jefflinebaugh(at)gmail.co Guest
Posted: Sat Mar 07, 2009 8:03 am Post subject: CJ Towbar |
Don't laugh...but for moving by hand, I went to the Aviation Dept of Home Depot and got some metal pipe.... about a 12" section to go through the nosewheel (retaining pin optional), a 90, then about 6 feet of pipe, a tee, and two sections for the handle. Painted to match the airplane of course... Worked great...
For moving with a tug, I got some square tubing, and had one welded up..about 100 bucks and a bunch cheaper than going out and buying one from Spruce that doesn't work well... I still have them both if you want pictures for ideas, I'd be happy to share...
Jeff Linebaugh
jefflinebaugh(at)gmail.com (jefflinebaugh(at)gmail.com)
skidmk
Joined: 19 Nov 2007 Posts: 171 Location: Ottawa, Ontario
Posted: Sat Mar 07, 2009 5:50 pm Post subject: Re: CJ Towbar |
I'd love to see some pictures Jeff.
_________________ Mike "Skidmk" Bourget
Ottawa, Ontario |
KingCJ6(at)aol.com Guest
Posted: Sat Mar 07, 2009 6:04 pm Post subject: CJ Towbar |
Jeff - knowing your attention to detail & authenticity, were you able to find suitable metric threaded pipe for this unique item, or did you simply settle for standard U.S. threads?
Dave
In a message dated 3/7/2009 8:04:29 A.M. Pacific Standard Time, jefflinebaugh(at)gmail.com writes:
| Quote: | Don't laugh...but for moving by hand, I went to the Aviation Dept of Home Depot and got some metal pipe.... about a 12" section to go through the nosewheel (retaining pin optional), a 90, then about 6 feet of pipe, a tee, and two sections for the handle. Painted to match the airplane of course... Worked great...
For moving with a tug, I got some square tubing, and had one welded up....about 100 bucks and a bunch cheaper than going out and buying one from Spruce that doesn't work well... I still have them both if you want pictures for ideas, I'd be happy to share...
Jeff Linebaugh
="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
