lgold(at)quantum-associat Guest
Posted: Fri Feb 13, 2009 9:18 am Post subject: Carb Calibration |
It be nice if we could put a single small sensitive gauge in our panels that
could tell us when our 912 carbs were out sync and allow us to make
adjustments without having hook up temporary gauges "under the hood". Yes,
I know we can feel it when the carbs are not in sync, but if they are just a
little off, or when I am not certain if a rough running engine is due to
sync problems, a panel instrument would be very helpful. Does such a dual
pressure differential gauge/sensor exist?
Les
m.tucciarone(at)hotmail.c Guest
Posted: Fri Feb 13, 2009 12:03 pm Post subject: Carb Calibration |
Yes,
I have thought of the same thing but that would be some long vacuum hoses
for me. I have an Aventura II and the engine is up in the back on the wing.
I wonder if it would work?
Roger Lee
Posted: Fri Feb 13, 2009 9:58 pm Post subject: Re: Carb Calibration |
Sorry guys, won't work. You have the cross over balance tube from carb to carb. That would throw off any real worth while reading.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Dick Maddux
Posted: Sat Feb 14, 2009 5:44 am Post subject: Carb Calibration |
I am in total agreement with an in panel gauge. Maybe you could come up with some sort of valve in the cross tube(of course it would probably leak air). I have a knob on the back of one of my throttle cables and can make micro adjustments on the carb sync without ever getting out of the aircraft.It does a great job of syncing one carb to the other. But alas, I have to have the gauge(I use a Twin Max) to get it "on the money"
Maybe someone will invent something.
Dick Maddux
Kitfox 4
Rotax 912UL
Pensacola,Fl
Nothing says I love you like flowers! Find a florist near you now.
Float Flyr
Posted: Sat Feb 14, 2009 10:34 am Post subject: Carb Calibration |
You would have to also install a centre valve in the cross tube to be able to shut down the cross flow make a reading. As for leaks not properly installed. My beef would be more weight.
Noel
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com
Sent: Saturday, February 14, 2009 10:09 AM
To: rotaxengines-list(at)matronics.com
Subject: Re: Carb Calibration
Dick Maddux
Kitfox 4
Rotax 912UL
Pensacola,Fl
Nothing says I love you like flowers! Find a florist near you now. | Quote: | | http://www.matronics.com/Navigator?RotaxEngines-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
