ron.mcgann(at)baesystems. Guest
Posted: Fri Feb 20, 2009 10:39 pm Post subject: First Engine start |
First engine start today - what a buzz. Ranks better than first panel checks and having the smoke stay in the wire.
Not quite without incident. I had previously removed the bottom plugs and spun the prop to preoil the engine. The new Concorde battery had no problem turning an engine with no compression. Left the battery on charge overnight knowing a few starts may be required. The battery had barely enough cranking capacity to kick the engine. May need to go to a couple of Odysseys in parallel. With battery sorted, the engine still would not fire. Found I needed to remove the fuel injector lines to the cylinders and run the boost pump to flush the lines. Once the lines were clean and free of air, she fired with little trouble.
Did not take it over 1500 rpm for the first run (only 2-3 mins), but even 1t 1500 she was screamin' to get over the chocks. Just the W&B and paperwork to do.
On a high - had to share.
cheers
Ron
-187
[quote]"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Sat Feb 21, 2009 4:43 am Post subject: Re: First Engine start |
Ron,
That's great! Nothing like the roar of an IO-540 to get you blood pumping. It must be nice to be that close. Any idea why the Concorde had so much trouble? It should have enough oomph to turn it over.
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
rv10free2fly(at)yahoo.com Guest
Posted: Sat Feb 21, 2009 3:27 pm Post subject: First Engine start |
A great achievement Ron, well done.
Pat
VH-XPP - South oz
Sent: Saturday, 21 February, 2009 5:06:26 PM
Subject: First Engine start
cheers
Ron
-187
| Quote: | "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." //www.matronics.com/Navigator?RV10-List" target=_blank rel=nofollow>htt="http://forums.matronics.com/" target=_blank rel=nofollow>http://for= --> http://www.matronics.com/contribution
Stay connected to the people that matter most with a smarter inbox. [url=http://au.rd.yahoo.com/galaxy/mail/tagline2/*http://au.docs.yahoo.com/mail/smarterinbox]Take a look[/url]. [quote][b]
Mike Whisky
Posted: Sun Feb 22, 2009 11:07 am Post subject: Re: First Engine start |
Congratulations Ron,
I can't wait when I will do the same but that will take one more ear I believe.
All the best from freezing Switzerland
Michael
_________________ RV-10 builder (flying)
#511 |
