		hotwheels
				 Posted: Mon Feb 09, 2009 9:13 am    Post subject: Firewall insulation |
				I recall seeing a website of aft-side firewall insulation templates that someone was selling. Does anyone have that info handy? Guess I could crawl around under there, but it might be easier to cut using a template.
 The path of least resistance would be to could use spray adhesive to attach insulation, but that's a permanent solution that wouldn't allow future inspection. What other options are there?
 I have several yards of insulation received from Abby (at) Flightline Interiors.
 http://www.flightlineinteriors.com/products/construction/default.asp
 Jay
		AirMike
				 Posted: Mon Feb 09, 2009 12:44 pm    Post subject: Firewall insulation |
				I bought some of the stuff from Abbey and used it wit Super 77 adhesive. (Be aware that I am Not flying yet).
 Just make some cardboard templates and cut away. I am not too worried about inspecting the firewall as it is a piece of monolithic SS and is not as subject to cracking like the aluminum.
  _________________ See you OSH '18
Q/B - sold. |
		dogsbark(at)comcast.net Guest
				 Posted: Mon Feb 09, 2009 4:41 pm    Post subject: Firewall insulation |
				Jay,
 I used hi-temp RTV for adhesive.  Just dabs in the corners and a few in the middle is enough.
 If you can get the firewall material in the ballpark size-wise, hold it up to the area you want to install it and press along the bulkheads and supports.  Run your hands along those areas a few times and you will get a light impression in the foil.  Get a medium point Sharpie (not fine-tip as it goes right through the foil) and mark the impressions, then cut.
 Hope this helps.
 Sean Blair
 (observation deck)
		jump2(at)sbcglobal.net Guest
				 Posted: Mon Feb 09, 2009 8:06 pm    Post subject: Firewall insulation |
				Jay,
  What I did was to put 4 nut plates around the firewall on each side to hold the insulation from moving. Use a large washer and screw to hold it and if you need to remove it you can without tearing things up.
 Patrick Thyssen
 Will fly one day.
 --- On Mon, 2/9/09, jayb <jaybrinkmeyer(at)yahoo.com> wrote:
 [quote]From: jayb <jaybrinkmeyer(at)yahoo.com>
 Subject: Firewall insulation
 Date: Monday, February 9, 2009, 11:13 AM
 [quote]--> RV10-List message posted by: "jayb"
 around [quote][b]
		hotwheels
				 Posted: Tue Feb 10, 2009 7:39 am    Post subject: Re: Firewall insulation |
				Thanks for the great tips. Someone sent me a link to here for the templates... http://www.iflyrv10.com/iflyrv10/Insulation_Templates.html
 I'm way past needing a variety of templates, so I'll opt for the crawl around method. Any small distracting task is a welcome reprieve from working on the doors or fitting the bottom cowl.
 Cheers,
 Jay
