Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Tue Feb 24, 2009 7:44 am Post subject: Antennas for Europas |
Hi,
Frans Veldman did a superb job of explaining the practicality of the
half-wave dipole in particular for a Europa because of its great vertical
fin area.
As he said, the 'gain' attributed to other forms is always at the
cost of overall effectiveness where contact with ground stations is a
concern. The flashlight ( 'torch) is the perfect example. It doesn't light
up areas behind it very well, but the forward gain is excellent.
Perhaps another antenna could be a fullwave circular wire inside the
aft fuselage and fed at the fuselage join halfway up, but then you'd need to
point the Europa to fire ahead or behind.
Thanks, Frans
Ferg
| Description: |
 Download |
| Filename: |
winmail.dat |
| Filesize: |
7.87 KB |
| Downloaded: |
338 Time(s) |
Rowland_Carson
Joined: 04 Jul 2008 Posts: 155 Location: Cheltenham, England
Posted: Tue Feb 24, 2009 9:52 am Post subject: Antennas for Europas |
At 2009-02-24 10:42 -0500 Fergus Kyle wrote:
| Quote: | Perhaps another antenna could be a fullwave circular wire inside the
Fergus - apparently the directionality of a loop is not quite as
strong as one would assume. The "Morris Loop" has been around for a
while; see info at:
http://www.davemorris.com/dave/MorrisDFLoop.html
The author reckons that the theoretical null abeam may not be a real
disadvantage in practice. It's certainly another interesting
possibility for composite fuselages.
regards
Rowland
| Rowland Carson http://home.clara.net/rowil/
| <rowil(at)clara.net> ... that's Rowland with a 'w' ...
Fergus Kyle
Posted: Tue Feb 24, 2009 11:06 am Post subject: Antennas for Europas |
Rowland,
Quite right - not as critical as a flashlight, but my full-wave quad
on 7 megs got 15db less off the sides, made it worthwhile to aim. I once
flew a piper J3 which was equipped with an antenna that made it almost
impossible to contact without aiming - made the tower elves furious, as I
had to swivel to talk on ground control.
Cheers, Ferg
PS: The owner was an antenna designer for Bombardier's daddy, Canadair, and
kept playing with things.
| Description: |
 Download |
| Filename: |
winmail.dat |
| Filesize: |
7.44 KB |
| Downloaded: |
315 Time(s) |
