[jabiruengines] A new thread for Jabiru, tires?
imap8ntr(at)cox.net
PostPosted: Thu Feb 05, 2009 2:18 pm    Post subject: [jabiruengines] A new thread for Jabiru, tires? Reply with quote
Jabiru pilots
Since tires are paramount for aircraft safety even before getting off the ground, I thought I would bring up this issue (maybe for a light change.)
My J-250 calls for main tires of 500 x 5. When I got the aircraft it came with 4 ply. I wonder if the 500 x 5 tires, 6 ply would be better. They obviously are rated for more static and breaking load. They are the same dimensions and weight as the original 4 ply and for the same price.
It seems intuitive that the 6 ply would be better. I do not know if an aircraft can specifically be designed to only use the 4 ply and no more, even given the above data. Incidently the "5" is the rim size but what is the "500?" It certainly is too big a number for the wheel diameter or tread width? Any ideas?
Ivan
USA
Lynn Matteson
PostPosted: Thu Feb 05, 2009 2:46 pm    Post subject: [jabiruengines] A new thread for Jabiru, tires? Reply with quote
That number probably refers to the width of the tire at the widest
point, or the width of the rim between the flanges. Are you sure
there isn't a decimal point after the 5......as in 5.00 x 5?
Maybe the manufacturer of the airplane, Jabiru in this case, had a
bit of "springing" in mind with the original 4-ply tires, and going
to the 6-ply would transfer more shock to the landing gear...just a
thought. Sometimes these decisions are made as a compromise, and when
we experimentalists change things, we introduce other factors that
upset the apple cart.
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
New skis done and flying
On Feb 5, 2009, at 5:17 PM, Ivan wrote:
Jabiru pilots
light change.)
Ivan
USA
Lynn
Kitfox IV-Jabiru 2200
N369LM
imap8ntr(at)cox.net
PostPosted: Thu Feb 05, 2009 3:27 pm    Post subject: [jabiruengines] A new thread for Jabiru, tires? Reply with quote
That is true, I would certainly like to hear from Pete regarding if they
had some specific reason why to use 4 ply instead of 6 ply. Good thought
about the springing of the tires, who knows. That is why I always default
to the manufacturer since they have many intricate reasons for doing things
which our "experimenting" mentality always tries to fix without maybe
knowing all the details.
The 500 has no decimal point and 500 x 5 is exactly as it is listed with a
few aviation tire manufacturers. I just cant fit 500 into anything.
Ivan
Roger Lee
PostPosted: Sat Feb 07, 2009 4:47 pm    Post subject: Re: [jabiruengines] A new thread for Jabiru, tires? Reply with quote
The 6 ply over the 4 ply is fine. It won't make any difference other than you'll have 2 more plys in the tire. You won't be able to tell the difference in the planes handling or anything else. My nose wheel had a 2 ply from the factory and I went with the Desser LSA 6 ply tire (5.00-5). It says it is a tubeless tire, but after talking to Desser, I just put a tube in like everyone else. Never looked back. It just has a better load rating and a little less sidewall flex between the 4 and the 6. I run 27-29 psi in the front. I have 6.00-6 for mains. That tire I run the Desser "Monster Tread" tire like a lot of my friends. I also used the Monster tread on my last plane after a couple of flats. Best money I ever spent and it's not expensive.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
imap8ntr(at)cox.net
PostPosted: Sat Feb 07, 2009 8:07 pm    Post subject: [jabiruengines] A new thread for Jabiru, tires? Reply with quote
Thanks Roger.
I have about 900 landings on my nosewheel and about 700 on my mains (300 on
the inner and 400 on the outer edges) I am a new pilot so I think these
tubed Air Hawks are doing me fine. Of course these landings have been
almost entirely on asphalt runways.
I am still wondering if 5.00-5 and 500-5 on the mains is the same tire size?
I just have replaced the tires with what size the old ones are labelled.
Ivan
wypaul
PostPosted: Tue Feb 10, 2009 7:12 am    Post subject: Re: [jabiruengines] A new thread for Jabiru, tires? Reply with quote
Ivan,
500-5 and 5.00-5 should be the same tire. The 500 or 5.00 is 5 inches thru the widest part of the sidewall, where the sidewall bulges. You will hear the tire refered to as a five hundred by five either way it is written.
Paul
Paul Spackman
Q-2 Jabiru 3300
imap8ntr(at)cox.net
PostPosted: Tue Feb 10, 2009 8:36 am    Post subject: [jabiruengines] A new thread for Jabiru, tires? Reply with quote
Ivan
