Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27016 Location: Livermore CA USA
Posted: Sun Mar 01, 2009 10:02 am Post subject: Slick Start Module |
Anyone using the Slick Start module on their Lycoming? A pirep would be most appreciated...
RV-8 #82880
Finishing Wiring
_________________ Matt Dralle
Dave(at)AirCraftersLLC.co Guest
Posted: Sun Mar 01, 2009 11:56 am Post subject: Slick Start Module |
Works very well with a single retard-point mag and no impulse couplings. Be
sure to only start on the retard point, not on the single-point mag.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
crowbotham(at)hotmail.com Guest
Posted: Mon Mar 02, 2009 5:51 am Post subject: Slick Start Module |
Hi Matt C
We installed the Slick Start on our IO-360 (200hp) with a single gel cel battery behind the rear bagage compartment. I felt that the slick start contributed to a quick atart even if the engine was hot (using the hot start procedure). Always got a start. I would install another on my next RV.
Chuck Rowbotham
RV-8A (sold)
[quote] Date: Sun C 1 Mar 2009 09:59:33 -0800
To: rv-list(at)matronics.com
Subject: Slick Start Module
--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com>
Windows Live™ Contacts: Organize your contact list. Check it out.
mcculleyja(at)starpower.n Guest
Posted: Mon Mar 02, 2009 9:55 am Post subject: Slick Start Module |
I've also used the Slick Start on my Lycoming O-360 for five plus years
and near 600 hours with a 17 AH RG battery, many "hot" starts, a Skytec
PM starter and B&C SD-8 PM alternator. I've never experienced better
overall performance and the elimination of an impulse magneto feature is
a very positive benefit.
Jim McCulley
Wittman Tailwind
Charles Rowbotham wrote:
| Quote: | Hi Matt,
Chuck Rowbotham
RV-8A (sold)
> Date: Sun, 1 Mar 2009 09:59:33 -0800
> From: dralle(at)matronics.com
> Matt Dralle ((SNIP))
chuck(at)chuckdirect.com Guest
Posted: Mon Mar 02, 2009 11:00 am Post subject: Slick Start Module |
Anyone got anything GOOD to say about a single impulse Slick mags for a
IO540? That's what I'm going to be running.
Chuck
| Quote: | I've also used the Slick Start on my Lycoming O-360 for five plus years
and near 600 hours with a 17 AH RG battery, many "hot" starts, a Skytec PM
starter and B&C SD-8 PM alternator. I've never experienced better overall
performance and the elimination of an impulse magneto feature is a very
positive benefit.
Jim McCulley
Wittman Tailwind
> Hi Matt,
> RV.
Jerry Cochran
Joined: 10 Jan 2006 Posts: 111 Location: Wilsonville, OR
Posted: Mon Mar 02, 2009 12:53 pm Post subject: Slick Start Module |
I've had 3 RV's all with O-360. The one with SlickStart fires instantly, far better than the others. I usually give it one stroke of throttle, no primer and she fires immediately in all kind of weather, engine temp hot or cold. Highly recommend same.
Jerry
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
Posted: Mon Mar 02, 2009 1:30 pm Post subject: Slick Start Module |
Chuck Weyant wrote:
a IO540? That's what I'm going to be running.
Same here Chuck.
If you do your job, it's expected. Screw up once, however ......
applies to mags too!
You shouldn't have any problems (unless the AD applies!) and should
overhaul them at 500 hrs. The overhaul will really make a difference,
trust me.
Linn
| Quote: | Chuck
> years and near 600 hours with a 17 AH RG battery, many "hot" starts,
> a Skytec PM starter and B&C SD-8 PM alternator. I've never
> experienced better overall performance and the elimination of an
> impulse magneto feature is a very positive benefit.
> Jim McCulley
> Wittman Tailwind
>> Hi Matt,
Checked by AVG - www.avg.com
