		Dave(at)AirCraftersLLC.co Guest
				 Posted: Sun Mar 01, 2009 11:55 am    Post subject: Filtered Air Box Failure |
				While we're on the subject, two weeks ago after about 300 hours, our FAB was
 found failed.
 The filter had rubbed its way all the through the fiberglass on the bottom
 edge.  There was a split in the glass along the outside edge of the filter
 in an arc of about 120 degrees.
 I think the fact that the filter is slighly compressed when the airbox is
 bolted closed gave it some preload against the glass, combined with enough
 vibration to wear through.
 We cleaned up the FAB and patched the crack, allowing the filter a tiny bit
 more room inside the box so that maybe with less pressure against the glass,
 it won't work against the inside as hard.  But, too little pressure and it
 won't seal.  It's a fine line.  I'll defineatly be watching it.  From the
 inside, you should be able to catch this happening long before it wears
 through.  I don't think I ever bothered to look closely.
 Remember that any repairs on the FAB should be done with vinyl ester as it
 is fuel proof.  Epoxy may or may not be, and fuel does tend to end up in the
 FAB from time to time.
 Dave Saylor
 AirCrafters LLC
 140 Aviation Way
 Watsonville, CA
 831-722-9141
 831-750-0284 CL
 www.AirCraftersLLC.com
 N921AC 335 hours
		AirMike
				 Posted: Wed Mar 04, 2009 2:35 pm    Post subject: Filtered Air Box Failure |
				Wow - thanks for the heads up on that Dave. Might be a good idea to add a bit more glass during the build while the unit is free of grease. good post.
  _________________ See you OSH '18
Q/B - sold. |
