Gig Giacona
Posted: Tue Feb 24, 2009 2:33 pm Post subject: To 406 or not 406 that is the question. |
As we know the 121MHz aren't going to be monitored by satellite any more. But the 406MHz aren't required by the FAA. There is a huge price difference between the two and I was wondering what the builders who are getting close to flying are planning to go with?
I'm leaning towards an 121MHZ Ack E-01 and some sort of 406MHz personal locater. Then in a few years hopefully the price will drop on the Ack 406 unit.
601XL Under Construction
psm(at)att.net Guest
Posted: Tue Feb 24, 2009 3:05 pm Post subject: To 406 or not 406 that is the question. |
I'm planning to put off the decision until I get near the end of
phase I flight testing. I don't think I need an ELT until that task
is complete.
It seems silly to buy a 121 MHz device since nobody will hear it. I
will probably get the 406 one when the time comes. Current pricing
for these gizmos is around $1000, and it probably won't be much less
when I need it - maybe this Summer. That seems like a lot of money,
but it is less than 10 percent of the electronics in my plane.
Paul
XL getting close
At 02:33 PM 2/24/2009, you wrote:
| Quote: | As we know the 121MHz aren't going to be monitored by satellite any
Posted: Tue Feb 24, 2009 3:06 pm Post subject: To 406 or not 406 that is the question. |
Rules say: Two seat airplanes must have an ELT.
Thats it....
I m staying with 121.5. It does work.
FBO's and Unicom stations will be listening.
I guess if you fly across Keyna you might want 406....
Posted: Tue Feb 24, 2009 3:12 pm Post subject: To 406 or not 406 that is the question. |
Thats KENYA. Im lesdexic.. Duh!
Posted: Tue Feb 24, 2009 3:28 pm Post subject: To 406 or not 406 that is the question. |
Wait as long as you can to buy - prices are dropping and new 406 MHz models
are coming out. The ACK 406 is close enough in price to their 121 ($586 vs.
$140 on Spruce). But I don't know if it is shipping yet. Spruce also shows
an Ameri-King 406 MHz unit for $836.
Too late for me, I bought the $1200 Artex (now under $1000) and it doesn't
even accept a GPS feed.
Also the Canadians are insisting that all their planes upgrade including
visiting ones. So if you plan to fly into Canada...
-- Craig
tigerrick(at)mindspring.c Guest
Posted: Tue Feb 24, 2009 3:54 pm Post subject: To 406 or not 406 that is the question. |
Hi, Gig!
That's exactly what I'm planning on doing, buying a lower cost personal 406 PLB until the average price of aircraft units comes down, which it eventually will.
Even though the satellites won't be looking for ELTs anymore, CAP and other aircraft WILL continue to monitor 121.5.
I like the idea of being able to activate a personal PLB before a force landing, and being able to instantly travel with it. I do believe that McMurdo is coming up with a smaller, lighter, and lower cost PLB that's in the final approval stages that will sell for less than half of a comparable aviation 406 unit.
Rick
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Tue Feb 24, 2009 4:40 pm Post subject: To 406 or not 406 that is the question. |
On Tue, Feb 24, 2009 at 02:33:29PM -0800, Gig Giacona wrote:
| Quote: | I'm leaning towards an 121MHZ Ack E-01 and some sort of 406MHz personal
unit.
I'd recommend, if you go this route (and it's a reasonable one if you don't
want to spend the money for 406 righ away), to mount the ELT and antenna
where you can get to them easily. The 406 ELT will use a different antenna
from the 121.5 ELT, and you'll have to swap antennas when you do the
conversion. I'm not looking forward to the change in my Zodiac for that
reason (unless the ACK antenna can be changed without needing access to the
underside).
Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
Posted: Tue Feb 24, 2009 5:06 pm Post subject: To 406 or not 406 that is the question. |
| Quote: | Im lesdexic.. Duh!
Have you heard about DAM? Mothers Against Dyslexia.
-- Craig
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Tue Feb 24, 2009 5:07 pm Post subject: Re: To 406 or not 406 that is the question. |
My C130 will still monitor 121.5 and 406. also the civil airliners may still be monitoring 121.5 anyone know?. if they know you have a 121.5 they will find you but not as fast.. get a portable 406 and turn it on after the crash for extra protection.
Chris
Posted: Tue Feb 24, 2009 5:24 pm Post subject: To 406 or not 406 that is the question. |
According to some FAA folks I spoke to at a trade show last weekend,
all aircraft are supposed to monitor 121.5 at all times if they are
able to do so. Unfortunately, I was unable to find any reference to
this in the FARs.
Paul
At 05:07 PM 2/24/2009, you wrote:
| Quote: | My C130 will still monitor 121.5 and 406. also the civil airliners
Chris
Posted: Tue Feb 24, 2009 5:40 pm Post subject: To 406 or not 406 that is the question. |
The disadvantage of course to the 406 MHz PLB is that you have to be
conscious to activate it. I suppose if you are dead there isn't much rush to
find you. An alternative would be SPOT or the Ham radio based APRS tracker
devices is Byonics. Both will allow a third-party to track you and report
your last known position if you are overdue. The downside to SPOT is that
the cost of the unit ($100 or more) and the annual fee ($100 basic plus $50
for tracking). So in a few years the cost approaches that of a 406 MHz ELT.
But you (or your friends and family) get real-time tracking. The question on
APRS is coverage.
http://www.findmespot.com/en/index.php?cid=1113
http://home.hiwaay.net/~sbuc/journal/tracker.htm
http://www.byonics.com/
-- Craig
jmaynard
Posted: Tue Feb 24, 2009 8:08 pm Post subject: To 406 or not 406 that is the question. |
On Tue, Feb 24, 2009 at 05:23:27PM -0800, Paul Mulwitz wrote:
| Quote: | According to some FAA folks I spoke to at a trade show last weekend, all
aircraft are supposed to monitor 121.5 at all times if they are able to do
so. Unfortunately, I was unable to find any reference to this in the FARs.
I don't believe there is one in the FARs. However, I'd refer you to AIM
5-6-2(a)(2): "All aircraft operating in the US national airspace, if
capable, will maintain a listening watch on VHF guard 121.5[...]" That
paragraph has to do with intercept procedures, and it's a REALLY good idea
to comply.
Martin Pohl
Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
Posted: Wed Feb 25, 2009 10:56 am Post subject: Re: To 406 or not 406 that is the question. |
| Quote: | | civil airliners may still be monitoring 121.5 anyone know |
Yes, most of the civil airlines are monitoring 121.5 on the second set at all times (unless we have to contact a preceding sector for entry clearance on COM2).
It happens from time to time that we hear an ELT-signal on 121.5. We then relay this to ATC, including our position (if not under radar contact). What ATC does with this information is unknown to me (however I doubt that they start a search and rescue immediately...). Is anybody working at an ATC and knows their procedure?
Cheers, Martin
_________________ Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html |
