Posted: Sat Feb 21, 2009 11:31 am Post subject: Plane Power R1224 to regulate B&C SD-20? |
At 11:51 AM 2/21/2009, you wrote:
Quote: |
The Plane Power R1224 regulator seems to provide the same
functionality as the more expensive B&C LS1 regulator (except for
temperature compensation). Would it would be suitable for
regulating a B&C SD-20 in a Z12 system?
TIA
Yes . . . assuming a 14v system. If you're installing
a 28v system, you MUST use the B&C regulator. It was
specifically designed to accommodate an alternator with
a 14v field winding in a 28v system. The SD-20 can
be used in either 14/28v but needs a special regulator
for 28v.
( -Thomas Paine 1776- )
rckol
Posted: Sun Feb 22, 2009 7:40 am Post subject: Re: Plane Power R1224 to regulate B&C SD-20? |
Upon closer inspection, the PlanePower regulator does not provide overcurent warning on its status lamp, like the B&C would if set up for it. But I suppose the same information could be determined by monitoring the alternator output current from a shunt.
_________________ rck |
