				 Posted: Tue Mar 10, 2009 12:55 pm    Post subject: Bottom Drain Fuel Tank Bushings |
				Mike
 The first set came from Kolb with my kit. I don't remember where I got the
 current set. I see Aircraft Spruce carries them. When I replaced the tanks I
 changed the fittings to fittings with a finger strainer and a shut off
 valve. AS part # FFV01 & FTB01.
 Again I make sure the hole is round and smooth with no burs. Then I push in
 the bushing, lubricate the fittings and push in the fitting. Never had a
 leak. Of course now that I said that.... I like to replace the rubber
 bushings and maybe the fuel tanks every 6 years or so. If nothing else I
 like to just spend a buck each every 5-6 years for a replacement rubber
 bushing, its also a good time to flush out your fuel tanks real good.
 Rick Neilsen
 Redrive VW powered MKIIIC
		George Alexander
				 Posted: Tue Mar 10, 2009 1:18 pm    Post subject: Re: Bottom Drain Fuel Tank Bushings |
				 	  | NeilsenRM(at)comcast.net wrote: | 	 		  Mike
 < < <SNIP> > >
 Rick Neilsen
 Mike et al:
 Rick said it, but I would stress the point, lubricate the fitting and PUSH them in.  Making sure that the fitting remains perpendicular to the surface where the bushing will seat.  Any attempt to get it to go in by twisting and turning will possibly distort the hole and may increase the possibility of a leak.   Would be more likely with the newer thin wall tanks.
 Tanks on my three previous airplanes, over the last dozen years, were bottom fed.  Unlike Rick, I was a big spender and changed them at least every other year.  Probably didn't need to, but it made me feel better.  Never had a leak.
 Just switched my FSII tanks over to bottom feed.
  _________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
