Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
kerrjohna(at)comcast.net Guest
Posted: Wed Feb 25, 2009 3:18 pm Post subject: CHT/EGT "Cold Junction" |
It is the ambient temperature at the instrument end of the thermocouple wires. My experience is that that variation is likely less than from instrument to instrument. You will notice some change from in indication at different ambient temperatures but also you engine will generate different CHT/EGT at different temperatures. In short, don't worry about it. You are seeking a reference temperature in any case.
John Kerr
Float Flyr
Joined: 19 Jul 2006 Posts: 2695 Location: Campbellton, Newfoundland
Posted: Wed Feb 25, 2009 4:25 pm Post subject: CHT/EGT "Cold Junction" |
The cold junction is simply a reverse thermocouple junction exactly like the
one you put on your engine. It is usually inside the instrument. (Gauge)
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Tom Jones
Joined: 12 Mar 2006 Posts: 729 Location: Ellensburg, WA
Posted: Wed Feb 25, 2009 5:44 pm Post subject: Re: CHT/EGT |
Okay, the connections between the thermocouples and the patch cables are behind the fire wall (cabin side) so the "Cold Junction" temperature will be close to the temperature inside the cabin. I wanted to be sure Cold Junction wasn't somewhere in the thermocouple cable on the front side (engine side) of the fire wall picking up engine heat under the cowl. Thanks guys! I can quit wondering about this now.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
