alikatz(at)mbay.net Guest
Posted: Tue Mar 03, 2009 9:02 pm Post subject: Oil filter |
Craigs works Great..
Best Regards
Jim
ChangDriver
Posted: Wed Mar 04, 2009 7:14 am Post subject: Re: Oil filter |
From the Yak-list Archives...Walt Lannon posted:
"I would recommend either ADC or Airwolf. My personal preference is the ADC micro-screen unit rather than the spin-on. ADC provides both types, Airwolf is spin-on only.
I would avoid cheap non STC'd systems which invariably utilize spin-on filters that are not capable of safely handling high scavange oil pressures.
Like most other things in aviation you get what you pay for.
Walt"
I installed the ADC micro-screen filter in my CJ. In the past, ADC has also been a sponsor of ARS. It is a well made product.
Contact Barry Hancock about installation as he did the install in my plane. We put it on the firewall after relocating the air start solenoid (may not have to do this on later model CJs). I've also seen pictures of it placed in the belly of the aircraft.
Craig
cpayne(at)joimail.com Guest
Posted: Thu Mar 05, 2009 3:55 am Post subject: Oil filter |
I let the quoted post from Walt pass the first time because it wasn't specifically aimed at the system I sell. But now I see it has been offerred up as specific answer to questions about the quality of the goods I sell.
Just what kinds of "high scavage oil pressures" are we talking about here?
Craig Payne
cpayne(at)joimail.com (cpayne(at)joimail.com)
wlannon(at)persona.ca Guest
Posted: Thu Mar 05, 2009 9:20 am Post subject: Oil filter |
Depending on temperature of the oil scavenge pressure could reach 200 psi or more. There is no pressure regulator in the system.
Harvard trainers which operated throughout the Canadian winters were equipped with an in-line, adjustable, bypass valve which, at 83 PSI would open full line capacity directly to the oil tank. This bypassed the oil cooler and the lower capacity valve located there. This system not installed on the T6.
Craig, I have no idea what system you sell nor was I even aware that you sold one, but If that is the case may I suggest you compare the internal construction of your filter unit to a standard, certificated, aircraft oil filter ( Champion, etc.).
If it compares favourably in paper element thickness, can wall thickness and other pressure retaining features it should be fine.
Walt
Posted: Thu Mar 05, 2009 1:20 pm Post subject: Oil filter |
Walt,
Thanks for the explanation. I know what I have, the problem was a careless post on the 'list in reply to a question about the viability of the system I sell. The elements I sell have a 200PSI rating, they are industrial grade not automotive. My base units have a 15PSI bypass valve with in/out taps for those who want to rig a monitor. I can also get other PSI settings as well. There are dozens of CJ's out there with the same setup, running for many years now.
The original post about a cold weather failure was not very inclusive about the nature of the installation. Therein, may lie the problem. My install instructions stress the necessity of an end-to-end solution.
I can still get the heavy duty Marion elements with 'glass media but you can't cut them open and peel back the media. Myself, I send out a sample from each change and keep an analysis track.
Craig Payne
keithmckinley
Posted: Thu Mar 05, 2009 4:57 pm Post subject: Re: Oil filter |
For what it's worth I purchased a CJ with a system, if not Craig's, is exactly the same right down to the Marion Hyd Filter.
Recently the system suffered a catastrophic failure on the ground.
I use Phillips 25-60W radial engine oil and my aircraft had been in an unheated hangar during a cold night. It was about 25 degrees the morning I was to fly. Prior to engine start, I had my sump and tank heater on for two hours. I did not have a strip heater on my oil cooler. Prior to engine start the oil temp indicated just above 10C
After engine start, pressure and temp were normal for the conditions and the engine was at idle for 2-3 minutes before I added power to taxi.
As I added power the system failed. The oil filter actually blew up like a balloon, but it was the threaded shaft ( for the filter) on the housing that suffered a shear failure.
I do know that even cold hyd fluid has a lot less viscosity than my engine oil. I also know that the by-pass in the housing was insufficient in my case.
It's very small, maybe 1/8 or 3/16 in diameter. Also, Without going back to my logs I was about 25 hours from the last oil change. I suspect a combination of the small filter size and 10 micron paper as well as the small by-pass led to the failure.
It's up to you to evaluate each system for what it was designed to do, what you plan to do with it, and how your operational environment will affect it
I've installed the ADC spin on system for radial engines. I like the fact that it uses aviation grade oil filters, it is STC'd, it has a very large by-pass, and can accept a chip detector system.
To each his own.
Keith
Posted: Fri Mar 06, 2009 3:55 am Post subject: Oil Filter |
Oh well, here we go again. Oil filtration systems on the CJ can be, and have been installed several different ways. Just because a particular filter element is used, does NOT define the layout of the installation.
IMHO, in cold weather operations one proven failure mode is the built-in Oil Cooler Bypass Valve. Often this valve becomes gummed up with carbon sludge and fails to function properly, allowing pressures to build "upstream". Excess pressure has been known to rupture oil coolers in both CJ's and Yaks. Without a properly functioning Filter Bypass built into the filter base, the element could rupture as well. It takes BOTH bypass valves working to provide a path for high pressure oil.
Another discussion could be had about WHAT should be done in cold weather BEFORE the start switch is pushed and HOW the engine should be warmed up. I have started my CJ in below freezing weather, with the oil filter installed, and have seen no failures. However, I did see the oil pressure go to zero, in flight, because my shutters were jammed open in cold temps. Another question is WHAT the effect of cold starting has on long-term life of the engine.
Craig Payne
yakplt(at)yahoo.com Guest
Posted: Fri Mar 06, 2009 3:34 pm Post subject: Oil filter |
Keith, you said: "I suspect a combination of the small filter size and 10 micron
paper as well as the small by-pass led to the failure."
Ok. I am sure that these were contributing factors, but hey... are you saying
that you do not think that the temperature and the viscosity of the oil had
anything to do with this?
The engine block in your aircraft was dead cold. Even if the sump and oil
tank came up to temp in two hours, (which I have to wonder about) you have
to realize that the oil in that oil cooler was colder than ... well...
real cold (and so was the majority of the rest of a rather large motor).
I suspect your oil filter actually failed from an extreme overpressure due to
cold and thick oil. We're talking about a gear driven pump design here!
I agree totally that the filter in your aircraft failed first, and that proves it was
the weak link in the chain. But I also remember seeing an M-14 blow the
oil cooler apart like a freaking hand grenade when the whole engine was
not pre-heated and there was a thick slug of cold oil in the oil cooler.
I have flown engines with a tank pre-heater, a sump pre-heater and an oil
filter by-pass valve that is thermostat controlled and with all that, I have
NEVER seen those engines ready to taxi in that kind of temperature in two
minutes... even after having it left the electric heaters on all night.
Stop and think.. some of your oil was pre-heated. When that oil hit your oil
temp sensor, of course it will "look about right", but the engine itself is
anything BUT warmed up in two minutes!
The original Russian design used an oil dilution system. No one really likes that
system, but if operated properly it totally avoids failures of this nature. I am
not recommending that we use it, but if we decide to go to something else, we are
moving into the realm of experimental design. Your new filter may indeed be STC'ed,
but my bet is that you have simply moved the first weak point (filter) to a NEW weak
point.. such as the oil cooler, or a hose.. or .... whatever.
I am not saying this to disagree about your selection of a good oil filter, far
from it. What I am saying is that I do not know a radial engine on the planet that
is ready to taxi in two minutes after a 25 degree Fahrenheit start-up without
a complete engine pre-heat prior to start.
Just my 2 cents, but something to at least think about.
Mark Bitterlich
From: keithmckinley <keith.mckinley(at)townisp.com>
To: yak-list(at)matronics.com
Sent: Thursday, March 5, 2009 7:57:29 PM
Subject: Re: Oil filter
--> Yak-List message posted by: "keithmckinley" <keith.mckinley(at)townisp.com (keith.mckinley(at)townisp.com)>
To each his own.
Keith
Keith McKinley
700 HS
KFIT
http://forums.matronics.com/vibsp; -Matt Dralle, ===========
talew(at)bellsouth.net Guest
Posted: Fri Mar 06, 2009 4:13 pm Post subject: Oil filter |
keithmckinley
Posted: Sun Mar 08, 2009 4:50 am Post subject: Re: Oil filter |
I just stated the fact of my failure. I wasn't impugning the set up you sell. You or anyone can take it for what it's worth or not.
Maybe my ground operations were the cause maybe not. But if you really want to call a spade a spade you shouldn't be putting a hydraulic filter made for a damn log splitter on an airplane.
Fire away.
Keith
Posted: Sun Mar 08, 2009 10:39 am Post subject: Oil filter |
Keith I don't have a dog in this fight... I don't sell filters, and in fact my engine is completely stock in this regard. So hey... I don't know beans about which filter anyone should use and I am sure your experiences using them is worthwhile telling people about.
Your first posting mentioned increasing engine RPM to taxi the aircraft, 2 minutes after starting on a 25 degree day with an oil tank and sump pre-heater operating about 2 hours first. My response is simple. Calling a spade a spade: I don't think that is anywhere near enough time to warm up an engine under these conditions and anyone doing what you did is going to subject the engine to extreme stress as evidenced by the fact that OIL COOLERS HAVE BLOWN UP UNDER THE SAME CIRCUMSTANCES.
If you or anyone else reading this wants to ignore my opinion in this matter, that is up to them. I really could care less.
Mark Bitterlich
N50YK
Sent: Sunday, March 8, 2009 8:50:52 AM
Fire away.
Keith
Keith McKinley
700 HS
KFIT
http://forums.matronics.com/viewtopic.php?p=233682#233682
bsp; -Matt Dralle, List Ad=========
cjpilot710(at)aol.com Guest
Posted: Sun Mar 08, 2009 11:57 am Post subject: Oil filter |
I'll put in my 2 cent worth.
I've used a Marion S10 filter on my M-14p for all of its 1,500 hours. I believe its been a major (if not the major) component along with the pre-oiler, that has kept my running pretty damn well. Compressions still in the low 70's as of last annual. This filter though not an "approved" aviation filter looks just a beefy on the inside as the approved ones I've cut open. I like the fact that I can cut out the paper filter accordion, lay it out to drain than check it for metal. Being a 10 micron filter I'm real confident its doing its job. It's price allows me to change it more often which is an incentive to anyone under BO's plans.
Now being a Florida boy, I have no need for pre-heat. BUT I've some experience with the problem BUT never in the extremes. Quite regularly on the B-24, after starting (away from sunshine of FL) we warm up at a max of 1,000 rpm until the temp is a "STEADY" 40C or better. The reason is we'll see the oil temp rise after start to above 40C and than maybe 2 minutes later, drop significantly cold again. Reason? The cold oil back in the cooler hit the sensor on the way into the engine. It is usually close to 5 minutes or more before we can exceed 1,000 rpms for taxi.
Oil dilution system was (I was told) "invented" by the Poles at the beginning of WW2. The Germans supposedly picked it up from them, and the allies followed suit. It is not meant to be a long term procedure for cold weather. You add enough fuel from one of your fuel tanks, to keep the oil thinned out for the length of time you will have the engine shut down. That is why that switch is spring loaded OFF. There were tables that told the crew how long (seconds or minutes) to hold the switch open for the length of time the engine was to be shut down. I never saw a table go beyond 24 hours. And once you used the system you were restricted on how soon you could start the engine again. I hope my memory is still good!!
My CJ showed up from China with a little blank on the oil cooler, oil tank, and oil sump. It of course had an oil dilution system. ( With the change to the M-14p, I removed the oil dilution system. I now use the valve for the smoke system and the switch for the pre-oiler). I do not and never have used multi grade oil. I go from using 50 (100w) in the winter to 60 (120W). I just do not envision myself flying my CJ in really cold climates. IF I did, I would put on a restriction plate on the oil cooler inlet. Also I'd put a electric preheat blank -not only on the oil tank - but the cooler as well. I'd most likely go to a multi grade oil too.
We'll heard of the stories of the Alaska bush pilots, who in the winter, would drain their oil while still warm from their engines and take it into their beds with them. The next day, they'd cook it over a fire, and pour into their engine when ready to start. (Some still do that I'm told.) Anyway extreme temps require extreme measures to able to operate. And when you look at the cost of these pre-heat systems over what it might cost in fixing problems caused by the oil being to cold. That might be the "cheap answer"
In a message dated 3/8/2009 2:40:35 P.M. Eastern Daylight Time, yakplt(at)yahoo.com writes:
| Quote: | Keith I don't have a dog in this fight... I don't sell filters, and in fact my engine is completely stock in this regard. So hey... I don't know beans about which filter anyone should use and I am sure your experiences using them is worthwhile telling people about.
Mark Bitterlich
N50YK
Fire away.
Keith
Keith McKinley
700 HS
KFIT
="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Check all of your email inboxes from anywhere on the web. Try the new Email Toolbar now!
keithmckinley
Posted: Sun Mar 08, 2009 1:10 pm Post subject: Re: Oil filter |
Mark,
I agree, that's why I posted the details as best I could remember. Hell other than my 75 hours of round engine time courtesy of the Navy and my 100 hours in a C-152 I'm a jet guy learning about this piston stuff more and more every day.
As for the oil. I'd be curious what others operating in colder climes use in the winter months. As I said I just don't know enough right now to be comfortable switching oils around without some facts.
For the record the warm up was more than 2 minutes but obviously needed to be 10-15. before advancing the throttle. I'm also guessing that roughly 25% of the oil (cooler and lines) was not heated
Keith
Posted: Mon Mar 09, 2009 3:09 pm Post subject: Oil filter |
My 2 cent reply to this message is: To the best of my knowledge and
experience, every word this man says is exactly dead on accurate, and I
wish I could have said it as well.
Mark Bitterlich
N50YK
wdjester(at)cox.net Guest
Posted: Mon Mar 09, 2009 3:22 pm Post subject: Oil filter |
All: I just purchases a Kimball Enterprises oil shut off valve and separate
scavenge pump. I got pictures from Jim Kimball on the installation. The
scavenge pump is not a problem. However, the oil shit off valve does not
fit where Kimball says to put it. The machined part is much larger than the
one in the pictures. Has anyone installed the newly machined oil shut off
valve on their Yak 52. If yes, how did you do it?
Dave Jester
Posted: Mon Mar 09, 2009 5:05 pm Post subject: Oil filter |
In a message dated 3/9/2009 7:22:38 P.M. Eastern Daylight Time, wdjester(at)cox.net writes:
Hay Goatboy!
Check your spell checker! Where is that shit off valve located?? Man I want to see one of them! ))))
Pappy
[quote]--> Yak-List message posted by: "Dave \"Goatboy\" Jester" <wdjester(at)cox.net>
Dave Jester
Posted: Mon Mar 09, 2009 7:18 pm Post subject: Oil filter |
Well damn. Good eye Pappy. I stand corrected. I meant I purchased an oil shut off valve....in my defense the u is next to the i on the keyboard.
