Dave Bigelow
Joined: 29 Jan 2006 Posts: 103 Location: Kamuela, Hawaii
Posted: Sat Mar 18, 2006 9:27 pm Post subject: Ethanol/Gasoline Mixture |
The State of Hawaii Legislature (in their infinte wisdom/ignorance) has passed a law that mandates all automotive gas sold in the state after April 1st will consist of 10% ethanol. This sounds like a nice green thing to do, but from a technical standpoint is bogus. First thing is that it takes more energy to produce a gallon of ethanol than the gallon of ethanol will produce. Add to that the fact that a gallon of ethanol has only 75% of the engergy of a gallon of gas, and also has a fuel system damaging affinity for absorbing water. The whole thing is a feel good tax payer subsidy of the local sugar industry. End of rant!
Now, the reason for this post is tap some of the great amount of experience on this list. What kind of experience have you had running a gas/ethanol blend in two stroke engines? Is the power loss noticible? Is re-jetting needed? Have you had problems with water laden fuel gumming up the carbs?
Maybe "Sea Foam" will solve the whole problem.
_________________ Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E |
grageda(at)innw.net Guest
Posted: Sat Mar 18, 2006 10:40 pm Post subject: Ethanol/Gasoline Mixture |
Hi Dave,
I work in the recreational boating industry and have seen first hand what
alcohol and water can do to fuel systems.
Gasohol is not a good thing. The alcohol in gasoline can damage rubber
components in your fuel system, i.e the diaphragm in the fuel pump for one
example.
It might cost a bit more but, you may have to use 100LL av-gas to stay away
from the alcohol. This my require a re-jetting of the carb, slightly leaner
I believe.
If you must use gasohol then I suggest you check your fuel system components
very frequently to make sure the rubber parts of your plane are in good
condition. The gasohol will attack the rubber parts and cause little bits of
rubber to break off and clog your fuel system.
I imagine you have to fly over water alot because of your island location.
Avgas may be your only practical solution to keep your peace of mind over
water.
Good luck
Carlos G.
ultrastarrick(at)yahoo.co Guest
Posted: Sun Mar 19, 2006 6:50 am Post subject: Ethanol/Gasoline Mixture |
Hi I work on 2 stroke race motors and have discover that the ethanol cleans the oil from the bearings a little to good and most of the time causes abnormal wear.
Dave Bigelow
Kamuela, Hawaii
FS2, Rotax 503 DCDI
http://forums.matronics.com/viewtopic.php?p=22593#22593
Bring photos to life! New PhotoMail makes sharing a breeze.
Roger Lee
Posted: Sun Mar 19, 2006 10:04 am Post subject: Re: Ethanol/Gasoline Mixture |
In Arizona we have had that fuel for many years now and it is used during the winter months. They are now going to get rid of it from what I hear. I have used this for many years and you should not notice any difference. When I had my Rotorway 162F helicopter they recomended that we not use it because Rotorway thought it was hard on some of their seals and rubber parts. Didn't seem to make a difference. I use it now in my 912S. In Arizona they switch back to the regular fuel during the warmer months.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Dave Bigelow
Posted: Sun Mar 19, 2006 1:24 pm Post subject: Re: Ethanol/Gasoline Mixture |
I'm finding more and more on the subject of blended ethanol/gas as I go - most of it not good. Here's a very good research paper done by Onan Engines in Australia that Jim Baker recommended:
http://www.deh.gov.au/atmosphere/fuelquality/publications/review-non-automotive/pubs/review.pdf
Here's what Rotax has to say:
*OXYGENATES (ALCOHOL ADDITIVES) ARE TO BE AVOIDED, ANY VOLUMES OVER 5% CANNOT BE USED. TESTING FOR ALCOHOL IS THE ONLY SAFE WAY TO BE SURE YOUR FUEL IS O.K. FOR USE IN YOUR ROTAX. A SIMPLE TEST KIT FOR DOING THIS IS AVAILABLE THROUGH AUTHORIZED DISTRIBUTORS OF MOGAS FOR AIRCRAFT. CONTACT YOUR LOCAL EAA FOR YOUR NEAREST MOGAS DISTRIBUTOR. THE ILL EFFECTS OF ALCOHOL IN YOUR ENGINE ARE AS FOLLOWS; THE ALCOHOL WILL ATTRACT WATER, THIS CAN CAUSE YOUR SEDIMENT TRAPS TO FLOOD, PLUG FILTERS AND RESTRICT FUEL FLOW. ALSO, AND VERY IMPORTANT, THE ALCOHOL COMPETES DIRECTLY WITH THE LUBRICATION, AND DEPENDING ON YOUR OILS ABILITY TO COMBAT SUCH, COULD CAUSE ENGINE DAMAGE IMPORTANT ALSO IS THE ALCOHOL CARRIES WATER WHICH ON ENGINE SHUT DOWN AND STORAGE CAN CREATE CORROSION ON VITAL ENGINE PARTS SUCH AS CRANK MAIN AND ROD BEARINGS AS WELL AS PINS. ONCE CORROSION PITS HAVE STARTED, THE BEARINGS WIU FAIL SHORTLY AFTER. *SEASONAL BLEND CROSSOVERS CAN EFFECT YOUR FUELS VOLATILITY IF YOU USE A WINTER BLEND FUEL DURING A HOT SUMMER DAY. THIS IS A COMMON OCCURRENCE WITH PEOPLE WHO BUY A FUEL BLEND IN COLDER CLIMATES IN MARCH, BUT DON'T USE IT IN THEIR ROTAX UNTIL JUNE. EVAPORATION TEMPERATURES OF YOUR FUEL MUST BE LOW ENOUGH TO MINIMIZE CRANKCASE AND COMBUSTION CHAMBER DEPOSITS AS WELL AS SPARK PLUG FOULING WITHOUT FEAR OF VAPOUR LOCKING OR BOILING. ALWAYS MAKE SURE YOU BUY YOUR FUEL FROM A HIGH VOLUME USER, AND AVOID FUELWHICH HAS BEEN IN STORAGE FOR LONG PERIODS OF TIME, ESPECIALLY BETWEEN SEASONS. LOSS OF OCTANE RATING IS A COMMON PROBLEM ON FUEL STORED INCORRECTLY, WHICH COULD LEAD DIRECTLY TO ENGINE STOPPAGE.
Guess my only choice here in Hawaii will be to use avgas - any tips regarding the use of avgas in 2 stroke engines?
Kamuela, Hawaii
FS2, HKS 700E |
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Sun Mar 19, 2006 6:44 pm Post subject: Re: Ethanol/Gasoline Mixture |
Dave,
I have the same choice and I have tried both. LL100 costs over a dollar more than auto gas, and it fouls the plugs in 20 hours. Currently, I am using auto gas with 10% ethonal. At least I have oil injection. That might help some.
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
by0ung(at)brigham.net Guest
Posted: Mon Mar 20, 2006 10:29 am Post subject: Ethanol/Gasoline Mixture |
most
Australia
that Jim Baker recommended:>>>>>>>>>>>>>>>>>>>>>>>>
I will throw this out and see what ya all say bout it.
The simple test for alcohol in gas is fill a test tube 1/2 with water and
mark the level on the outside. Then fill the remainder of the test tube
with gas. Shake it up and let it settle. If there is alcohol in the gas
the level of the water will go up from the mark. The difference will be the
amount of alcohol that was in the gas. Now if you pour the gas off the
top, you should have alcohol free gas. With a water alcohol mix left over.
If this principle works?????? You could use a 50 gal test tube. And render
out 20 to 25 gal at a time.
Alcohol should attract an equal amount of water before it will separate out
of the gas.,,,, 10% of say 50 gal should be 5 gal.... you would probably
want to start with 10 to 15 gal of water then fill the 50 gal test tube (
DRUM ) with gas. If you prop the tank up on edge and siphon out the water
from the bottom till the gas starts to run clear. Using the last bit to
start your next batch. You should be left with the good stuff.
My daughters father-in-law, drives a 18 wheeler gas carrier, and tells me
that the storage tanks where he gets his gas will have 2 ft of water in the
bottom... but when they fill his truck they draw the fuel out at the 5 ft
level. Now if they were using alcohol in the gas this would not work.
Also when they pump petroleum products through underground pipelines they
use thousands of gallons of water to separate the different grades of fuel.
When the operator sees the difference in color he will switch the fuel from
one tank to the other. and the water will separate out in the bottom if the
large storage tanks.
Maybe it is easier to buy av gas or av gas mixed 50/50 with mogas. That
would take a 10 % mix down to 5%.
Worth every cent you paid fer it.
Boyd
Do not archive.
Dave Bigelow
Posted: Mon Mar 20, 2006 6:07 pm Post subject: Re: Ethanol/Gasoline Mixture |
Interesting idea, Boyd.
I wonder if the water grabs all the alcohol, or leaves some behind. I remember reading about this test 15 or 20 years ago in Untralight Flying magazine when "gasohol" was the rage. Actually, the idea of using a 50 gallon drum to separate out a supply of real gas might just work.
So, the question remains about what to do with the ethanol/water mixture left over? Could you drink it? Perhaps you could sell it to the "Sea Foam" company?
Kamuela, Hawaii
FS2, HKS 700E |
Posted: Tue Mar 21, 2006 8:53 am Post subject: Ethanol/Gasoline Mixture |
remember
when
separate
left over?
Dave Bigelow
Kamuela, Hawaii
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>
I would be quite sure the ethanol would be de natured. So I would not drink
it. maybe you could sell it back to the gas station. however a contract
with the fine folks at SF would be good if the shipping cost did not run
more than the purchase price. maybe they could find a use for it.
Seriously,,, the amount of alcohol it would remove would depend on the
contact time and the level of mixing. If you could pick up the container
and give it a good shake I am sure it would separate faster/more completely.
I have thought that if you could find a half gallon of 10% ethanol gas and
pour into 16 gal of gas dropping the % of ethanol to less than 1%. That
way it would remove any condensation that may have accumulated in the fuel
system. And hopefully it would not affect the components in the carb.
Boyd
