AirMike
Posted: Tue Feb 17, 2009 4:55 am Post subject: Tie rods on baffles and chafe |
I am trying to install the tie rods on the bottom of the engine and am getting interference from the aluminum oil lines down there. Is there an anti-chafe material that I can use there or do I have to cut new oil lines to avoid any contact with the tie rods. It seems like kind of a foolish system for controlling the baffles. Why not just screw tabs on each cylinder?
_________________ See you OSH '18
Q/B - sold. |
dlm46007(at)cox.net Guest
Posted: Tue Feb 17, 2009 5:17 am Post subject: Tie rods on baffles and chafe |
High temp spital wrap from McMaster Carr
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Tue Feb 17, 2009 8:01 am Post subject: Re: Tie rods on baffles and chafe |
I don't have the plans here but if I remember correctly, the plans calls for cutting some of the provided clear plastic tubing.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Deems Davis
Posted: Tue Feb 17, 2009 8:39 am Post subject: Tie rods on baffles and chafe |
Slip a length of tubing over the tie rods. The lower parts of the
baffles don't have to be perfect .... tighten the nuts to snug the
aluminum up but not stretch the tab. Also, use washers under the nuts
(bigger is better) and Locktite one nut so that you can remove the other
nut and slip the tierod out.
Linn
AirMike wrote:
OSH '08 or Bust (busted) be there in "09
Q/B Kit - wiring and FWF
http://forums.matronics.com/viewtopic.php?p 30636#230636
AirMike
Posted: Tue Feb 17, 2009 8:10 pm Post subject: Tie rods on baffles and chafe |
Note that the build manual seems to recommend that you use the supplied plastic pipe (it only says something about 1/4" tube. )
The supplied tube that I see is Parker Parflex N 1/4" x .035 tube.
This tubing is only good to 193 degrees if it is the Nylon tube shown in Parker's manual.
Correct me if I am wrong......please
Q/B - sold. |
Dave(at)AirCraftersLLC.co Guest
Posted: Tue Feb 17, 2009 8:54 pm Post subject: Tie rods on baffles and chafe |
Mine melted like wax. But somehow the tie rod doesn't rub the oil lines, so
the tubing isn't needed in my case. But those lines are pretty delicate and
if anything is close to touching them, then you'll have to do something to
prevent contact..
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
