Engine ground on RV 10
planesmith(at)hotmail.com
PostPosted: Tue Feb 10, 2009 3:51 pm    Post subject: Engine ground on RV 10 Reply with quote
Hi All C
I'm building an RV 10 with the 12v battery locally grounded and mounted in the tail. Where is a good place to locally ground the engine on the airframe?
Possible engine grounding options are:
1. To a ground forest mounted on the stainless firewall. Q: Will the thin stainless handle the current during the starting of an IO 540?
2. To one of the engine mount/airframe bolts.
3. To the engine mount (Yes C I've read Bob's article against using this but through it in anyway.)
3. Other options?
I really don't want to run a negative cable back to the battery (~12 foot of #2 cable.) I have looked through the archives and this subject has been nibbled around both here and on the RV 10 list C but not hit square on the head. I look forward to you comments.
Thanks C
Vernon Smith (#324 RV 10 finishing)
Windows Live™: Keep your life in sync. See how it works. [quote][b]
PostPosted: Tue Feb 10, 2009 7:38 pm    Post subject: Engine ground on RV 10 Reply with quote
At 05:49 PM 2/10/2009, you wrote:
Hi All,
3. To the engine mount (Yes, I've read Bob's article against using
3. Other options?
subject has been nibbled around both here and on the RV 10 list, but
The big guys have been using airframes for cranking
current grounds for many, many moons. In this case,
ground crankcase to forest-of-tabs bolt with a braid
strap -AND- it wouldn't hurt to add the jumper straps
around the shock mounts like the big guys too . . .
PostPosted: Tue Feb 10, 2009 9:05 pm    Post subject: Engine ground on RV 10 Reply with quote
Bob C
Thanks for the response. Got it C two braided jumper straps. That's one less thing to obsess over!
Vern
[quote] Date: Tue C 10 Feb 2009 21:37:44 -0600
Subject: Re: Engine ground on RV 10
--> AeroElectric-List message posted by: "Robert L. Nuckolls C III" <nuckolls.bob(at)aeroelectric.com>
At 05:49 PM 2/10/2009 C you wrote:
>Hi All C
>3. Other options?
current grounds for many C many moons. In this case C
Windows Live™: E-mail. Chat. Share. Get more ways to connect. See how it works.
rv9jim(at)juno.com
PostPosted: Wed Feb 11, 2009 6:16 am    Post subject: Engine ground on RV 10 Reply with quote
Vernan,
Run a #6 wire from the forest of tabs directly to the battery
neg. term. That gives you a good source of electrons for your equipment.
Then, run a braided cable from the negative term of the battery directly
to the case of the engine. This gives you two wires to hook up to the
negative terminal of the battery. Basically, you have two wires from the
positive terminal. One is the "keep alive" wire and the other is the
main wire to the starter solenoid ect. Do not use the stainless steel
firewall as a current carrier.
Jim
____________________________________________________________
Need cash? Click to get a cash advance.
http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw1hEPyYtMguGP7lFk72hCWLzaeEGIu0lxdfvLA2mHoFbi7nb/
PostPosted: Wed Feb 11, 2009 6:50 am    Post subject: Engine ground on RV 10 Reply with quote
At 11:03 PM 2/10/2009, you wrote:
Thanks for the response. Got it, two braided jumper straps. That's
That's ONE braided jumper strap (or 2AWG welding cable
with terminals and heat-shrink) and as many thin, flat, sheet
metal bonding straps as you have shock mounts (usually
4).
( -Thomas Paine 1776- )
PostPosted: Wed Feb 11, 2009 8:06 am    Post subject: Engine ground on RV 10 Reply with quote
Bob C
The RV-10 has a ground lug welded to the engine mount.
Could I run one cable from the engine case to the this lug C and one cable from the engine case to the ground forest on the firewall? Thus eliminating the bonding straps around the lord mounts.
Vern Smith
Date: Wed C 11 Feb 2009 08:47:29 -0600
Subject: RE: Engine ground on RV 10
At 11:03 PM 2/10/2009 C you wrote:
>Bob C
with terminals and heat-shrink) and as many thin C flat C sheet
4).
( a thing wrong C gives it a superficial )
Windows Live™: Keep your life in sync. Check it out. [quote][b]
PostPosted: Wed Feb 11, 2009 8:24 am    Post subject: Engine ground on RV 10 Reply with quote
At 10:04 AM 2/11/2009, you wrote:
Could I run one cable from the engine case to the this lug, and one
About anything you want to do will function.
We can argue/discuss a host of relatively
small issues with equally small cause/effect
scenarios.
Bottom line is that hundreds of thousands of TC
aircraft have used a variety of combinations
for getting crankcases grounded. While the
stainless firewall sheet is not a GOOD conductor,
it's adequate for a very few accessories that
depended on it for ground that includes things
like contactors, voltage regulators, accessory
control relays, etc. The notion of tying the
forest of tabs to the crankcase with a fat
wire is to GROUND the forest of tabs, not
ground the engine.
The minimum impedance path from crankcase
to structure is through the engine mount
bolts at the corners of the firewall.
Since you've decided to use the fuselage
as a battery return conductor, then our
design goal might be to minimize current
on across the firewall sheet.
How about this? Leave the shock mounts alone
and add a fat-wire jumper from the forest
of tabs down to the most solid structure
available under the floorboards. I think
I like that better. This isn't going to
reduce the firewall sheet currents to zero
but they'll become a small fraction of the
total during engine cranking.
PostPosted: Wed Feb 11, 2009 8:57 am    Post subject: Engine ground on RV 10 Reply with quote
Thanks Bob C
The extra information makes sense and helps greatly.
Vern
Date: Wed C 11 Feb 2009 10:23:44 -0600
At 10:04 AM 2/11/2009 C you wrote:
>Bob C
scenarios.
stainless firewall sheet is not a GOOD conductor C
like contactors C voltage regulators C accessory
control relays C etc. The notion of tying the
wire is to GROUND the forest of tabs C not
ground the engine.
as a battery return conductor C then our
Windows Live™: E-mail. Chat. Share. Get more ways to connect. Check it out. [quote][b]
BRogers(at)fdic.gov
PostPosted: Wed Feb 11, 2009 12:12 pm    Post subject: Engine ground on RV 10 Reply with quote
Bob Nuckolls,
You said below that stainless firewall sheet is not a GOOD conductor.
Will you please quantify that statement? How much worse is it than
2024-T3 aluminum?
I have a battery in the tail of my airplane that is grounded through the
airframe, but the forest of ground tabs is on the stainless steel
firewall. Does that mean that I need to run a fat wire from the forest
of tabs attach bolt on the stainless steel firewall to some portion of
the aluminum airframe?
Bob J. Rogers
PostPosted: Thu Feb 12, 2009 5:22 am    Post subject: Engine ground on RV 10 Reply with quote
At 02:06 PM 2/11/2009, you wrote:
Bob Nuckolls,
2024-T3 aluminum?
It wouldn't hurt.
The simple answer to your question is that stainless steels are
between 10 and 30% as good a conductor of electron flow as
annealed copper. That sounds worse than it is in this case
because we're not dealing with a long, thin conductor between
point A (your battery ground) and point B (your forest-of-tabs).
Imagine if you will 1,000,000 conductors between A and B. Each conductor
is made of aluminum (A-to edge of firewall) where a piece of
stainless wire is spliced on (edge of firewall to B). While the
addition of the stainless might make the over all path resistance
of any one conductor jump by a factor of 3 to perhaps even
10x, the PARALLELED value of all those conductors is still
a rather low number.
As an example, I think I heard a number offered in a meeting
on lightning issues that the resistance of a Model 400 Beechjet
from nose to tail was on the order of 1 milliohm. Pretty low
as far as cranking engines was concerned (assuming that you
ran cranking current the length of the airplane!). In terms
of 100,000 amp lightning strikes, that 1 milliohm was quite
significant for other concerns.
If you visualize your point A to point B conduction pathway
as a wire frame made up of many paralleled paths of connected
airframe components, the whole thing is still pretty good
(with "pretty" being "terribly" non-quantified . . . terribly
isn't well quantified either).
The point is that while the stainless steel as a single entity
in a huge array of entities doesn't cause the cranking current
pathway to become useless. The concerns come with ageing
of the airframe where new rivets that were swelled up in tight
holes become less conductive with time in service and
environmental effects.
It would be interesting to get a conductivity measurement
between the center of the firewall sheet and the battery (-)
terminal of your airplane before and after adding a
fat-wire jumper. I did have occasion to measure the
battery(-) to crankcase resistance on a wrecked 172. See
http://www.aeroelectric.com/articles/grnding.pdf
Even in the bent state, the resistance was just
under 3 milliohms. Know too that the majority
of that resistance came from wire and joints in
wires use to complete the chain. The airframe
would have been a small fraction of the total.
If this sounds like an indefinite answer as to the
value of adding the jumper wire, you're right. Your
brand new airplane as-assembled will probably not
show the effects of less-than-the-best grounding.
But as a matter of experience and good practice let
me offer that I try to avoid using the firewall sheet
(indeed other parts of the airframe) as the universal
ground conductor.
This is discussed in the 'Connection and in Figure Z-15.
Adding the jumper now and then using the airframe for
grounding ONLY a few remote accessories is a good
thing to do for the owner-operator that's going to
be flying this airplane 20 years from now . . . hopefully
that's you.
rparigor(at)SUFFOLK.LIB.N
PostPosted: Thu Feb 12, 2009 12:26 pm    Post subject: Engine ground on RV 10 Reply with quote
Hi Bob"The simple answer to your question is that stainless steels are > between 10 and 30% as good a conductor of electron flow as > annealed copper. "Did you add a decimal place stating between 10 and 30% and mean 1 and 3%??According to this table:http://www.ndt-ed.org/GeneralResources/MaterialProperties/ET/ET_matlprop_Iron-Based.htmbetween 1 + 3% is more accurate??Ron ParigorisJust as a reference annealed copper is 100% and silver 106%:http://www.wisetool.com/designation/cond.htm [quote][b]
PostPosted: Thu Feb 12, 2009 3:11 pm    Post subject: Engine ground on RV 10 Reply with quote
At 02:23 PM 2/12/2009, you wrote:
Hi Bob
> annealed copper. "
Good eye! I tried to do conductance values to
percentages of resistance . . . Thanks!
MauleDriver(at)nc.rr.com
PostPosted: Thu Feb 12, 2009 5:03 pm    Post subject: Engine ground on RV 10 Reply with quote
4).
Bob, I want to do that on my RV10. I have the forest of tabs on the
firewall which has an 8AWG wire running back to the battery. I'll run a
braided jumper strap from the bolt on the forest of tabs to wherever
it's best connect it to the IO540 crankcase. And I understand it
doesen't really ground the engine as much as it grounds the forest of tabs.
But what do the 4 "thin flat sheet metal bonding straps" look like? I'm
imagining something forming an arc around the non-conductive shock
mounts but I've never seen this and can't find a reference. Can you
elaborate a bit here or point me to the photos you probably have out on
your site? Is this something I fabricate or buy?
If anyone can help me identify the ground lug on the RV10 engine mount
or the best place to attach a ground on the crankcase, I'd appreciate it.
Thanks.
Bill "ready to hang the engine" Watson
PostPosted: Thu Feb 12, 2009 7:56 pm    Post subject: Engine ground on RV 10 Reply with quote
At 06:59 PM 2/12/2009, you wrote:
<MauleDriver(at)nc.rr.com>
> 4).
Eliminate this dude. It's contribution is too
tiny to measure much less observe. Ground battery
through 4AWG welding cable to the same class of
structure as cited below . . .
I'll run a braided jumper strap from the bolt on the forest of
tabs to wherever it's best connect it to the IO540 crankcase. And
I understand it doesen't really ground the engine as much as it
Okay, add another fat-wire jumper from forest
of tabs to structure right behind the firewall.
Anyone out there got a picture of the heavy
metal under the floorboards between the rudder
pedals?
like? I'm imagining something forming an arc around the
non-conductive shock mounts but I've never seen this and can't find
a reference. Can you elaborate a bit here or point me to the photos
you probably have out on your site? Is this something I fabricate or buy?
Leave those off. We distilled this process down
a bit from the first thought about using the
shock-mount straps. It's STILL a good idea not
to use the engine mount for anything other
than holding the engine on the airplane.
mount or the best place to attach a ground on the crankcase, I'd appreciate it.
PostPosted: Sat Feb 14, 2009 7:45 pm    Post subject: Engine ground on RV 10 Reply with quote
Bob C
You asked for some pictures of the RV 10 floor boards.
Just a note C In one of the photos there is a nice heavy 3/4" angle that runs in the side wall of the aircraft for the full length (there is a splice in it back behind the baggage door.) Van's has said not to drill any additional holes in this piece C however there is a plate mount with three AN 3 bolts that hold the rudder pedal blocks (it's visible in the photo labeled SYS 010.) Maybe this would be a good place to ground the firewall ground forest?
Of course C I though about this after pulling a #2 ground up from the battery yesterday!
Hope this is of help C
Vern Smith ( #324 RV-10 finishing)
Date: Thu C 12 Feb 2009 21:54:08 -0600
Okay C add another fat-wire jumper from forest
pedals?
>mount or the best place to attach a ground on the crankcase C I'd appreciate it.
========================Windows Live™: Keep your life in sync. See how it works.
 Filesize:  48.55 KB
 Viewed:  12482 Time(s)
 Filesize:  78.51 KB
 Filesize:  71.13 KB
 Filesize:  38.29 KB
 Filesize:  51.17 KB
