user9253
Joined: 28 Mar 2008 Posts: 1968 Location: Riley TWP Michigan
Posted: Sat Feb 07, 2009 6:56 pm Post subject: Light Speed Ignition with OV |
There has been discussion recently about Light Speed Ignition with built in OV protection based on a phone conversation with Light Speed. And then someone posted an excerpt from the installation manual which reads in part:
"Input voltages above 35 volts or reversed polarity will cause system damage. For this reason it is mandatory that all aircraft using Plasma CD Ignitions are equipped with over-voltage protection in their alternator charging system(s)."
I interpret this to mean that there is no crowbar over-voltage protection built into the Light Speed Ignition. Otherwise, how could it be damaged if high voltage is shorted by internal OV protection? And why would it be mandatory that the aircraft electrical system be equipped with OV protection if it is already built into the ignition? I suggest that there was a misunderstanding in the conversation and that Light Speed Ignition systems do NOT have built-in crowbar over-voltage protection. The company should issue a written statement to clarify this issue. Otherwise prospective customers might not want to buy their products if there is a perceived danger that a charging system failure could stop the engine.
Joe
_________________ Joe Gores |
mrspudandcompany(at)veriz Guest
Posted: Sun Feb 08, 2009 5:46 am Post subject: Light Speed Ignition with OV |
Joe
[quote] This is not a perceived danger, as you stated, but a real actual failure reported by more than 1 lister. I agree that the company should issue a statement to clarify their design goals. In the mean time, it appears that pilots should be aware of this potential problem and the power to the Light Speed Ignition systems should be fed through an easily accessible in flight circuit breaker. Roger [b]
Posted: Sun Feb 08, 2009 7:08 am Post subject: Light Speed Ignition with OV |
At 07:36 AM 2/8/2009, you wrote:
Joe
| Quote: | This is not a perceived danger, as you
[/b] |
This is one example of the important activities
for crafting and qualifying systems on
TC aircraft. This exercise offers decades of valuable
lessons-learned. The conversations that have
evolved around this topic are excellent examples
of how much "wobble" there is moving toward
complete understanding when we're not privy to
the details of a particular product's design.
On the TC side of the house it's not uncommon for
an OEM airframer to have complete sets of drawings
for as-supplied products in the "vendor files".
Of course, these are protected under the standard
non-disclosure agreements. Access to these files
is a critical component of seamless system
integration and troubleshooting of fielded
systems.
Not having access to internal details gives rise
to discussions not unlike those we're having now
about Lightspeed . . . and those we've had in the
past about critical characteristics of IR
alternators.
The point I've emphasized in all of these
discussions is that intimate knowledge of the
inner workings of a product is absolutely required
for competent systems folks to do their job.
The marketing hype and 4-color brochures are
useless when it comes to qualifying a device on the
aircraft and/or preventing/fixing problems in the
field.
There is risk when a customer is forced to
"interpret" the meaning of words to arrive at some
rudimentary understanding. Lightspeed has a
free-marked duty to give you lucid answers to
all of your questions . . . just as you have
a right to reject their product based on
perceptions of value and risk. Risk pushed
upon you as a product of holding critical details
incommunicado is not acceptable.
( -Thomas Paine 1776- )
user9253
Posted: Sun Feb 08, 2009 5:58 pm Post subject: Re: Light Speed Ignition with OV |
Thanks to Bob and Roger for the informative replies.
Roger, You mentioned other postings about over-voltage conditions disabling the Lightspeed ignition. I would like to read about them if you happen to have a link to the posting. I do not read AeroElectric everyday and missed the postings. I did read about a Lightspeed ignition that failed because of overheating.
Thanks, Joe
Posted: Mon Feb 09, 2009 6:14 am Post subject: Light Speed Ignition with OV |
| Quote: | Thanks to Bob and Roger for the informative replies.
Thanks, Joe
Joe,
I have erased most of the recent postings, but here is one in which Bob
gives a lot of info:
Roger
<nuckolls.bob(at)aeroelectric.com>
At 11:34 AM 2/4/2009, you wrote:
| Quote: | Bob,
If I choose the routed suggested by your diagram
to run both ign boxes, would you duplicate the
fuse & 14 AWG from the batt buss or simply run
the 14 AWG to a bus bar such that I could hook up both 5 amp cb's?
If you create an ignition bus that services
contemporary conventions for minimizing the energy
exposure of battery-feed wires during crash
events, then you need a disconnect at the battery.
A design goal for inoculating the aircraft's
accessories from single-points of failure becoming
hazardous.
This suggests that dual ignition systems are either
powered from multiple busses that have low probability
of common failure or a single bus with a VERY low
probability of failure.
We've cited design and maintenance goals for making
sure that a battery bus connected to a well maintained
RG battery is the single bus with a very low
This gave the writer comfort in suggesting that
separate fuses for two ignition systems fed from
an always hot bus supported was a good design
when that bus was supported by (1) well maintained
RG battery (2) main alternator (3) aux alternator
and (4) protected with very fast fuses that addressed
our goals for crash safety.
| Quote: | It appears that this is only adding hardware
from the already existing entry point of the
buss and further extending it to cb's. The only
valid argument I see is the ability to reset a
cb in crisis mode (after a big OV event has
blown both fuses) and continue down the road -
albeit with just about everything else riding on the buss blown as well.
That's the real sticking point. If we're doing due
diligence and honoring our past teachers, there's no
reason for the ignition system to even have such a
feature. No mater how honorable the motivation for
including it, it created FEMA issues that would
get the thing booted from a TC aircraft.
Thanks so much for your input on this topic. I'm
sorry you are not getting paid for this prime
time activity. Hopefully there is a way we can donate to your cause.
I wouldn't do it if it were not useful to me
personally . . . so don't be concerned for any
overt lack of compensation . . .
| Quote: | Recently I read a thread from some FAA lawyers
who were talking about mechanical standards and
regulation. One said that the FAA regulations
for mechanical compliance (not design) are
designed to be debated. He was referring to the
often vague terms in which the regulations are
written. They should be left open enough for
debate, but not too wide open as to allow broad
deviation from normal practices (depends who's calling what normal).
Gee do they think? Do you suppose this is why
folks in the airframe services business will shop
around for the most compliant ACO to get their
STC or 337 on an airplane? Like our tax codes,
the FARS are a study in debate prompted by a
lack of teaching to simple-ideas.
The same phenomenon is infecting industry and
government with an MBA/Harvard-Law mentality that
curiosity, creativity and wisdom of experience
by honorable individuals can be replaced with
"The Plan".
IMO this type of debate should strive to improve
the quality/design of the products offered in
such a way that the improvements are both
advantageous in technological design and add a
factor of safety for the end user. For my $$
pure technology advancement that adds little or
takes away from the integrity of well known systems is a bad investment.
Absolutely.
So, debate is good and I hope Klaus and others
accept the forward thinking on which their products are offered.
Sure. I recall with great fondness the circumstances
of my last really rewarding job. I cannot recall a
single instance of walking with trepidation into
a come-to-jesus meeting in Beech's Targets Division.
We had many meetings were some portion of a program
was in trouble. As the problem was discussed and
ideas circulated around the table, new avenues of
attack would emerge. Folks freely volunteered to
help out. You always walked out of those meetings
with a feeling of accomplishment and renewal. This
is how I imagine the meetings in Kelly Johnson's
"Skunk Works" worked. This is a tribute to a handful
of individuals at the ship's wheel.
You can bet the bank on the idea that progress
was bench marked by the successful integration of
simple-ideas to satisfaction of design goals
by a group of honorable individuals. That's my
vision of what should happen here on the List.
Posted: Mon Feb 09, 2009 6:49 am Post subject: Light Speed Ignition with OV |
At 08:02 AM 2/9/2009, you wrote:
<mrspudandcompany(at)verizon.net>
>Thanks, Joe
Joe,
Bob gives a lot of info:
Roger
AeroElectric-List messages are archived on the
matronics.com server. You can search any of
the matronics list at:
http://www.matronics.com/search/
or review all postings of a particular time
frame at:
http://www.matronics.com/archives/
