Inexpensive instruments?
john.marzulli(at)gmail.co
PostPosted: Tue Feb 10, 2009 8:46 pm    Post subject: Inexpensive instruments? Reply with quote
Can anyone suggest a decent source for a VFR six pack? I was going to go with a Dynon 180, but need to scale back after an expensive engine overhaul on my C150.
I am also looking for a good deal on a com, transponder and encoder.
Used is perfectly OK.
Any ideas?
Thanks and DO NOT ARCHIVE
John Marzulli
http://www.GenevieveMarzulli.org/
http://marzulli.smugmug.com/
http://701Builder.blogspot.com/
http://www.JohnMarzulli.net/
mcjon77
PostPosted: Tue Feb 10, 2009 9:52 pm    Post subject: Re: Inexpensive instruments? Reply with quote
I don't know how inexpensive you want to get but the MGL Avionics Stratomaster Ultra EFIS can give you a complete six pack (black and white) for under $3K. If you can do without the artificial horizon it drops to under $2K. Another option are the maxi singles from the same company. With artificial horizon, it is less than $2K (about $1500 ?). Aircraft Spruce was selling refurbished Artificial Horizions for < $600 last time I checked.
Jon McDonald
Building Sonex #1287
Jon McDonald
Next up CH 701 Very Happy
PostPosted: Tue Feb 10, 2009 10:49 pm    Post subject: Inexpensive instruments? Reply with quote
There have been a few stories in the EAA rags and Kitplanes about guys building great planes for cheap. I am wondering if good deals can be had on used stuff and put together my main instruments for way less than a cheap EFIS.
DO NOT ARCHIVE
John Marzulli
On Tue, Feb 10, 2009 at 9:52 PM, mcjon77 <mcjon77(at)yahoo.com (mcjon77(at)yahoo.com)> wrote:
[quote]--> Zenith701801-List message posted by: "mcjon77" <mcjon77(at)yahoo.com (mcjon77(at)yahoo.com)>
Jon McDonald
Jon McDonald
http://forums.matronics.com/viewtopic.php?p=229682#229682
utilities such as List Un/Subscription,
://www.matronics.com/Navigator?Zenith701801-List" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
ref="http://forums.matronics.com/" target="_blank">http://forums.matronics.com
p; -Matt Dralle, List Admin.
craig(at)craigandjean.com
PostPosted: Wed Feb 11, 2009 12:14 am    Post subject: Inexpensive instruments? Reply with quote
If you are looking at the MGL EFIS (color or monochrome) check with Matt at
Sport Flying Shop (MGL/USA). He often has trade-in units.
Also a combination of an MGL Flight 2 and E-1 engine monitor can give you a
usable VFR panel in two 3.5 inch instruments for about $700. Chris Smith
flees with this in the Cleanex II (a Corvair-powered Sonex).
http://www.sportflyingshop.com/
-- Craig
dougsnash
PostPosted: Wed Feb 11, 2009 3:51 am    Post subject: Inexpensive instruments? Reply with quote
John, I can appreciate the idea of wanting to save a little money on your plane. The details do get expensive. I question the need for a full six pack of instruments in a 701. Since it was originally intended as a day VFR flier. For sure, each builder will do what they want in this regard. That is why we are into Experimental aircraft.
The other thing to think about with steam gauges is weight. I have a turn co-coordinator that I almost installed in my 701 until I read the tag that said it weighed over three pounds. I guess the gyro wheel is pretty heavy. Also you end up with the additional hassle of installing a vacuum system to run the other gyros.
I suppose that is where Dynon is making their big marketing ploy. They are cheaper than the total of all six instruments (new) and they weigh a lot less. For cost, you can always check out E-Bay but of course, "Buyer Beware". You never really know what it is you are getting there.
Best of luck with your build
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
--- On Wed, 2/11/09, John Marzulli <john.marzulli(at)gmail.com> wrote:
Subject: Re: Re: Inexpensive instruments?
Date: Wednesday, February 11, 2009, 12:46 AM
about guys
deals can be had on
less than a cheap
EFIS.
DO NOT ARCHIVE
John Marzulli
