davies.leo(at)gmail.com Guest
Posted: Sun Mar 08, 2009 2:34 pm Post subject: RV10-List Digest: 22 Msgs - 03/07/09 |
Re: Fitting rear windows with the cabin roof off the plane.
I would counsel against this.
The cabin roof is quite "floppy" off the plane. If you bond the windows in this situation the cabin roof will invariably have a slightly different configuration to its installed position. When you install it you will be preloading the bonded plexiglass which is generally a bad idea.
The rear windows can be clamped in place with the cabin roof mounted by running straps around the plane and using spacers (lengths of 2 X 4 or similar) to apply pressure where needed.
Leo Davies
RV6A flying
RV10 gestating
