frans(at)paardnatuurlijk. Guest
Posted: Fri Feb 20, 2009 9:44 am Post subject: Coolant temperature indicator |
Hi all,
I would like to have an indicator for the coolant temperature. However,
there seems to be no connection point for a temperature sender. It seems
to me that some of you have installed a coolant temperature indicator.
If so, how have you achieved this?
In some of the pictures in the album (forgot which one), I noticed that
there are coolant "tanks" with a sensor hole in it, but mine does not
have this provision.
Best regards,
Frans Veldman
Ivor Phillips
Posted: Fri Feb 20, 2009 10:25 am Post subject: Coolant temperature indicator |
Hi Frans
You use a 2 inch aluminium Pipe with a sensor, similar to
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=ROAD&pcode=GLOHA25
You fit this on the outlet pipe on top of the engine as high as you can,
this will give you the most accurate readings,
regards
Ivor
---- Frans Veldman <frans(at)paardnatuurlijk.nl> wrote:
Quote: |
Hi all,
Best regards,
Frans Veldman
danny shepherd
Joined: 27 Jan 2006 Posts: 117 Location: north Wales, United Kingdom
Posted: Fri Feb 20, 2009 10:27 am Post subject: Coolant temperature indicator |
Hi Frans,
I fitted a coolant temperature gauge from Skydrive UK. skydrive.co.uk The complete kit was about 50 UK pounds. Works very well.
Danny G-c.e.r.i
Frans Veldman wrote: [quote] Quote: | --> Europa-List message posted by: Frans Veldman <frans(at)paardnatuurlijk.nl> (frans(at)paardnatuurlijk.nl)
Hi all,
| [b]
rampil
Posted: Fri Feb 20, 2009 1:15 pm Post subject: Re: Coolant temperature indicator |
Lockwood and CPS also such items. You have to simply slice the coolant hose, remove an inch or so, insert the T-adapter in place of the slice, and
install the transducer which is usually NPT.
Your local Rotax dealer should have the parts
paul.the.aviator(at)gmail Guest
Posted: Fri Feb 20, 2009 5:10 pm Post subject: Coolant temperature indicator |
Hi Frans,
I suspect that picture you saw of a coolant tank with a sensor mounted
in it was a modified unit that Cliff Shaw made. I did something
similar. I took my tank to the Lincoln Welder demonstration stand
last year at the Oshkosh airshow and had them weld a patch of aluminum
on it to make it thicker so I could put a NPT thread in it. Although
this approach is more elegant than putting in a T in the host, it does
require a whole lot more effort.
Just as an FYI, Grand Rapids also sell a T along with the appropriate sensor.
Regards, Paul
Posted: Sat Feb 21, 2009 12:57 am Post subject: Coolant temperature indicator |
Hi Paul,
Quote: | I suspect that picture you saw of a coolant tank with a sensor mounted
Yes, I think I saw one of these.
It does indeed. I will have to make my mind up for this.
BTW, how much information does this coolant temperature indicator
provide, if you also have cylinder head temperature indicators? Is it
overkill, or does it make sense?
Best regards,
Frans Veldman
Posted: Sat Feb 21, 2009 6:34 am Post subject: Coolant temperature indicator |
Hi Frans,
I am in the fortunate situation where I had a couple of coolant tanks
that was among a bunch of Rotax parts that I purchased from a guy who
was doing research and development for the military in the '90's.
I haven't actually installed mine yet, but the engine is currently in
at the Rotax dealer to have some oil leaks repaired and I will have it
installed at that time. I have a Grand Rapids EIS that has inputs for
two CHT's and the water sensor so it is an easy task for me to
instrument it.
Rotax discusses the combination of CHT's and coolant temperature
measurement in a recent SB about reverting back from Evans to a water
glycol mix. I would suggest that you read through the SB, I think it
should cover most questions.
In my opinion measuring coolant temperature makes a lot of sense, it
gives an earlier warning of issues in the case of a burst hose or
coolant boiling. Graham Singleton often tells me that if he had
coolant temperature sensing in his aircraft he would have known about
his pending issue and not taken off and had his subsequent accident.
If your airplane isn't flying yet, then the effort is a lot less, if
it were me I'd probably just go do it.
Regards, Paul
Posted: Sun Feb 22, 2009 2:15 pm Post subject: Coolant temperature indicator |
Paul McAllister wrote:
Quote: | If your airplane isn't flying yet, then the effort is a lot less, if
Regards, Paul
So would I! Pity Rotax and Europa didn't warn us about the boiling
point of 50/50 glycol too
Graham
air.guerner(at)orange.fr Guest
Posted: Mon Feb 23, 2009 3:10 am Post subject: Coolant temperature indicator |
I am just curious to know how the coolant temp reading compares to the cyl 3 CHT reading.
Remi Guerner
F-PGKL
