Bill1200
Joined: 19 Oct 2008 Posts: 111 Location: medford oregon
Posted: Tue Feb 24, 2009 8:10 am Post subject: Prop pitch control |
In the 52, if you lose oil pressure does the prop go to high or low RPM?
Posted: Tue Feb 24, 2009 8:43 am Post subject: Prop pitch control |
Before I answer this for you, let's think about the situation and what would happen if the prop went to coarse pitch or fine pitch.
What would happen if the prop went to fine pitch?
What would happen if the prop went to coarse pitch?
What do you think would be the way the prop should go if oil pressure was lost?
Dennis
wlannon(at)persona.ca Guest
Posted: Tue Feb 24, 2009 8:49 am Post subject: Prop pitch control |
Low RPM - High Pitch
JOE HOWSE
Joined: 10 Jan 2006 Posts: 140 Location: DUNCAN BC CANADA
Posted: Tue Feb 24, 2009 12:34 pm Post subject: Prop pitch control |
[quote] With counter weight constant speed props loss, of oil pressure allows the counterweights to set the blades to coarse pitch which is the least amount of prop drag, handy in case of engine failure.
Joe Howse
_________________ J.C. HOWSE |
