Windscreen Demister
ghiggins(at)cirruscomms.c
PostPosted: Sat Feb 14, 2009 3:05 pm    Post subject: Windscreen Demister Reply with quote
Hi Europaphiles,
Has anyone felt the need for a demisting system in their Europa? If so,
under what conditions?
Has anyone who has devised a cabin heating system included demisting as part
of this?
Have you ever used it in anger?
I am considering my cabin heating system from the hot air at the back of the
radiator, and wondering if I should include any demisting while on the job -
don't want to have to come back later to do it.
Regards Graham Higgins, #261 in Oz
PostPosted: Sat Feb 14, 2009 3:48 pm    Post subject: Windscreen Demister Reply with quote
paul.the.aviator(at)gmail
PostPosted: Sat Feb 14, 2009 3:53 pm    Post subject: Windscreen Demister Reply with quote
Hi Graham,
I blow cold air onto my windscreen and it does a nice job of
defrosting. If you take a took at
http://www.europa.net.nz/363/index.html under June 2002 you can see
the vents I made.
December 2003 shows the manifold for the ducts on the instrument panel.
You can see the SS heat box on the fire wall under January 2004.
The hose lay out can be seen under Friday 20th on February 2004.
If you click on the sidebar under flying experiences you will find a
link on how I did my cockpit heat.
Cheers, Paul
ptag.dev(at)tiscali.co.uk
PostPosted: Sat Feb 14, 2009 3:54 pm    Post subject: Windscreen Demister Reply with quote
Hi! Graham,
Very occasionally on start up without the knee vents open and "TWO UP" I
have had misting up and once at 10,000ft without my hot air pick up
switched on when I had the screen begin to freeze over also "two up".
However my being in the UK and perhaps you being in OZ you my have
different considerations.
Bob Harrison. G-PTAG
budyerly(at)msn.com
PostPosted: Sat Feb 14, 2009 6:53 pm    Post subject: Windscreen Demister Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Graham,
My website has a view of the method I use for my customers heaters. Like most systems off the coolers, it varies the temp with the engine, outside air and velocity. Normally very good at 120 kias at 30 degrees F or above.
As for demisting, most avionics put off enough heat that a small fan blowing air from the passenger well and exiting through a hole above the instruments (on top of the panel, in front of the pilot) works well for our modest temps here in the SE US. Jerry Hope said it best, "might as well cool the instruments and keep the windscreen clear!" He used a small computer cooling fan of 12 volts sucking air from the curved portion on the passenger side behind his radios and it blows across his stack, and it exits out the top quite well.
Bud Yerly
Custom Flight Creations
Website: customflightcreations.com
g-iani(at)ntlworld.com
PostPosted: Sun Feb 15, 2009 3:05 am    Post subject: Windscreen Demister Reply with quote
A small computer fan works well. See attached, The recessed aerial is for my Skymap IIIc and mount is for my PCAS unit.
Ian Rickard G-IANI XS Trigear, 200 hours
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
 Filesize:  167.46 KB
 Viewed:  3520 Time(s)
air.guerner(at)orange.fr
PostPosted: Sun Feb 15, 2009 3:49 am    Post subject: Windscreen Demister Reply with quote
Graham,
I have installed a demisting system using a glassfiber plenum under the top of panel module (see attached picture). Hot air comes from the heating system which takes air behind the radiator and exits through 6 holes (7 millimeters diameter) at the bottom of the windscreen. It works well in flight but is not very effective on the ground were it is the most needed. A fan would certainly help for ground use.
Hope that helps.
Remi Guerner
F-PGKL
of this?
Regards Graham Higgins, #261 in Oz <<<<<<<<
 Filesize:  1.43 MB
Trevpond(at)aol.com
PostPosted: Sun Feb 15, 2009 4:54 am    Post subject: Windscreen Demister Reply with quote
Hi Graham,
I put a large fan to the rear of my instrument panel so that air will be drawn into the bottom and cool the avionics and Efis. I cut 2 slots into the instrument nacelle and the air exhausts nicely to the screen and keeps it fog free. Two for one!
kind regards
Trev Pond
G-LINN
loboloda(at)execulink.com
PostPosted: Sun Feb 15, 2009 6:41 am    Post subject: Windscreen Demister Reply with quote
Graham,
I've used a small computer fan, cost about $4 as a surplus item. I fitted an on/off switch, but to date it has always been on.
I've had no misting problems with this in use, and it does get cold up here.
Dave C-FBZI
On 14-Feb-09, at 9:46 PM, ALAN YERLY wrote:
[quote] Graham,
Bud Yerly
