henrysfork1(at)msn.com Guest
Posted: Wed Feb 11, 2009 4:09 pm Post subject: KFM Battery Size |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Which battery should I be using?
Dee Young
Model II
N345DY
Posted: Wed Feb 11, 2009 4:39 pm Post subject: KFM Battery Size |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> The 14-BS battery does not have enough cold cranking amps to spin the KFM when its cold out.
Dee Young
Model II
N345DY
Clint says -
I am using a 14-BS battery that you can get a any auto supply store. I change it out every 2 years, but wouldn't have to. Weighs in at 10 1/2 lbs. Works very well on my 912ULS with high compression. Its true, haven't had it at real low temp, about 20F with snow lowest. Less then half the size. And I am sure a lot cheaper.
Clint
Paul A. Franz, P.E.
Posted: Wed Feb 11, 2009 7:30 pm Post subject: KFM Battery Size |
On Wed, February 11, 2009 4:38 pm, Dee Young wrote:
| Quote: | The 14-BS battery does not have enough cold cranking amps to spin the KFM when its
cold out.
Here's some battery information from Bob Nuckolls Aeroelectric connection:
<http://www.aeroelectric.com/Reference_Docs/Battery/>
I believe the current best practice is to have two small batteries where one is
changed out every year. You size batteries such that you have enough reserve to
complete the intended flight operation. This requirement is normally for more reserve
than cold engine cranking.
I am going to follow Bob's recommendations for wiring, contactors and redundancy.
If you cannot find the precise battery information you need by searching the
aeroelectric archives, then post the request on the forum.
Bob has a FAQ that is over 300 pages long that answers questions by category.
<http://www.aeroelectric.com/FAQ/AeroElectric-List/AeroElectric-List_FAQ.pdf>
Batteries, contacters and OV protection are among the subjects covered.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Posted: Wed Feb 11, 2009 8:22 pm Post subject: KFM Battery Size |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I am not sure any of you are that familiar with the KFM. The engine is hard starting when cold and requires 300 rpms to trigger the mags. If the battery can't spin the engine in 0 degree weather then it will not start. End of story. The Odyssey does a good job for me and I am pleased with its performance.
Dee Young
Model II
N345DY
Roger Lee
Posted: Thu Feb 12, 2009 8:07 pm Post subject: Re: KFM Battery Size |
They use the Odyssey PC310 in the Flight Design with the Rotax 912ULS. I have had mine over 2 years now and no issues. It is a military spec battery.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Fri Feb 13, 2009 5:40 am Post subject: KFM Battery Size |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Roger do you think this battery would have a enough zip to spin a cold engine (at) 0 degrees?
Dee Young
N345DY
Model II
Roger Lee
Posted: Fri Feb 13, 2009 6:58 am Post subject: Re: KFM Battery Size |
Yes I do. Many Flight Design pilots living around the world live in climates that cold or worse. The Oddyssey battery is a very good battery, but it also likes to be charged. Two things that make the starting process much easier. Keep the battery charged. If you fly once a week or more no problem, but if it's once every 4 weeks put a float charger on it. Second keep the oil/engine warm before starting. There are several ways people do this. Really cold oil even though it still pours may slow the engine rotation just enough to keep it from firing especially if the battery is down some also. If you don't keep the battery charged and a very cold engine then you may have an issue.
Tucson, Az.
Cell 520-349-7056 |
Posted: Fri Feb 13, 2009 7:34 am Post subject: KFM Battery Size |
I am using the Odyssey 925 but Clint says its like putting a golf cart battery in a Cessna. I take that to mean it must be way to small???? I know what you mean about the cold engine and oil but your telling me I need a smaller battery. Why would a smaller battery be better????
Dee Young
N345DY
Model II
akflyer
Posted: Fri Feb 13, 2009 8:43 am Post subject: Re: KFM Battery Size |
| Roger Lee wrote: | | Yes I do. Many Flight Design pilots living around the world live in climates that cold or worse. The Oddyssey battery is a very good battery, but it also likes to be charged. Two things that make the starting process much easier. Keep the battery charged. If you fly once a week or more no problem, but if it's once every 4 weeks put a float charger on it. Second keep the oil/engine warm before starting. There are several ways people do this. Really cold oil even though it still pours may slow the engine rotation just enough to keep it from firing especially if the battery is down some also. If you don't keep the battery charged and a very cold engine then you may have an issue. |
Anytime it is below freezing we preheat the 4 stroke engines. Using a red dragon and cowl blanket, I can take a 0320 from -20 to 110 degrees in about 25 minutes.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Lynn Matteson
Posted: Fri Feb 13, 2009 9:51 am Post subject: KFM Battery Size |
I've seen some VERY big golf cart batteries....are you sure that your
interpretation of what Clint said is correct? Maybe he could offer
another analogy to clear up the issue.
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
New skis done and flying
On Feb 13, 2009, at 10:33 AM, Dee Young wrote:
[quote] Roger
Dee Young
N345DY
Model II
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Fri Feb 13, 2009 11:16 am Post subject: KFM Battery Size |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> That might be good.
clint_bazzill(at)hotmail. Guest
Posted: Fri Feb 13, 2009 11:33 am Post subject: KFM Battery Size |
I looked up KFM 112M C a small engine. Its starter is .44 KW. A good 14AH battery should be fine. Has 200 CCA C how much do you need. I wouldn't want to start an expensive aircraft engine cold at 0 degrees without preheat.
Clint
Subject: Re: Re: KFM Battery Size
Date: Fri C 13 Feb 2009 12:14:15 -0700
That might be good.
Fox5flyer Guest
Posted: Fri Feb 13, 2009 12:19 pm Post subject: KFM Battery Size |
I thought he was implying you had way too much battery for the airplane. Might be wrong though.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
thesupe(at)hotmail.com Guest
Posted: Fri Feb 13, 2009 12:24 pm Post subject: KFM Battery Size |
Think of an electric golf cart. Large battery indeed. Jim Chuk Avid MK IV Mn
That might be good.
Posted: Fri Feb 13, 2009 1:47 pm Post subject: KFM Battery Size |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> sorry but I don't play golf and have never seen a golf cart battery. Thanks
Posted: Fri Feb 13, 2009 2:04 pm Post subject: KFM Battery Size |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I don't like starting at cold temps. either but I live where its cold. If your going to fly there are times you have to be able to start your plane in the cold or you will stay on the ground all winter. I can tell you for sure the engine will not fire at 20 degrees with a small battery I know that from experience. However I am willing to try what you suggest and will save your post for reference.
Thanks to all who have commented.
Dee Young
N345DY
Model II
akflyer
Posted: Fri Feb 13, 2009 2:56 pm Post subject: Re: KFM Battery Size |
[quote="henrysfork1(at)msn.com"]<xml><xml><endif> I don't like starting at cold temps. either but I live where its cold. If your going to fly there are times you have to be able to start your plane in the cold or you will stay on the ground all winter. I can tell you for sure the engine will not fire at 20 degrees with a small battery I know that from experience. However I am willing to try what you suggest and will save your post for reference.
Dee Young
N345DY
Model II
look up red dragon or engine preheater.. will save you lots of wear and tear on your engine.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
lcfitt(at)sbcglobal.net Guest
Posted: Fri Feb 13, 2009 4:54 pm Post subject: KFM Battery Size |
Out of town on a borrowed computer and pretty much lurking, but since no one brought it up, there have been lots of battery size discussions in the past.
I think Clint touched on it a bit if it was him that mentioned CCAs. I have read that in certain instances, a large battery can sometimes have poorer cranking ability due to internal resistance than a smaller battery. To start an engine you need to know the current it will provide in a hurry Cold Cranking Amps. Size generally relates to how long a battery will send out any current at all as in the case where you have electronic ignition on both sides and the alternator fails. Here you don't want a tiny battery or only one, for that matter.
As far as I recall, here on the list, most large batteries were selected to be used as ballast to correct W / B issues enabling the builder to use a weight with some usefulness rather than a simple dead weight lead block. I would suggest that if a normally sized battery is not cranking as it should, check the wire size, the size of the terminals and bolts and check the bolts for security. Keep in mind as well, that a cold battery will not be as efficient as a warm one. I have heard of folks in the cold who couldn't get the car to crank turning on the headlights to get a little chemistry going in the battery to warm it a bit. Not being a cold - cold weather dweller, I can't speak with experience on this idea or the other special circumstances found up north.
Lowell
St. Augustine - don't need to warm anything right now
--- On Fri, 2/13/09, akflyer <akflyer_2000(at)yahoo.com> wrote:
| Quote: | From: akflyer <akflyer_2000(at)yahoo.com>
Subject: Re: KFM Battery Size
Date: Friday, February 13, 2009, 2:56 PM
| Quote: | --> Kitfox-List message posted by: "akflyer"
[quote="henrysfork1(at)msn.com"] I don't like starting at cold
Dee Young
N345DY
Model II
your engine.
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p 30166#230166
Float Flyr
Posted: Fri Feb 13, 2009 7:02 pm Post subject: KFM Battery Size |
It’s story time.
When I was in technical school a couple of my instructors told this little story about a couple of guys flying a couple of Aero Commanders through Goose Bay Labrador to Europe.
After a frosty night, that’s frosty for Labrador, the two guys went out to their planes and were doing their walk around when the mechanics turned up and offered then a hot shot start for $25. Ea. ($12.50/engine) A real bargain.
The mechanics were told that the planes didn’t need preheating and the guys didn’t like to be taken advantage of.
The two guys got into their planes and started their pre start checks and both started their engines almost in unison. As their second engines fired up the first engines started to spew oil all over the shiny airplanes. Before they noticed that they had lost all the oil in their first engines the second engines blew and they were left there on the apron with two beautiful planes covered in black mucky oil.
Then they went looking for somebody to fix their planes... Yup the two mechanics were the only civilians for around a thousand miles with no roads who were certified to do the work. Each engine cost close to $2000.00 U.S. . As one of the guys told me pay me now or pay me more later.... much more, a little later!
What happened is the oil coolers didn’t have pressure by passes and with the oil hovering around -40 C or F pressure in the coolers quickly built up and caused the coolers ($600.00 U.S.) to blow The engine compartments had to be cleaned ( the guys were allowed in the hangar to clean the rest of the mess) and the whole systems had to be tested. ( both mechanics had U.S. IA ) as per the engine manufacturers MM.
Add the cost of flying in parts, hotel rooms etc they still got a real deal.
My point is that just because your engine starts not all is well in the State of Denmark. Be careful of the cold starts. Remember the worst thing you can do to an engine is to start it. So if you must start an engine and we all must, we should try to make the starts as easy as possible on the engine.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
