AirMike
Posted: Wed Mar 04, 2009 2:33 pm Post subject: Fuel injection servo attachment - concerned ? |
Trying to get my Precision Airmotive silver hawk EX F/I servo attached permanently to the Mattituck engine and Filtered Air Box.
I called Mahlon at Mattituck who told me that the servo is bolted on to the engine with the already attached studs. He said to use a std washer and then a star washer over that before you bolt it on to 204 in/lbs. I assume that it will not vibrate out - does anyone use locktite????
Next is the attachment to the FAB box which is accomplished with the supplied "non-standard" 1/4 x 20 bolts that are 1/2 inch long. Instead of the standard #AN4 bolts that can be safety wired. These to be secured with 96 in/lbs into the aluminum. Ingetion of these bolts into the maifold could be catastrophic.
Question: Does anyone know a source for 1/4 x 20 x 3/4" long (the 1/2" are too short) bolts that are drilled with a hole for safety wires????
_________________ See you OSH '18
Q/B - sold. |
egohr1
Joined: 17 Jan 2006 Posts: 38 Location: Oklahoma City
Posted: Wed Mar 04, 2009 4:33 pm Post subject: Re: Fuel injection servo attachment - concerned ? |
Check with Vans. My FAB came with drilled bolts straight from Vans. The bolts are specifically noted as needing to be safety wired.
_________________ eric gohr
EGOHR86@alumni.carnegiemellon.edu |
Posted: Wed Mar 04, 2009 6:21 pm Post subject: Fuel injection servo attachment - concerned ? |
Those should definitely have come with the FWF kit if I remember
correctly. Either that or it should come with the engine, but I think
in one of the hardware bags in the FWF kit. Check those out.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Mar 4, 2009, at 5:33 PM, AirMike wrote:
locktite????
wires????
OSH '08 or Bust (busted) be there in "09
Q/B Kit - wiring and FWF
http://forums.matronics.com/viewtopic.php?p 33228#233228
AirMike
Posted: Wed Mar 04, 2009 10:26 pm Post subject: safety wired bolts |
My FWF kit that I picked up approx August '07 has these plain 1/2" long 1/4x20 bolts. They use this "tab/washer arrangement" to secure the bolts in place. I consider this a poor solution and potentially dangerous giving you four more pieces of steel in the FAB.
I may have located the drilled 1/4 x 20 bolts at Spencer Aircraft in Washington State.
Q/B - sold. |
bkbrown(at)minetfiber.com Guest
Posted: Thu Mar 05, 2009 6:34 am Post subject: Fuel injection servo attachment - concerned ? |
Remember that it's really not a big deal to drill a bolt, either the head or
the threaded end. There are jigs out there to help you do it (Avery or
Cleveland), or if you're a welder, you can make a jig. I have purchased
many bolts for things like FAB's from a nearby farm supply store, some of
them maintain excellent selections (lengths and diameters) of grade 5 and
grade 8 bolts and various lock washers. All the attachments to my FAB on my
plane are safetied...although there are also some shop side rivet heads that
could conceivable break off and get sucked in. The reality though is, that
isn't the cause of very many accidents that I'm aware of. Good luck in your
search. BTW, I hate tab washers...and have broken many tabs at installation
over the years...which doesn't inspire much confidence in them for me.
Mike Whisky
Posted: Thu Mar 05, 2009 8:20 am Post subject: Re: Fuel injection servo attachment - concerned ? |
Interesting explanations on locking methods:
http://www.roymech.co.uk/Useful_Tables/Screws/Locking.html
Michael
_________________ RV-10 builder (flying)
#511 |
partner14
Posted: Thu Mar 05, 2009 8:34 am Post subject: Fuel injection servo attachment - concerned ? |
Without the cost of a special jig, just purchase several center drills. Used in the machinists arean a lot. They come in several sizes. I use them for starting lot's of holes because they don't wander.... and I just finished drilling a bolt that I needed that was just a little longer than the pre-drilled bolt I had... no problem.
Don McDonald
--- On Thu, 3/5/09, Bob and Karen Brown <bkbrown(at)minetfiber.com> wrote:
From: Bob and Karen Brown <bkbrown(at)minetfiber.com>
Subject: RE: Re: Fuel injection servo attachment - concerned ?
Date: Thursday, March 5, 2009, 6:32 AM
--> RV10-List message posted by: "Bob and Karen Brown" <bkbrown(at)minetfiber.com (bkbrown(at)minetfiber.com)>
40636 |
AirMike
Posted: Thu Mar 05, 2009 9:32 am Post subject: Fuel injection servo attachment - final word |
I spoke to Vans this morning.
Apparently I had the FAB installation kit with bag 939-1. This kit was delivered in August of 2007.
Bag 939-1 has been superseded by bag 939-2 with 1/4x20 bolts that are DRILLED.
Vans does not show this item in their on-line catalog and I was unable to find these drilled bolts anywhere else. I would urge anyone using the tabs to replace them with the drilled and safety wired bolts. The tabs are only supposed to be used once and could work harden and break off if used twice
Q/B - sold. |
AV8ORJWC
Posted: Thu Mar 05, 2009 3:19 pm Post subject: Fuel injection servo attachment - concerned ? |
An exceptional reference with one small footnote. Nylocs have a max
temperature range and should be used judiciously around the FWF
application or near brake cylinders and M5606. Heat will cause a loss
of locking capability at your worst time. Other nuts meet that higher
temperature requirement.
To that I add, every builder is the manufacturer, they set their
standard on their experiment and they know best!
John
jcumins(at)jcis.net Guest
Posted: Fri Mar 06, 2009 12:11 pm Post subject: Fuel injection servo attachment - concerned ? |
If any one needs good aircraft hardware go to JCAero.com. He has anything
and everything you need if it is not on his web site give him a call and we
will have it or he can order it. I get all my hardware from him and he is
way cheaper then the other places.
But I can drive right up to his shop and get anything I need on a moments
notice.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Sat Mar 07, 2009 3:47 am Post subject: Re: Fuel injection servo attachment - concerned ? |
AirMike,
There are many ways to lock a bolt in place and there is nothing wrong with the tabs that were sent with the kit. They work fine and are a recognized way of safetying a bolt to prevent backing out. So is staking but bent tabs are much easier for homebuilders. Often times it is not practical to safety wire and this is a good substitute. Of course you can only use it once.
You can replace it with a drilled head/safety wire combo if you like, but it is not correct to say it is "dangerous".
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
Gordon Anderson
Posted: Sun May 17, 2015 1:12 am Post subject: Re: Fuel injection servo attachment - concerned ? |
I have the Van's Lycoming IO-540 and am ready to attach the fuel servo to the engine, but cannot find any instructions or hardware. Only the nuts and plain washers holding the plastic "preservation" cover plate on the sump together with a blind gasket were supplied with the engine & servo.
Lycoming Service Instruction 1484C gives the torques but states to "refer to the Parts Catalogue for the correct washers, lock washers, nuts, gaskets and spacers"
Can anyone provide a copy of the relevant page in the Lycoming parts catalogue?
Assuming a gasket is required, is it normal to use one both above and below the control cable bracket?
Gordon Anderson
Switzerland
Posted: Sun May 17, 2015 5:54 am Post subject: Fuel injection servo attachment - concerned ? |
You want a gasket on both sides of the bracket and you want lock washers under the nuts holding the servo on. The hardware, IIRC, should have been included with the FWF kit.
Jesse Saint
352-427-0285
Sent from my iPad
| Quote: | On May 17, 2015, at 5:12 AM, Gordon Anderson <mregoan(at)hispeed.ch> wrote:
Lycoming Service Instruction 1484C gives the torques to "refer to the Parts Catalogue for the correct washers, lock washers, nuts, gaskets and spacers"
Gordon Anderson
Switzerland
http://forums.matronics.com/viewtopic.php?p=442185#442185
Posted: Sun May 17, 2015 6:13 am Post subject: Fuel injection servo attachment - concerned ? |
You might want to look again. Hardware and gaskets should be in a bag that
came with the engine. If it is not there give Van's a call.
Yes - a gasket goes on each side of the control cable bracket. If memory
serves, the bracket came with a gasket.
Carl
Gordon Anderson
Posted: Sun May 17, 2015 11:52 am Post subject: Re: Fuel injection servo attachment - concerned ? |
Carl, Jesse, thanks a lot for challenging me to go look again. Now I managed to find the hardware and gasket. Definitely time for some 5S in the workshop….
Cheers,
Gordon
