trock07(at)austin.rr.com Guest
Posted: Mon Feb 16, 2009 9:00 am Post subject: Fuse or Current Limiter on SeaRey amphib? |
A friend of mine, who is not on the list and built a SeaRey amphibian, wanted me to ask the following question.
"Reference Figure Z-15, Ground Systems (Sheet 1/2), Rev K, 04/20/05 - Why no fuse or current limiter at the battery terminal or battery contactor to protect the 2AWG wire from a dead short along the distance back to the engine/alternator on a pusher/seaplane? (In his case that distance is 15'.)
Ken Firestone
mrspudandcompany(at)veriz Guest
Posted: Mon Feb 16, 2009 10:20 am Post subject: Fuse or Current Limiter on SeaRey amphib? |
Ken Firestone
[quote] This has been discussed on several occasions on this list. You can search the archives. It has always been common practice for TC and experimental aircraft to not fuse the Fat Wires. If reasonable care is taken to install them correctly, then the risk is exceedingly low. Roger[b]
mprather(at)spro.net Guest
Posted: Mon Feb 16, 2009 10:49 am Post subject: Fuse or Current Limiter on SeaRey amphib? |
It's not clear from the description of the SeaRay's architecture, but it
sounds similar to many production (and owner-built) airplanes. My 182 has
its battery located behind the baggage compartment. The contactor is
mounted to the battery box, and then there's a long run of heavy gauge
wire to the starter contactor and other buses near the front of the
airplane.
The rationale is that the contactor provides protection for that wire. If
you smell smoke, you turn off the master - de-energizing the heavy wire.
It's exceedingly unlikely on any single flight that you'd lose control of
the contactor (not being able to make its output cold), _and_ have a hard
fault on the heavy cable.
Matt-
no
15'.)
Ken Firestone
aircraft
Roger
