with these issues
and I think the conversation would benefit many. Because of where I
am in the build, and the many topics this will span, I think it's
best to break this in to three threads: Interior, Panel and Paint.
Others may want to expand beyond these three, but these are the areas
I have in front of me to consider. The option of taking on a partner
is also something I'm considering, but I want to see things play out
a while longer before I go that route.
My plan has been to buy a Flightline Interior in leather at a cost of
about $5000. I'm now considering adding the craft of upholstery to
the list of things I've learned while building this plane. For those
that have "rolled your own" interiors, was the raw material cost low
enough to realize some savings? What are some good resources for
headliner, carpet and leather? What tools are required? What are
the best "How To" books to read?
Up until now, I have had a nice mix of time and money. Now I've got
a surplus of time... money, not so much.
Jeff Carpenter
40304
N410CF (reserved)
pietflyr(at)bellsouth.net
PostPosted: Sat Feb 07, 2009 2:50 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
Jeff, when I built my Pietenpol Aircamper (which, btw is in this month's Sport Aviation on page 7Cool I got an entire hide of leather from B&B Aircraft Supply at OSH for $110 (this was in 2002). I made the seat cushions with Temperfoam and then took the foam and the leather to a local upholstery shop that specializes in boat upholstery. They charged me $400 to make two seat cushions, so between the foam, the leather and the upholstery shop, I put a total of about $600 into two seats (and had enough leather left over to make the cockpit coamings, and still more is left). I would think if you do it yourself like that, even paying professionals to sew it (leather requires pretty heavy duty sewing machines) you should be able to do all four seats for about $1,000.
Jack Philllips
RV-10 #40610
Pietenpol NX899JP
Tim Olson
PostPosted: Sat Feb 07, 2009 3:04 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
While not a way to get maximum savings, just changing from Leather
to fabric or faux leather would save a bunch on the interior.
and I think the conversation would benefit many. Because of where I am
in the build, and the many topics this will span, I think it's best to
break this in to three threads: Interior, Panel and Paint. Others may
want to expand beyond these three, but these are the areas I have in
front of me to consider. The option of taking on a partner is also
something I'm considering, but I want to see things play out a while
about $5000. I'm now considering adding the craft of upholstery to the
list of things I've learned while building this plane. For those that
have "rolled your own" interiors, was the raw material cost low enough
to realize some savings? What are some good resources for headliner,
carpet and leather? What tools are required? What are the best "How
To" books to read?
Up until now, I have had a nice mix of time and money. Now I've got a
Jeff Carpenter
40304
N410CF (reserved)
Tim Olson
PostPosted: Sat Feb 07, 2009 3:08 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
Oh, and for what it's worth, if you can stomach it, and you find
the RIGHT partner, going partners in a plane can have just
tremendous cost savings advantages for maintenance, for hangar
costs, and all that aspect too. I have to say, finishing the
plane is expensive, but once I got mine flying, I found that
whereas I had previously been able to save up quite a bit of
money in shorter timeframes, just the fact that I was flying
the plane really heavily impacts how fast our savings account
is rebounding. It's been 3 years now that I've been flying
my RV-10. It took me 2 years to build it. I saved up only
about 1/2 to 1/3 of the money in the bank SINCE I've finished
the plane in 3 years, as I did in the 2 or 3 years prior while
building it. That's why I'm not a fan of financing a kit
project...because once you're done, making the payments isn't
going to be any easier if you actually use your airplane.
So if you do indeed find a good partner, even if you do it for
a limited timeframe, it could give you the opportunity to get
back into a good financial position without sacrificing what you
want to put into the plane, and make the long-term possibilities
more feasable.
To" books to read?
Jeff Carpenter
40304
N410CF (reserved)
pitts_pilot(at)bellsouth.
PostPosted: Sat Feb 07, 2009 3:17 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
am in the build, and the many topics this will span, I think it's best
Don't install an interior. You can always do that later.
Panel
Don't know whether you're planning on full IFR, but you can install a
VFR panel and then upgrade to IFR when you have the cash.
and Paint.
If you have a hangar to store the completed plane in, then even paint
can be delayed. If no hangar, I'd recommend painting it so it
withstands the weather better.
areas I have in front of me to consider. The option of taking on a
partner is also something I'm considering, but I want to see things
play out a while longer before I go that route.
about $5000.
$5000 will go a long way to populate your panel. And you'll be somewhat
lighter for it! Wink
I'm now considering adding the craft of upholstery to the list of
things I've learned while building this plane. For those that have
"rolled your own" interiors, was the raw material cost low enough to
By the time you invest in an industrial sewing machine and toss the
'learning experience' material, I'm not sure that you'd be very far
ahead. You'll surely save on the frustration level by contracting that
part out. Installing the 'bad' parts will aggravate you each time you
lay eyes on it .... and that's true when only you notice!!!
Good luck
Linn
What are some good resources for headliner, carpet and leather?
What tools are required? What are the best "How To" books to read?
Jeff Carpenter
40304
N410CF (reserved)
chuck(at)chuckdirect.com
PostPosted: Sat Feb 07, 2009 5:24 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
While we're speaking of cutting corners or costs, what are you guys doing
about yearly property taxes on your RV10s particularly those of you living
in California. As near as I can tell it's going to cost me about $2,000 a
year in "personal property taxes" for the state/county to allow me to keep
my airplane. Ideas?
Chuck
Subject: Re: Change in Economy... Change in Plans... Interior
more feasable.
> company, is down 40%) I'm having to rethink my RV-10 plans and would love
> to hear some thoughts about cost cutting options in the home stretch. I
> imagine I'm not the only one struggling with these issues and I think the
> conversation would benefit many. Because of where I am in the build, and
> the many topics this will span, I think it's best to break this in to
> three threads: Interior, Panel and Paint. Others may want to expand
> beyond these three, but these are the areas I have in front of me to
> consider. The option of taking on a partner is also something I'm
> considering, but I want to see things play out a while longer before I go
> that route.
> have "rolled your own" interiors, was the raw material cost low enough to
> realize some savings? What are some good resources for headliner, carpet
> and leather? What tools are required? What are the best "How To" books
> to read?
> Jeff Carpenter
> 40304
> N410CF (reserved)
capsteve(at)iflyrv10.com
PostPosted: Sat Feb 07, 2009 6:04 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
Wow, I thought new York was bad.. perhaps setting up a out of state
corporation which owns the aircraft could help..
I have used Nevada before..
steve DiNieri 40205
IFLYRV10.COM
Sent: Saturday, February 07, 2009 7:55 PM
my airplane. Ideas?
Chuck
> more feasable.
> Tim Olson - RV-10 N104CD - Flying
> do not archive
>> To" books to read?
>> Jeff Carpenter
>> 40304
>> N410CF (reserved)
pascal(at)rv10builder.net
PostPosted: Sat Feb 07, 2009 6:06 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
Jeff;
I feel your pain, my group at the Corp continues to diminish each month,
they announced a 12K headcount reduction within the year and no one is
safe, so I have slowed my project waaay down to assure I have funds for that
thunderstorm should I get stuck in that layoff.
I plan to spend the money on the engine- new one, maybe do what you did and
get it on clearance at Sun n Fun, I plan to get the panel I planned on or
maybe better as technology allows, , my seats are done locally using a good
quality faux leather since my 2 daughters are very young and will test the
seats for durability so anything less or more was not acceptable. Everything
else is not critical to my mission and can be done to a minimum. I'll paint
the interior with a decent paint and deal with better later, outside will
probably get painted like Tim did since it will be far easier time and
financially to do it in pieces than after completion in a pro shop. I'll
take my time doing all this as it will cost money to park the plane in a
hangar, pay California taxes and of course all those trips for the family as
Tim has teased us all with these last three years once the plane is
completed, THAT will far outdo any spending I am doing now. The good news
for me is by my saving for the thunderstorm, if it dissipates before hitting
me I'll have the funds to finish and afford flying the plane, so time is a
good thing. Be patient and work on the plane, delay the major purchases as
long as possible, and get the panel you want that too will cost more to
replace and redo later than just doing it right the first time.
Best of success with whatever you decide to do.
Pascal
Sent: Saturday, February 07, 2009 1:42 PM
Subject: Change in Economy... Change in Plans... Interior
that route.
to read?
Jeff Carpenter
40304
N410CF (reserved)
dlm46007(at)cox.net
PostPosted: Sat Feb 07, 2009 6:42 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
Vote with your feet. AZ NV ??
avu1(at)md.metrocast.net
One thing I'm most proud of about my interior is my home made upholtery -
only because my wife came home one day with two rolls of uphostery fabric
from G-Street Fabric. It's been a while but I think the total cost was
$300. I spent a week covering each seat, one stitch at a time. I think
there's enough left over to cover at least one more set of seats. That
was a saving of a few thousands.
I'm glad I don't live in CA.
Anh
N591VU
my airplane. Ideas?
Chuck
> more feasable.
> do not archive
>> <jeff(at)westcottpress.com>
>> love
>> I
>> the
>> and
>> go
>> that route.
>> to
>> carpet
>> books
>> to read?
>> Jeff Carpenter
>> 40304
>> N410CF (reserved)
indigoonlatigo(at)msn.com
PostPosted: Sat Feb 07, 2009 7:27 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
As per Callefornia...as Arnold calls it...it might be best to leave it without a registration number and out of sight for as long as possible. This doesn't help...but I too dred the day the LA Co. assessors office sends me that letter C every year C time to bend over.
I suspect they may even try to fine me for not paying the taxes prior to the builds completion.
I don't think the Nevada option works unless you can leave it there for a very long time C get to it easily and even they are short on money and looking for it in what ever way they can.
JOhn G.
Jacked up the plane today and now the top of the plane is about seven inches from the gluelam on my shop ceiling
[quote] From: chuck(at)chuckdirect.com
Date: Sat C 7 Feb 2009 16:55:23 -0800
PostPosted: Sat Feb 07, 2009 8:17 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
The board is actually quite confused on how to handle homebuilts, technically you have 1 year to pay for the out of state purchases, they will simply tax you for the value assessed as if you bought the plane (aka 7.75% of initial assessment). It turns out to be less in taxes to pay as you go since then you don’t have to show receipts for all California purchases. As far as the property tax it's 1.0% of the assessed value, if you disagree with the initial assessment you can request a revalue and court date. They'll basically ask what you have in the plane than compare to other RV-10's out there, so those wanting 200K plus for their planes are going to hurt the rest of us as that is how they determine the final value, unless you're plane is state of the art I don’t think you'll be hit with 2K a year, even in LA county.
If you're not going to do the LLC and try to get it by Arnold's tax army for over a year as being in Nevada, think about paying for the kits now. California is spending lots of money to assure boats, cars and other "luxury" items are not being covered as LLC and placed in California, the penalties are very severe if caught, my neighbor, who's a yacht broker said trying to sell boats 100 miles out and leaving in Mexico for a year is not working anymore in Ca, one of his clients was caught and hit with close to 500K in penalties for a 1.1million yacht, take your chances in DE or NV but California is in a deficit and want all those who support those who aren't paying a dime in this state to pay more.
It's not worth it to me, I play by the books and know that if Obama nominates me I'll have a clean tax record.
Sent: Saturday, February 07, 2009 7:25 PM
To: RV 10 group (rv10-list(at)matronics.com)
Subject: RE: Change in Economy... Change in Plans... Interior
As per Callefornia...as Arnold calls it...it might be best to leave it without a registration number and out of sight for as long as possible. This doesn't help...but I too dred the day the LA Co. assessors office sends me that letter, every year, time to bend over.
I don't think the Nevada option works unless you can leave it there for a very long time, get to it easily and even they are short on money and looking for it in what ever way they can.
JOhn G.
Date: Sat, 7 Feb 2009 16:55:23 -0800
--> RV10-List message posted by: "Chuck Weyant" <chuck(at)chuckdirect.com>
my airplane. Ideas?
Chuck
> --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
> more feasable.
> do not archive
>> --> RV10-List message posted by: Jeff Carpenter <jeff(at)westcottpress.com>
>> that route.
>> to read?
>> Jeff Carpenter
>> 40304
>> N410CF (reserved)<=======================
PostPosted: Sat Feb 07, 2009 8:39 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
This is the biggest reason not to register your plane as an RV-10. Call
it a Pascal-1 (or 2 or 3 for repeat offenders Smile ) and pay whatever tax
you're comfortable with. If you're proactive and send the state a little
tax money (be somewhat reasonable) when you finally register the
airplane, they aren't likely to make a fuss. If you aren't proactive and
they finally send you a letter (and they will) then you're hit with the
taxes and penalties.
States are increasingly taxing on where the airplane resides, not where
the corporation resides. Some states issue a 'use tax' sticker. If your
airplane resides in a hangar and can't be seen on the ramp without a
sticker then you might get by without paying for a while .... but the
tax man just asks the airport management for a t-hangar list with
N-numbers .... and you're busted.
I love it! Maybe you can get some help from the stimulus bill!!! There's
a saying that volunteers pay taxes ..... it all depends on how much you
volunteer.
Linn
ricksked(at)embarqmail.co
PostPosted: Sat Feb 07, 2009 10:36 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
If I were you guys I suggest you not post your tax evasion schemes on the list....government knowledge is dangerous...remember the TSA thread the other day?
Sent via BlackBerry by AT&T
partner14
PostPosted: Sat Feb 07, 2009 11:53 pm    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
Do like what we're going to do....... MOVE the hell out of here! (Calif)
Don McDonald
Date: Saturday, February 7, 2009, 4:55 PM
about yearly property taxes on your RV10s particularly those of you living in
California. As near as I can tell it's going to cost me about $2,000 a year
my airplane. Ideas?
Chuck
more feasable.
company, is down 40%) I'm having to rethink my RV-10 plans and would love to
hear some thoughts about cost cutting options in the home stretch. I imagine
conversation would benefit many. Because of where I am in the build, and the
many topics this will span, I think it's best to break this in to three
threads: Interior, Panel and Paint. Others may want to expand beyond these
three, but these are the areas I have in front of me to consider. The option of
taking on a partner is also something I'm considering, but I want to see
things play out a while longer before I go that route.
about $5000. I'm now considering adding the craft of upholstery to the list
of things I've learned while building this plane. For those that have
realize some savings? What are some good resources for headliner, carpet and
to read?
got a surplus of time... money, not so much.
> Jeff Carpenter
> 40304
> N410CF (reserved)
Don A. McDonald
40636
partner14
PostPosted: Sun Feb 08, 2009 12:08 am    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
I worked for the Franchise Tax Board for 28 years.,... you are so right. I have a catamaran on the east coast and Calif went after me for the sales tax.... When I didn't get all the info to them (because we were in the Bahamas) they sent me a bill for $33,000. Did finally get it all straightened out, but what a pain.
So, definitely donot post your scheme on any board. Pascal, email me.
Don McDonald
--- On Sat, 2/7/09, ricksked(at)embarqmail.com <ricksked(at)embarqmail.com> wrote:
[quote]From: ricksked(at)embarqmail.com <ricksked(at)embarqmail.com>
To: "Rv" <rv10-list(at)matronics.com>
Date: Saturday, February 7, 2009, 10:33 PM
[quote]--> RV10-List message posted by: ricksked(at)embarqmail.com If I were you guys I suggest you not post your tax evasion schemes on the list....government knowledge is dangerous...remember the TSA thread the other day? Sent via BlackBerry by AT&T --
Don A. McDonald
40636
poneill(at)irealms.com
PostPosted: Sun Feb 08, 2009 12:53 am    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
Ditto on that. I’ve lived in CA my entire life and the CA FTB is definitely the worst. I’ll deal with the IRS over them any day of the week.
The tax issues on my project are getting just as much diligence as the workmanship on the plane.
Patrick #40715
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald
Sent: Sunday, February 08, 2009 12:07 AM
Don McDonald
Date: Saturday, February 7, 2009, 10:33 PM [quote]--> RV10-List message posted by: ricksked(at)embarqmail.com If I were you guys I suggest you not post your tax evasion schemes on thelist....government knowledge is dangerous...remember the TSA thread the otherday?Sent via BlackBerry by AT&T --
daveleikam(at)wi.rr.com
PostPosted: Sun Feb 08, 2009 6:55 am    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
I thought tax evasion was legal now?
In WI I believe we pay tax on the project at registration time. That is why
I am keeping detailed receipts of every purchase I have made during the
entire build to present to the WI Dept. of Revenue so they may tax me
accordingly.
PostPosted: Sun Feb 08, 2009 8:03 am    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
Tim. I believe, had a writeup on this on his site.
In Ca you do too but if you pay along the way when they go to tax you once
the FAA has your number as active in California the FTB comes out with a
bill once you show that you already pay all taxes to build the plane and
they don't pursue taxing you again, so you only pay taxes on the actual cost
not the estiomated value- same thing you are saying just easier than doing
it later with every receipt.
Sent: Sunday, February 08, 2009 6:54 AM
why I am keeping detailed receipts of every purchase I have made during
the entire build to present to the WI Dept. of Revenue so they may tax me
accordingly.
evmeg(at)snowcrest.net
PostPosted: Sun Feb 08, 2009 8:09 am    Post subject: Change in Economy... Change in Plans... Interior Reply with quote
How about using a mid time engine? You can take at least half off the price
of a new one and still have 1000 hours of flight time. I have a nice one
available for $14k with under 1000 hours SMOH if anybody is interested.
Email for details.
Cheers...
Evan
Goto page 1, 2  Next
Page 1 of 2
