Fuel tanks
mdnanwelch7(at)hotmail.co
PostPosted: Thu Mar 12, 2009 2:31 pm    Post subject: Fuel tanks Reply with quote
Jim C
(please note corrected spelling of the subject)
Jim C
  Exellent point re: 5052.  I hadn't done any research for the proper aluminum alloy to use.  I had just recently purchased some 2024T6 from these folks C and was simply passing that information along that they carried 2024.
  My apologies for making it look like I was suggesting 2024 for tanks.  You are correct that the best aluminum alloy for fuel tanks is 5052.
  Since Jim points out 5052 is the best alloy C anybody care to advise the best thickness.  My guess would be about .0625.  Anyone have a tank and know what thickness you used?
Mike Welch
MkIII
Subject: Re: Re: Fjuel rtanks
Date: Thu C 12 Mar 2009 18:12:44 -0400
Mike;
I wouldn't use 2024 aluminum for a fuel tank. Use 5052 aluminum. 2024 corrodes real easy and with today's fuel you would be looking at severe corrosion problems with 2024.
5052 is a marine grade aluminum and is very resistant to corrosion.
Just my 2 cents worth.
Jim H
(I have been welding aluminum for 60 years and still no expert)
ttp://www.matronics.com/Navigator?Kolb-List
ronics.com
ww.matronics.com/contribution
Windows Live™ Contacts: Organize your contact list. Check it out. [quote][b]
PostPosted: Thu Mar 12, 2009 2:53 pm    Post subject: Fuel tanks Reply with quote
.050"
ISince Jim points out 5052 is the best alloy, anybody care to advise the best thickness. My guess would be about .0625. Anyone have a tank and know what thickness you used?
Mike Welch
jimh474(at)embarqmail.com
PostPosted: Thu Mar 12, 2009 3:02 pm    Post subject: Fuel tanks Reply with quote
Mike;
I use .050, 5052 on all aluminum tanks that I weld up. John's 25 gallon tank is .050. and cross baffled.
Jim Hauck
PostPosted: Thu Mar 12, 2009 3:12 pm    Post subject: Fuel tanks Reply with quote
Hi Gang:
Highly recommend sloshing the tank after fabrication. Will eliminate future headaches.
Jim welded up an 18 gal tank for my FS.  That was 1987. We did not know about sloshing the tank. Water tested, pressure tested, thought we had it, but down the road it sprung a leak in the most in accessible place.
1991, Jim welded up a 25 gal tank for my mkIII. Water tested, pressure tested, sloshed, and never looked back. That was nearly 2,900 flight hours, and three crashes ago.  This tank just keeps on ticking.
.050"
olendorf
PostPosted: Fri Mar 13, 2009 8:59 am    Post subject: Re: Fuel tanks Reply with quote
Here is the company that made my 8 gal tank. The tank is working great. No leaks. http://www.alumiworx.com/cart/index.php?act=viewProd&productId=20
 Filesize:  97.31 KB
 Viewed:  4722 Time(s)
Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/
